PiOLED for Mini AdBlocker noob question
Re: PiOLED for Mini AdBlocker noob question
by millercommamatt on Fri Sep 13, 2019 1:48 pm
You can't change the brightness, but setting the display to turn on/off at given intervals or during certain hours wouldn't be hard.
millercommamatt
by adafruit_support_carter on Fri Sep 13, 2019 3:30 pm
Easiest would probably be to have the program only display the information for X amount of time and then go blank. And then use cron to run it at some regular intervals (larger than X).
by aphexx0407 on Fri Sep 13, 2019 6:54 pm
What script should I put and where should I put it? Would you point me to any tutorial or document on how to do it?
aphexx0407
by adafruit_support_carter on Fri Sep 13, 2019 7:36 pm
Actually there's probably an even easier way by just adding some blanking to the script. I've made a PR for this:
https://github.com/adafruit/Adafruit_Le ... s/pull/840
by aphexx0407 on Fri Sep 13, 2019 8:11 pm
adafruit_support_carter wrote:Actually there's probably an even easier way by just adding some blanking to the script. I've made a PR for this:
Thank you, I will check this out when I return from holiday after 3 days. I will let you know how it goes.
aphexx0407
by adafruit_support_carter on Fri Sep 13, 2019 9:46 pm
The PR has been merged. The change is very simple. It just shows the info for 10 seconds then blanks the screen for 50 seconds and repeats. You can get the updated stats.py from the repo link above or from the guide, which has also been updated.
by aphexx0407 on Fri Sep 13, 2019 10:49 pm
Will do, thank you. Will update you once I get it done.
aphexx0407
