RMA )) Adafruit 1.44" Color TFT LCD Display with MicroSD Car
by icbanq on Mon Mar 11, 2019 3:27 am
Hi, This is Sonia
For our last order on February 25, 2019 with Order #1989272-9545001998
P/N : Adafruit 1.44" Color TFT LCD Display with MicroSD Card breakout - ST7735R PID: 2088
Q'ty : 2ea
We found it cause operation trouble. you could see on vidio showes just white screen with letters on it. (in this fourm can not add vidio, if you'd like to see it, I will send it by email)
So, pls help to check and exchange it. thank you!
icbanq
Re: RMA )) Adafruit 1.44" Color TFT LCD Display with MicroSD
by icbanq on Fri Mar 15, 2019 12:35 am
Could you pls help to advise my request?
icbanq
by franklin97355 on Fri Mar 15, 2019 1:37 am
Do both displays exhibit the same problem? Can you post a picture of the display and your connections?
franklin97355
by icbanq on Mon Mar 18, 2019 8:21 pm
Attached Connection pic as you requested. pls help to check it. Also both parts comes same problem.
icbanq
by icbanq on Wed Mar 20, 2019 8:55 pm
Could you pls help to update me for this RMA request~?
icbanq
by franklin97355 on Wed Mar 20, 2019 11:16 pm
You need to connect the RST line too. Check out the learn guide wiring and test section.
franklin97355
by icbanq on Tue Mar 26, 2019 2:36 am
Hi, we Aleady connected that line of RST~ By the way did not connected reset & light~ Pls help to advise me again for this issue~ thank you!!
icbanq
by icbanq on Wed Mar 27, 2019 8:07 pm
Hi, Attached pic even we connect the RST line~ pls check and pls help to refund it! I will watting for your update.
icbanq
by icbanq on Tue Apr 02, 2019 6:45 am
Pls help to reply this isssue~
icbanq
by franklin97355 on Tue Apr 02, 2019 12:42 pm
Set the IDE preference to verbose and post the results here. It looks like your code is not compiling correctly.
franklin97355
