Help with 16 Channel PWM/Servo Hat
by Hackopedia on Wed Mar 09, 2016 3:22 pm
I everytime get a exeption "I2C: wrote 0x00 to Register 0x49" and so on and it only changes the "0x49" into other figures. I use the Example code on github and followed the Instructions @ learn.adafruit.com
Thanks a lot for helping!
Hackopedia
Re: Help with 16 Channel PWM/Servo Hat
by franklin97355 on Wed Mar 09, 2016 4:50 pm
What do you get when you run i2cdetect?
franklin97355
by Hackopedia on Wed Mar 09, 2016 4:59 pm
I get the "standart" I2C output, like its shown in the tutorial.
Hackopedia
by franklin97355 on Wed Mar 09, 2016 5:30 pm
Which ports show up?
franklin97355
by Hackopedia on Thu Mar 10, 2016 1:40 am
There is shown a 40 in the 0/40 section, and a 70 in the 0/70 section.
I hope it helped...
Hackopedia
by MJPV on Thu Mar 10, 2016 5:06 pm
under the same topic as Help with etc ..
I would like to ask about powering 16 servo's.
I have an idea but would like it clarified please.
I am using micro 9g tower servos with the 16 servo/pwn board and I am having trouble powering the servos.
Up to a point about 10 servos work off my 4 x1.2v 2400mah batteries but any more and it goes eratic. The servos go to random positions and sit there. I assume this is a power issue?
I suspect I need to up the amps as each servo draws x so about 3-5a I reckon I need - what batteries would supply 6v or 4.8v with sufficient amps to power the hexpod for an hour?
I was thinking the 7.2v 3000mah bats might do the job for a shorter time but I would have to put in a regulator to take it down to 6v or 4.8 right?
If I need 5000mah and higher the batts get heavy and I@m not sure my hexpod will lift the weight,
Maybe I'm asking for idea's and confirmation of my thoughts?
Thank you,
Mike
MJPV
by Hackopedia on Thu Mar 10, 2016 5:10 pm
How did you gotta brought it to work. Mine is in holidays or what ;)
Hackopedia
by Hackopedia on Fri Mar 11, 2016 10:57 am
I maybe could identify where the problem COULD be. I tested it and it hides in the Adafruit_PWM_Servo_Driver.py at the def setPWMFreq part. But i'm not quite sure if its there. setPWM is also possible..
Hackopedia
