New Feather Board?
- adafruit_support_rick
Re: New Feather Board?
Baffling. Sorry. I have no ideas on this. Do you have a different computer you can try?
- geekguy
Yes, baffling is and understatement. I don't have another computer, unfortunately.adafruit_support_rick wrote:Baffling. Sorry. I have no ideas on this. Do you have a different computer you can try?
8-Dale
- geekguy
I just got IDE v1.6.9 to recognize the WICED board, and can compile code for it! 8-D I did a complete reinstallation of the IDE.adafruit_support_rick wrote:Double-check that you have the right sketchbook path specified in Arduino Preferences.
8-Dale
Wow! Great news!
- geekguy
I spoke too soon. I can see the WICED board in the list of boards until I install the Adafruit SAMD boards for the Feather M0. After that, I no longer see the WICED board. This happens with both IDE v1.6.5 and v1.6.9.adafruit_support_rick wrote:Wow! Great news!
Does this sound familiar?
8-Dale
No, that doesn't sound familiar at all. You said you have a lot of boards installed? I wonder if you're running into some limit of Arduino? Maybe try removing some boards packages and see if t comes back?
- geekguy
On my fresh installs of the IDE, I only install what I need for the boards I want to work with. Those are the Feather M0 and WICED boards. I see the WICED board until I install the Adafruit SAMD boards. Then, the WICED board disappears from my boards list. This is very weird, to say the least.adafruit_support_rick wrote:You said you have a lot of boards installed? I wonder if you're running into some limit of Arduino? Maybe try removing some boards packages and see if t comes back?
8-Dale
- mariakatosvich
I can see the WICED board in the list of boards until I install the Adafruit SAMD boards for the Feather M0. After that, I no longer see the WICED board.i have the right sketchbook path specified in Arduino Preferences.
DVLA
DVLA
- ktownsend
Thanks for the additional information ... I haven't been able to reproduce this strangely, but please let me know your exact version of the Arduino IDE, the OS and version you are using (including x64 or x86 if appropriate), and the path where the WICED files are stored? Thanks!
- masonlvvy
hello,any music module recommend work with digital led strips??
Recommended for what? What are you trying to do?masonlvvy wrote:hello,any music module recommend work with digital led strips?
