PiTFT Plus 2.8 Resistive Screen - Touch Issues
Re: PiTFT Plus 2.8 Resistive Screen - Touch Issues
by mikeysklar on Wed Oct 07, 2020 2:39 pm
As I understand it the display is being used by the OS and taking up the SPI device so it will not be available in the /dev tree once configured. It is this line in config.txt that is triggering the display to take SPI0.
I did see an example passing the touch components the driver in config.txt. Could you try this?
dtoverlay=pitft28-resistive,rotate=90,speed=64000000,fps=30,touch-swapxy,touch-invx
Also does the touchmouse utility work for you?
https://learn.adafruit.com/adafruit-pit ... pace-tools
cd Adafruit_Userspace_<chrome_find class="find_in_page">PiTFT</chrome_find>-master
sudo python touchmouse.py
mikeysklar
by aaaltomare on Wed Oct 07, 2020 5:11 pm
So I changed that line in the config.txt and rebooted, ran
sudo evtest /dev/input/touchscreen
and still no input.
Then I ran the python touchmouse, see output below:
pi@raspberrypi:~/Adafruit_Userspace_PiTFT-master $ sudo python touchmouse.py
Namespace(calibration=[0, 0, 4095, 4095], chip='STMPE', debug=False, outrange=[0, 0, 4095, 4095], rotation=90)
  File "touchmouse.py", line 64, in <module>
    spi.open(0, 1)
IOError: [Errno 2] No such file or directory
Exception TypeError: TypeError('super() takes at least 1 argument (0 given)',) in <bound method InputDevice.__del__ of InputDevice('/dev/input/event6')> ignored
aaaltomare
by mikeysklar on Thu Oct 08, 2020 10:51 am
@aaaltomare,
I'm slowly coming around to the complexities involved in getting /dev/spidev0.0 to show up and how all of our tools are dependent on it.
Can you try manually load the spidev kernel module?
sudo modprobe spidev
If it worked it you should see it with:
ls /dev/spidev*
and tftcp should work:
cd Adafruit_Userspace_PiTFT-master
sudo ./tftcp
If the module will not load we might need to remove ads7846 which I believe could be blocking spidev.
sudo rmmod ads7846
https://github.com/raspberrypi/linux/bl ... verlay.dts
mikeysklar
by aaaltomare on Thu Oct 08, 2020 4:29 pm
I will try this but I won't be able to get to it until a little later. In the meantime I'm wondering if you can help me understand something. Are these complications due to recent updates to the raspberry pi OS? I'm curious as to why this driver would be provided and marketed as an easy install if it weren't plug-in-play. Or is this relatedspecifically to my situation somehow?
Thanks for your help, I will get back to you in a little while once I've had a chance to test this new operation.
aaaltomare
by aaaltomare on Thu Oct 08, 2020 6:53 pm
Okay here we go:
pi@raspberrypi:/dev $ sudo modprobe -v spidev
insmod /lib/modules/5.4.51+/kernel/drivers/spi/spidev.ko
pi@raspberrypi:/dev $ ls /dev/spidev*
ls: cannot access '/dev/spidev*': No such file or directory
pi@raspberrypi:/dev $ sudo rmmod ads7846
rmmod: ERROR: Module ads7846 is not currently loaded
So spidev doesn't load into /dev/, the ads7846 overlay isn't loaded and the touchscreen doesn't work (the screen continues to work as a display, fyi).
If this is the way that the driver/overlay works why are we chasing spidev?
Thank you.
aaaltomare
by mikeysklar on Sun Oct 11, 2020 1:31 pm
I have found mixed discussions in other forums about the ads7846 driver not being needed for the resistive screens and blocking out the necessary spidev if loaded. Since several of the utilities have errored out based on not finding a /dev/spidevX device I was concerned about getting it back.
I take it you have been recreated the necessary udev rule after the fresh install to Raspbian Lite. Can you run this to confirm it is in place.
cat /etc/udev/rules.d/95-stmpe.rules
Does running the manual calibration result in any response?
sudo TSLIB_FBDEVICE=/dev/fb1 TSLIB_TSDEVICE=/dev/input/touchscreen ts_calibrate
Unfortunatley, the touchscreen portion seems to have always been a little troubled with the autoconfig script not handling everything, but we would like to resolve that.
mikeysklar
by aaaltomare on Mon Oct 12, 2020 2:50 pm
Yes, I've been checking for that rule. Here is the output of that command:
SUBSYSTEM=="input", ATTRS{name}=="*stmpe*", ENV{DEVNAME}=="*event*", SYMLINK+="input/touchscreen"
And when I run the touch calibration command you posted in your last video, I'm met with a blank screen with just a small white dash in the upper right-hand corner.
The output on the terminal reads:
pi@raspberrypi:~ $ sudo TSLIB_FBDEVICE=/dev/fb1 TSLIB_TSDEVICE=/dev/input/touchscreen ts_calibrate
xres = 320, yres = 240
HOWEVER, when I changed "/dev/fb1" to "/dev/fb0", I get this:
pi@raspberrypi:~ $ sudo TSLIB_FBDEVICE=/dev/fb0 TSLIB_TSDEVICE=/dev/input/touchscreen ts_calibrate
xres = 640, yres = 480
and then I get the touch calibration interface on the screen. it does not work, though.
Also for full disclosure, after not hearing back for a few days I tried a new install of full raspbian with a GUI to see if I could plunk away at getting this to work. I discovered changing the framebuffer brought that interface up on the last raspbian lite install I had before starting over.
aaaltomare
by mikeysklar on Tue Oct 13, 2020 6:35 pm
Okay, if your using /dev/fb0 then we might need to adjust /dev/input/touchscreen to /dev/input/touchscreen0.
When you look in /dev/input what do you see?
ls /dev/input/touchscreen*
If it is indeed touchscreen0 (or some other final numeric value) then try re-running some of the commands like evtest and ts_calibrate.
TSLIB_FBDEVICE=/dev/fb0 TSLIB_TSDEVICE=/dev/input/touchscreen0 ts_calibrate
sudo evtest /dev/input/touchscreen0
mikeysklar
by aaaltomare on Fri Oct 16, 2020 12:46 am
unfortunately there is no /dev/input/touchscreen0, simply /dev/input/touchscreen.
It was a change in the framebuffer that amounted to the programming successfully running, but without registering touch inputs
Is there a way to check to see which framebuffer the screen/touch overlay are actually using and which is being called to listen for inputs?
aaaltomare
by aaaltomare on Fri Oct 16, 2020 12:51 am
Also - I'm not sure if this is of any help or interest, but with nothing else connected to the pi, no keyboard, no mouse, etc, this is the result of running lsinput
pi@raspberrypi:~ $ lsinput
/dev/input/event0
   bustype : BUS_I2C
   vendor  : 0x0
   product : 0x0
   version : 0
   phys    : "stmpe-ts/input0"
   bits ev : EV_SYN EV_KEY EV_ABS
aaaltomare
by mikeysklar on Sat Oct 17, 2020 5:19 pm
Just grabbing at straws here since the device tree names are all over the place.
Can /dev/input/event0 or /dev/stmpe-ts/input0 be used:
TSLIB_FBDEVICE=/dev/fb0 TSLIB_TSDEVICE=/dev/input/event0 ts_calibrate xres = 640, yres = 480
TSLIB_FBDEVICE=/dev/fb0 TSLIB_TSDEVICE=/dev/stmpe-ts/input0 ts_calibrate
mikeysklar
by aaaltomare on Sun Oct 18, 2020 9:52 pm
Hey sorry for the delay on this, the results of:
are the same as before, it displays the target for the calibration but registers no touch input.
The other command gives me an error:
pi@raspberrypi:~ $ sudo TSLIB_FBDEVCE=/dev/fb0 TSLIB_TSDEVICE=/dev/stmpe-ts/input0 ts_calibrate xres = 640, yres = 480
ts_setup: No such file or directory
I'm wondering, do you have one of these touchscreens and a pi near you? I'd be curious to know if you are having the same kind of difficulty setting this up. I've spoken with other who have one and have had very few issues, let alone weeks of troubleshooting. Thanks for your help thus far, I'd really love it if we could get this thing working.
aaaltomare
by mikeysklar on Mon Oct 19, 2020 11:25 am
@aaaltomare,
It is starting to look like we are looking for the touchscreen on the device name. Is it event0 or event2? Can you try running evtest with no args and see if it outputs a list of devices found and their corresponding inputs?
I don't have a PiTFT 2.8" on hand or I would set it up myself.
Also it might be necessary to not use sudo in front of your testing as it could be dropping the EXPORT libraries when switching to root. Either run the commands as root or yourself if permissions allow it.
Does this command work when you walk through the different event# devices?
export TSLIB_TSDEVICE=/dev/input/event0
ts_uinput -d -v
mikeysklar
by aaaltomare on Wed Oct 21, 2020 4:12 pm
So the touchscreen is definitely registered to event0
pi@raspberrypi:~ $ evtest
No device specified, trying to scan all of /dev/input/event*
Not running as root, no devices may be available.
Available devices:
/dev/input/event0:   stmpe-ts
/dev/input/event1:   ts_uinput
/dev/input/event2:   ts_uinput
/dev/input/event3:   ts_uinput
Select the device event number [0-3]: 0
Input driver version is 1.0.1
Input device ID: bus 0x18 vendor 0x0 product 0x0 version 0x0
Input device name: "stmpe-ts"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 330 (BTN_TOUCH)
  Event type 3 (EV_ABS)
    Event code 0 (ABS_X)
      Value      0
      Min        0
      Max     4095
    Event code 1 (ABS_Y)
      Value      0
      Min        0
      Max     4095
    Event code 24 (ABS_PRESSURE)
      Value      0
      Min        0
      Max      255
Properties:
Testing ... (interrupt to exit)
running that command that you had given at the end of your last inquiry a few times, no understanding what it did at first has now generated 3 new events, event 1-3, all with the device "ts-uinput." These were not present before this.
trying with and without sudo still registered no touchscreen input.
I'm starting to think it's time to start fresh here. We know that the driver was installed, we know the screen itself is operating on fb0 and is outputting a video, it's the touchscreen overlay that is giving us headaches.
A few questions/thoughts:
Is there a specific build of raspbian that you knew for certain this screen was working on? I would be willing to download that and try it and then begin troubleshooting again.
Is there a possibility that this screen's touchscreen function is damaged or broken in some way? Would this behavior exhibited here be a symptom of an improperly functioning touchscreen panel?
We are now on what, week 2 of troubleshooting this? When do we approach the possibility that we are dealing with faulty hardware?
aaaltomare
by aaaltomare on Fri Oct 23, 2020 12:09 am
looking through the forums today, I noticed something. The install instructions/script for the PiTFT screens has been updated! I was EXCITED.
So I installed a fresh new image (the august2020 recommended on the installation) and installed it to an SD card.
I installed a full image as the end goal for this device would be to have some kind of desktop environment.
I followed all the instructions, rebooted and no touch.
rebooted again (just for good measure) and still no interactivity via the touchscreen.
THE DREAD BEGAN SETTING AGAIN.
Any additional advice here?
aaaltomare
