Adafruit 16-Channel PWM / Servo HAT Coding
Re: Adafruit 16-Channel PWM / Servo HAT Coding
by adafruit_support_bill on Sun May 15, 2016 12:59 pm
Please post the exact code you are using.
by mclemens7 on Sun May 15, 2016 3:19 pm
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
#define SERVOMIN  150 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  600 // this is the 'maximum' pulse length count (out of 4096)
// our servo # counter
uint8_t servonum = 0;
  Serial.begin(9600);
  Serial.println("16 channel Servo test!");
  pwm.begin();
  pwm.setPWMFreq(60);  // Analog servos run at ~60 Hz updates
  yield();
// you can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. its not precise!
void setServoPulse(uint8_t n, double pulse) {
  double pulselength;
  pulselength = 1000000;   // 1,000,000 us per second
  pulselength /= 60;   // 60 Hz
  Serial.print(pulselength); Serial.println(" us per period");
  pulselength /= 4096;  // 12 bits of resolution
  Serial.print(pulselength); Serial.println(" us per bit");
  pulse *= 1000;
  pulse /= pulselength;
  Serial.println(pulse);
  pwm.setPWM(n, 0, pulse);
  // Drive each servo one at a time
  Serial.println(servonum);
  for (uint16_t pulselen = SERVOMIN; pulselen < SERVOMAX; pulselen++) {
    pwm.setPWM(servonum, 0, pulselen);
  delay(500);
  for (uint16_t pulselen = SERVOMAX; pulselen > SERVOMIN; pulselen--) {
  delay(500);
  servonum ++;
  if (servonum > 7) servonum = 0;
Reason: Added code tags
mclemens7
by adafruit_support_bill on Sun May 15, 2016 5:05 pm
What do you get when you run the i2cScanner code?
http://playground.arduino.cc/Main/I2cScanner
by mclemens7 on Sun May 15, 2016 5:39 pm
so i tried it and the servo started to jitter then i stopped it. tried another code and it didnt work then i went back to the one u gave me and it didnt work
mclemens7
by franklin97355 on Sun May 15, 2016 6:08 pm
Running the scanner code should print data to the serial monitor not move the servos. What was the output of the scanner program?
franklin97355
by mclemens7 on Sun May 15, 2016 6:16 pm
I2C Device foundat address 0x40
I2C Device found at address 0x70
mclemens7
by adafruit_support_bill on Mon May 16, 2016 5:59 am
That is the correct output.
That sounds like either a power problem, or a connection problem.
Please post some close up photos showing your soldering to the front and back of the board.
by mclemens7 on Tue May 17, 2016 11:57 am
here
mclemens7
by mclemens7 on Tue May 17, 2016 11:58 am
and more
mclemens7
by mclemens7 on Tue May 17, 2016 12:01 pm
soldering side
mclemens7
by adafruit_support_bill on Tue May 17, 2016 12:24 pm
There are some possible problem joints there. Especially the servo header joints on the back side. A few appear to be cold joints and some appear not to have flowed onto the solder pads. Please have a look at this guide for some tips on fixing those: https://learn.adafruit.com/adafruit-gui ... n-problems
