🔮Adafruit sale all weekend long – use the code ADATHX for 15% off! 🔮
Analog Input Isolator
by gdoland on Fri Mar 04, 2016 3:36 pm
When you are using an Arduino to measuring analog input signals from several different sources, the ground wires are not always connected together. That is, you don't always have a common 0 volt reference. Does Adafruit have an analog input isolator so I can measure different analog values from several different battery powered devices? I would love to buy several if you do. Do you anyone that sells them?
gdoland
