🔮Adafruit sale all weekend long – use the code ADATHX for 15% off! 🔮
Adafruit 2.8" PiTFT - Capacitive Touch help for touchscreen
by Fluchers on Wed Feb 17, 2016 3:54 am
Hello, within the framework of a personal project which requires a use of a touch screen on raspberry, I have to use the tutorial of Lady Ada concerning this subject. After several unfruitful tests with my OS personal, I have to decide to use the image of raspbian Jessie provided in the tutorial, all functions except the touch screen.
If you would have whatever explanation has to provide me concerning things which I would have omitted to make, that would be greater help.
Cordially Fluchers
Fluchers
Re: Adafruit 2.8" PiTFT - Capacitive Touch help for touchscr
by franklin97355 on Wed Feb 17, 2016 2:37 pm
Make sure you are using the correct install for the cap touch model from here https://learn.adafruit.com/adafruit-2-8-pitft-capacitive-touch/easy-install
franklin97355
by Fluchers on Wed Feb 17, 2016 2:55 pm
Thank you for your answer, yes I used the image Jessie which is available in the tutorial, the problem is really that all is to install but I do not have the configuration necessary in this part (https://learn.adafruit.com/adafruit-2-8 ... ouchscreen) this part of the tutorial is not effective on my raspberry. Cordially Fluchers
Fluchers
