🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
School project
School project
by timdrapeau on Mon Mar 07, 2016 12:01 am
We are building a small project and need help selecting the right supplies. I have attached a sketch
We will have a plastic base and 7 bamboo poles (1 inch diameter each). We would like to have each bamboo pole to have separate LED. Ideally, 6 with same color and 1 different.
I was thinking about using the NeoPixel 8mm LED's and need help with powersource and supplies. Ideally I just need a battery power source for this school project and the appropriate neopixels and holders.
Tim
school project.JPG (667.2 KiB) Viewed 260 times
timdrapeau
Re: School project
by adafruit_support_bill on Mon Mar 07, 2016 7:01 am
What do you plan to do with the LEDs? Neopixels require a microcontroller of some sort to drive them. If they will be steady-on, then discrete LEDs would simplify your circuit a bit.
Re: School project
by timdrapeau on Mon Mar 07, 2016 11:41 am
Lets keep it simple. This is for a school project and I think discrete LED's would be great. She simply needs to insert 7 discrete LED's into the bamboo columns. She iwas looking for solid colors. 6 yellow and 1 blue perhaps Let me know what would work best and I will place order today.
Also, her twin sister is looking for a multi color LED that would be used inside something like a disco ball. What sort of multi color LED and driver would work for that? She is building the object out of Polyethylene
Tim
timdrapeau
Re: School project
by adafruit_support_bill on Mon Mar 07, 2016 12:10 pm
For discrete LEDs, you would need the LEDs. Some resistors and a battery holder. You could run the whole thing from a 3xAAA battery pack.\
https://www.adafruit.com/products/771
The yellow LEDs should be wired in series with about a 220 ohm resistor to limit the current: https://www.adafruit.com/products/2780
The blue LED operates at a slightly higher voltage and needs a smaller resistor value. You can wire 2 of the 220 ohms in parallel to make a 110 ohm equivalent, then put that in series with the blue LED.
https://learn.adafruit.com/all-about-leds
For the multicolor LED project, you could use essentially the same circuit with a variety of different discrete led colors.
Or you could use some of these for some colorful flashing effects
https://www.adafruit.com/products/679
