SemiFlex Semi-translucent Filament
by GianIsAlive on Wed Mar 02, 2016 2:37 am
Hi there. I recently purchased SemiFlex Semi-translucent Filament to print on Type A Series 1 pro. Every time when I try to print, the filament jams the extruder (motor skipping noise). I thought it's caused by false build plate set up, but no matter how many times I try, I still experience the same problem. Then I tried different color of SemiFlex and under the same setting, the print came out beautifully. Not sure what to do....
GianIsAlive
Re: SemiFlex Semi-translucent Filament
by pixil3d on Wed Mar 02, 2016 10:43 am
we have noticed darker colors require a higher temperature, try 245c with a print speed of 30-40mm/s.
thanks!
pixil3d
