Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more.
Adafruit NeoPixel Digital RGB LED Strip 144 LED - 1m White -
by ductsoup on Mon Mar 23, 2020 6:14 pm
I rigged four of these up driven by a Raspberry Pi ZeroW with a level shifter. It works well and it's very pretty but ... they're not as bright (aka ouch my eye) as I expected from my experience with the neopixel sticks and matrices. Near as I can tell the leds are the same or at least similar. Wondering if it's the silicon casing. Thoughts?
ductsoup
Re: Adafruit NeoPixel Digital RGB LED Strip 144 LED - 1m Whi
by dherrada on Mon Mar 23, 2020 6:46 pm
First, did you set the brightness to max? If you did, then it's probaby because of the silicon casing. Also, what's the amperage of the power supply powering them?
dherrada
by ductsoup on Tue Mar 24, 2020 5:48 am
That's a 5V 30A power supply.
ductsoup
by Foxblade on Thu Mar 26, 2020 12:02 am
Just chiming in since I have the same strip, but is the color order RGBW or GRBW?
Foxblade
by adafruit_support_bill on Thu Mar 26, 2020 5:50 am
With the bare pixels on the sticks and matrices you are looking right at the silicon die so the light is super intense - especially when viewed on-axis. The casing does diffuse the light quite a bit, so it will appear less bright.
by ductsoup on Sat Mar 28, 2020 9:49 am
Foxblade wrote:Just chiming in since I have the same strip, but is the color order RGBW or GRBW?
Mine are GRB.
ductsoup
by ductsoup on Sat Mar 28, 2020 9:51 am
Got it, thanks. Going for super intense so I'm going to rethink how I can mount them without the silicon casing.
ductsoup
