🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
what is the simplest way to read 7 switches w/4 wires
by ajoslin103 on Mon Feb 15, 2016 3:07 pm
Hi There,
Dammit Jim! I'm a programmer, not an Electrical Engineer!!
Logically speaking I wanted to use 3 lines to read as many switches as possible (knowing I had to save one for power.) So I thought of the 3 lines as binary counting and decided I could read 7 switches -- 001, 010, 011, etc...
So I wired up 7 switches with each one connecting to the proper wires using the binary 'directions' -- and Hey Presto, all three lines light up no matter which switch I press.
Which gets me to thinking about using transistors in some reverse-cascade arrangement (I'd have to figure that out) so that only the lines I want energized become so when I press each switch.
Thinking about transistors leads me to thinking that there may be a chip to do this job, and multiplexing comes to mind -- but everything I can find seems to need some computing on both ends and I want only switches on the far end.
So after trying to read a bunch of bunch of EE greek-to-me stuff I bail out on that.
So I think about the mess for a while longer and realize that the current is flowing 'backwards' and cross connecting the lines -- and a quick google search tells me that I could use diodes to control the directional flow of current and that would probably work.
Is there a better way to put 7 switches out at the end of a 4 conductor wire and be able to tell which one is being held down? I'm willing to put a chip out there, but I don't want to put a computer out there.
ajoslin103
Re: what is the simplest way to read 7 switches w/4 wires
by paulf8080 on Mon Feb 15, 2016 9:31 pm
Google 8 to 3 encoder
paulf8080
by paulf8080 on Mon Feb 15, 2016 9:32 pm
paulf8080
by franklin97355 on Mon Feb 15, 2016 9:35 pm
Something like this should work http://www.onsemi.com/pub_link/Collateral/MC14028B-D.PDF This is not the only chip out there, Google "binary to decimal" for more
franklin97355
by ajoslin103 on Tue Feb 16, 2016 9:28 am
thanks for these great answers -- I've ordered some chips
ajoslin103
by ajoslin103 on Wed Feb 17, 2016 7:21 pm
ok, so the diodes arrived -- and it works as I had predicted !! a small test with 4 switches and 3 wires works !!
logic wins !!
the chips should show up Friday, and I can try all 7 switches without a [small] spiders nest of diodes :)
ajoslin103
by ajoslin103 on Wed Feb 17, 2016 7:31 pm
sample code for a Espruino
// standard options for pins
var stdOpts = { repeat: true, edge:'rising', debounce:25 };
// when a pin changes call the fn with everything we know
function onChange ( pin, fn ) {
  return function changed ( evt ) { // rather than the little bit they give us
    fn.call(null,pin,evt);
// setup the watch on the pin to call the changeFn
function setupInput ( pin, changeFn, opts ) {
  digitalRead(pin);
  pinMode(pin, "input_pulldown");
  setWatch(onChange(pin,changeFn),pin,opts);
// the pins we'll use
var pins = [ 'B3','B4','B5' ];
// our binary source
var binary = [0,0,0];
// when a pin is on set it's associated bit
function pinIsOn (ndx) {
  return function (name,evt) {
    binary[ndx] = 1;
// initialize the pins
pins.forEach(function(e,x){ setupInput(e, pinIsOn(x), stdOpts); });
// every 1/2 second output the last button pushed
setInterval(function(){
  var binStr = binary.reverse().join('');
  if (binStr) {
    var btn = parseInt(binStr,2);
    if (btn) {
      console.log('switch ',btn);
  binary = [0,0,0]; // and reset
},500);
ajoslin103
by ajoslin103 on Fri Feb 26, 2016 7:34 pm
I should have been looking for Encoders as suggested by others
The MC14028B is a Decoder
Will advise on success...
ajoslin103
by ajoslin103 on Fri Feb 26, 2016 7:58 pm
wait a minute - using an encoder is going to require me to supply it with not only +3v but also a gnd -- right?
I only have 4 wires -- if I use one for +3 and one for gnd then I only have 2 wires left to read 7 switches !!
My diode solution handled the problem by only completing the circuit when a switch was pressed...
Hrmmmm......
Is there a chip that does 'cascading' diodes that doesn't need + and gnd ?
ajoslin103
