master contrast current control of SSD 1351
loonsome1
Post by loonsome1 »
Hi there, I have purchased a OLED Breakout Board - 16-bit Color 1.5" w/microSD holder from Adafruit.
My control board is using arduino uno.
From your website, i have download the Adafruit-SSD1351-library.
The library works fine. Right now I'm trying to modify the parameter of master contrast current control of SSD1351.
In the file " Adafruit_SSD1351.h" in Adafruit-SSD1351-library, it have a define "#define SSD1351_CMD_CONTRASTMASTER 0xC7" which is using for setting master contrast current control.
If I want to modify this parameter, do anyone have suggestion about how should i modify the code?
thanks.
Dannikorsholm
Re: master contrast current control of SSD 1351
Post by Dannikorsholm »
Hi loonsome1
Did you find a way to dimmer the display??
Regards Danni.
kim2139
Post by kim2139 »
I have been trying to run the 1.27" OLED display with Simblee. But I keep getting this error message:
Arduino: 1.8.5 (Mac OS X), Board: "Simblee"
/Applications/Arduino.app/Contents/Java/portable/sketchbook/libraries/Adafruit_SSD1351_library/Adafruit_SSD1351.cpp:29:28: fatal error: wiring_private.h: No such file or directory
#include "wiring_private.h"
compilation terminated.
exit status 1
Error compiling for board Simblee.
Does any one know what the problem is?
CCat
Post by CCat »
I'm using SSD1351_CMD_CONTRASTMASTER like this (somewhere in the setup{} or loop {})
        tft.writeCommand(SSD1351_CMD_CONTRASTMASTER);
        tft.writeData(0x32);
And back to full contrast
        tft.writeData(0x0F);
But I wonder what is max and min values. :-)
0x00 - 0xFF maybe?
You may also switch display off and on:
        tft.writeCommand(SSD1351_CMD_DISPLAYOFF);
        tft.writeCommand(SSD1351_CMD_DISPLAYON);
