128x32 I2C OLED not displaying
TDEAF
Post by TDEAF »
Hi. Last week i received (among other things) a 128x32 I2C OLED which today I have been trying to get working. I have soldered the 6-pin header on, wired it to my Arduino via breadboard, and tried running the example code, all as shown in the tutorial instructions. However, I cannot get the OLED to display anything. BANNED use of Serial.println statements suggest that the sketch is running and getting past the point where I should see messages/graphics, but I still don't see anything on the display. I've tried several different I2C addresses (0x3C is the default, and 0x78 and 0x7A were suggested in some old forum posts), powered the Arduino off and on, reset it, recompiled/uploaded the sketch, but all to no avail. I certainly think I have everything wired properly, as per the tutorial page, though the tutorial is a bit confusing as it sometimes says this OLED can only be used with SPI and sometimes says it can be used with I2C. (The OLED I received says it is I2C, and has the I2C SDA and SCL pins, so I've proceeded with I2C configuration. :-))
dastels
Re: 128x32 I2C OLED not displaying
Post by dastels »
These displays don't work well (or at all) unless you make use of the reset pin. The new ones with the stemma connectors auto-reset, but older ones have to be done in your code.
TDEAF
Post by TDEAF »
Is there an example of what I have to do in my code? I'm happy to do that, if I know what I have to do.
dastels
Post by dastels »
See https://learn.adafruit.com/monochrome-o ... d-examples. There's an example that got installed with the library.
TDEAF
Post by TDEAF »
Yes, I'm using that example and it doesn't work. And it doesn't show anything special about using the reset pin from within my code, other than where it is used when calling the constructor. This is why I reached out to this forum. :-)
dastels
Post by dastels »
Let's see the solder joints where you added the header.
TDEAF
Post by TDEAF »
Not a very good picture, but here one is. I suppose something could have happened with the soldering, as I'm not an expert at soldering, but all my connections have worked well on everything else I've been doing.. :-).
2019-12-03 13.12.57-1.jpg (282.83 KiB) Viewed 453 times
dastels
Post by dastels »
I don't see anything obviously wrong with your soldering.
You've double and triple checked the wiring between the arduino and the breakout? Everything agrees with what's used in the code?
TDEAF
Post by TDEAF »
Thanks for looking. :-)
Yes and yes. I am using the example code as is from "Examples" in the Arduino IDE. And have double and triple-checked the wiring diagrams in the tutorial, have tried different UNO boards, different USB cables, different connection wires... I'm baffled.
Do you know how to raise the attention of an Adafruit support person? (My apologies if you are, but it looked like another person's ID was listed as the Adafruit moderator for this area.)
dastels
Post by dastels »
It sounds like a bad board. You already have the attention required. :)
Please email [email protected] with a link to this thread, your order number, and request a replacement "Monochrome 128x32 I2C OLED graphic display".
TDEAF
Post by TDEAF »
OK. Will do. Thanks very much for you time and efforts to try to get this resolved.
dastels
Post by dastels »
No worries. I hope the replacement works without hassle. It should, they're pretty reliable.
