2.8in TFT on pi 3 B+
Re: 2.8in TFT on pi 3 B+
by adafruit_support_carter on Tue Jul 07, 2020 1:46 pm
If you want just HDMI, then remove the TFT and do not use it. Simply use the Pi as normal and attach an HDMI monitor to the HDMI output. To configure HDMI settings, do some via /boot/config.txt.
If you want HDMI and TFT, then attach the TFT, run the install script from here:
https://learn.adafruit.com/adafruit-pit ... -install-2
answer NO to "Would you like the console to appear on the PiTFT display?"
answer YES to "Would you like the HDMI display to mirror to the PiTFT display?"
by hithesh123 on Tue Jul 07, 2020 2:13 pm
For HDMI only, what settings should I change in the /boot/config.txt
The default settings don't seem to work.
hithesh123
by adafruit_support_carter on Tue Jul 07, 2020 2:21 pm
It would depend on the HDMI display. The easiest thing to try first it to set hdmi_safe=1. So uncomment this line in /boot/config.txt:
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
remove the # so you get:
hdmi_safe=1
by hithesh123 on Tue Jul 07, 2020 3:23 pm
The HDMI display is adafruit 5"
No change even after uncommenting that line. I checked if the uncomment actually worked after a power cycle.
I made a video, please see if it helps -
https://youtu.be/yVk0zZabPYI
hithesh123
by adafruit_support_carter on Tue Jul 07, 2020 4:02 pm
For the Adafruit 5" HDMI display:
https://www.adafruit.com/product/2260
use the config.txt shown in the guide:
https://learn.adafruit.com/adafruit-5-8 ... -pi-config
by hithesh123 on Tue Jul 07, 2020 4:13 pm
I changed the config.txt file.
But still see a blank screen.
hithesh123
by adafruit_support_carter on Tue Jul 07, 2020 4:56 pm
Post a photo of your setup showing how everything is connected.
by hithesh123 on Tue Jul 07, 2020 6:48 pm
Here's the pic -
https://imgur.com/rKHSVpN
USB power coming from wall power supply.
hithesh123
by adafruit_support_carter on Tue Jul 07, 2020 7:14 pm
Thanks for the photo. That looks fine.
Let's double check your config.txt. Please post the entire contents of that file here.
by hithesh123 on Tue Jul 07, 2020 8:05 pm
Here's the config.txt copy/pasted -
hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (here we are forcing 800x480!)
hdmi_group=2
hdmi_mode=87
hdmi_cvt=800 480 60 6 0 0 0
hdmi_drive=1
max_usb_current=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# for more options see http://elinux.org/RPi_config.txt
hithesh123
by adafruit_support_carter on Tue Jul 07, 2020 8:11 pm
That is not the same as the one posted in the guide. Please make sure you are using that one:
It looks like all you may need to do is comment out hdmi_safe=1.
by hithesh123 on Tue Jul 07, 2020 8:19 pm
I already tried the config.txt in the link with and without commenting out hdmi_safe.
Just tried again.
Here's the paste of the config.txt
hdmi_safe=1
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
hdmi_group=2
hdmi_mode=87
hdmi_drive=1
max_usb_current=1
#hdmi_drive=2
# no display
#sdtv_mode=2
#arm_freq=800
hithesh123
by adafruit_support_carter on Tue Jul 07, 2020 8:30 pm
The line is still not commented out. Just erase your current /boot/config.txt and replace it with the contents from the guide.
by hithesh123 on Tue Jul 07, 2020 8:39 pm
I replaced the config file with the one in the link .The display is still blank.
#hdmi_safe=1
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
hdmi_group=2
hdmi_mode=87
hdmi_drive=1
max_usb_current=1
#hdmi_drive=2
# no display
#sdtv_mode=2
#arm_freq=800
hithesh123
by adafruit_support_carter on Tue Jul 07, 2020 8:42 pm
Did you reboot the Pi after making the changes?
