Dotstar panel not working when connected
by jessgingery on Wed Sep 11, 2019 12:25 am
Im using 4 x Flexible Adafruit DotStar Matrix 16x16 parts and 2 of them are working perfectly when connected to a bluefruit.
Since we only just plugged them all together to create a scrolling sentence, we have seen that 1 of the matrix 16 x 16 panels has an LED that lights up green permanently in the bottom right corner.
Faulty LED.JPG (475.82 KiB) Viewed 146 times
Here is the youtube link: https://youtu.be/H9RI72PTj7c
The other panel is not lighting up at all when connected.
4 panels connected.JPG (388.21 KiB) Viewed 146 times
We have swapped it out into different combinations and know for sure that there is something wrong with this particular panel.
jessgingery
Re: Dotstar panel not working when connected
by dastels on Wed Sep 11, 2019 10:25 am
You should contact customer support: https://www.adafruit.com/support
dastels
by adafruit_support_carter on Fri Sep 13, 2019 4:29 pm
Did you test the panels individually before chaining them together? If not, can you backup with your wiring and somehow do that now?
by jessgingery on Sat Sep 14, 2019 1:43 pm
HI there,
I have wired each matrix panel to power via the bluefruit individually.
https://www.youtube.com/watch?v=qrnBK5FHoRY
All but three respond, the last one does not.
Thanks for reading this. Let me know what you think.
MATRIX TESTING.jpg (754.25 KiB) Viewed 100 times
jessgingery
by adafruit_support_carter on Mon Sep 16, 2019 12:50 pm
Thanks. Good set of tests.
For the one panel with the green LED - does that show up even with initial power? So no data signal from the Feather, just power to the panel. And when you are running it with the Feather, does it ever change at all?
For the non-responding panel, can you post a photo of the backside. And please try a higher resolution photo so we can see if there are any obvious hardware issues.
by jessgingery on Thu Sep 19, 2019 7:57 pm
Thank you for your response.
I have attached some higher res images of the non responding matrix panel that is not working.
As for the panel with the green LED, when running it through the feather the LED stays green. When it is connected to power without a signal it is also green.
I am in an urgent situation now and if possible would like to know if these panels can be fixed/replaced in the next 2 weeks? Can you share any more information about next steps and how this might be resolved?
I see that you are out of stock of the Dotstar matrix 16 x16 at the moment. The particular exhibit piece I am working on relies on 4 working matrix panels. If they are out of stock for the foreseeable future, would the NeoPixel matrix panels be the best alternative. Can they be connected together and be coded in a similar way and be as flexible?
Thank you
jessgingery
by adafruit_support_carter on Mon Sep 23, 2019 5:38 pm
OK - let's just replace these. All your setup seems fine and correct. So not sure why they are behaving that way. And really no easy way to fix them, esp. with not knowing the underlying issue.
NeoPixel vs. DotStar - the main tradeoff is update rate. DotStars are faster. So if you are doing something that requires a fast refresh, then take that into consideration.
In terms of stock availability, I'll let support help you with that. Send an email to support@adafruit.com with a link to this thread and your order number and they can send you 2 replacement panels. Sorry you ran into these issues. Hope the project comes together OK.
