Adafruit LCD + Keypad:
by ltpitt on Wed May 17, 2017 6:27 pm
Hi there!
Very happy owner of this LCD + keypad:
https://www.adafruit.com/product/1110
Since a few days, if I start it, I get this error:
import Adafruit_CharLCD as LCD
File "build/bdist.linux-armv6l/egg/Adafruit_CharLCD/__init__.py", line 1, in <module>
File "build/bdist.linux-armv6l/egg/Adafruit_CharLCD/Adafruit_CharLCD.py", line 89, in <module>
File "build/bdist.linux-armv6l/egg/Adafruit_CharLCD/Adafruit_CharLCD.py", line 95, in Adafruit_CharLCD
File "build/bdist.linux-armv6l/egg/Adafruit_GPIO/GPIO.py", line 426, in get_platform_gpio
RuntimeError: Could not determine platform.
I think this could be related to my last OS update (I use DietPi).
How can I fix the issue?
I saw on the github page that the code contained in GPIO.py simply understands if I use a Raspberry or a Beaglebone or other board.
I would like to tweak it in order to force Raspberry but...
Where is the file?
I cannot find it anywhere...
Or, clearly, if there is a better solution I'd be very happy.
Also if I can help with any diagnostic data please let me know what you need.
ltpitt
Re: Adafruit LCD + Keypad:
by adafruit_support_rick on Thu May 18, 2017 9:48 am
by ltpitt on Thu May 18, 2017 10:49 am
Hi there and thanks for the help...
I cannot find the same file in my Raspberry Pi, I've already found the online repo.
ltpitt
by adafruit_support_rick on Thu May 18, 2017 1:22 pm
cd to /usr/local/lib and enter the command find -name "GPIO.py"
by ltpitt on Fri May 19, 2017 6:39 pm
Here's the result:
HomeAssistant /usr/local # cd lib
HomeAssistant /usr/local/lib # find -name "GPIO.py"
./python3.4/dist-packages/WebIOPi-0.7.1-py3.4-linux-armv6l.egg/_webiopi/GPIO.py
And then the file is not like the online one (7 rows, not of any use...)
ltpitt
by adafruit_support_rick on Sat May 20, 2017 9:34 am
That file has a different path than the one n the error message. Try going up to /usr/local and doing the find again. If necessary, go up to /usr until you find the right path
by ltpitt on Sat May 20, 2017 11:47 am
Thanks for the new input, Rick.
Sadly the result stays the same:
HomeAssistant /usr # find -name "GPIO.py"
./local/lib/python3.4/dist-packages/WebIOPi-0.7.1-py3.4-linux-armv6l.egg/_webiopi/GPIO.py
What could be wrong?
ltpitt
by adafruit_support_rick on Sat May 20, 2017 1:27 pm
Look for the folder "build" in root and then go from there
Also try sudo find
by ltpitt on Sun May 21, 2017 6:32 am
On my specific Raspbian distro (DietPi) I just have root user.
I really do not understand what could be wrong here.
How am I supposed to install Adafruit LCD library?
Maybe I am doing errors there?
ltpitt
by adafruit_support_rick on Sun May 21, 2017 9:05 am
To install, just follow the instructions here:
https://learn.adafruit.com/adafruit-16x ... ython-code
The easiest way to get the code onto your Pi is to hook up an Ethernet cable, and clone it directly using 'git', which is installed by default on most distros. Simply run the following commands from an appropriate location (ex. "/home/pi"):
sudo apt-get update
sudo apt-get install build-essential python-dev python-smbus python-pip git
sudo pip install RPi.GPIO
git clone https://github.com/adafruit/Adafruit_Python_CharLCD.git
cd Adafruit_Python_CharLCD
sudo python setup.py install
by ltpitt on Wed May 31, 2017 3:51 am
Perfect!
I've reinstalled it using pip --force and then I was able to patch the GPIO.py
All works great now, thanks :)
ltpitt
