2345 no function
2345 no function
by autobotic on Mon Mar 29, 2021 12:31 am
Order Number is 2478703-7242541635
Date: February 3, 2021
PID: 2345
Issue: We are tested with raspberry pi 3b+ with jumper wires, and a 32x32 RGB LED Matrix Panel, the panel doesn't light up. Does the panel faulty?
Link: https://drive.google.com/file/d/197igZT ... sp=sharing
autobotic
Re: 2345 no function
by autobotic on Tue Mar 30, 2021 12:16 am
Update:
Recently, we have done the second test for PID: 2345. I found that is the RGB Matrix HAT + RTC caused the problem.
I have changed the RGB Matrix HAT + RTC board, same configuration, and set up as Unit 1, it works.
Unit 2 ( second test): https://drive.google.com/file/d/1rTc8E_ ... sp=sharing
Could we get the warranty claim for the board?
autobotic
by adafruit_support_carter on Tue Mar 30, 2021 11:36 am
Please post a photo of your soldering job on the headers pins for the first HAT.
Why are you using jumper cables vs. attaching the HAT directly to the Pi?
by autobotic on Tue Mar 30, 2021 9:55 pm
Thank you for the reply.
The link below is the picture for the soldering job on the headers pins for the first HAT by the customer.
https://drive.google.com/file/d/158zzFu ... sp=sharing
Thank you.
autobotic
by adafruit_support_carter on Wed Mar 31, 2021 12:05 pm
Please flip the HAT over and take another photo. The soldering in question is on the opposite side shown. Thanks.
by autobotic on Wed Apr 14, 2021 12:53 am
autobotic
by autobotic on Wed Apr 21, 2021 1:24 am
There has any update for this ticket?
Thank you.
autobotic
by adafruit_support_carter on Wed Apr 21, 2021 11:09 am
The photos are a little out of focus, but it does look like soldering may be an issue. Please see here for common soldering issues:
https://learn.adafruit.com/adafruit-gui ... n-problems
Try inspecting all the pins and reflowing any that may seem cold soldered or insufficiently wetted out on the pads.
by autobotic on Fri Apr 23, 2021 4:12 am
All pins inspected and completed the reflowing process.
Results remaining the same. Please refer to the videos provided
Video 1: https://drive.google.com/file/d/1-CI6rZ ... sp=sharing
Video 2: https://drive.google.com/file/d/1XO_Y3t ... sp=sharing
Thank you.
autobotic
by adafruit_support_carter on Fri Apr 23, 2021 3:35 pm
What is the "Unit 1" here that works?
Try connecting the HAT directly to the Pin instead of through this ribbon cable.
by autobotic on Wed Apr 28, 2021 12:48 am
Resoldering all the pins.
Still did not function well.
For more information please refer to https://drive.google.com/file/d/1ScuS-T ... sp=sharing
Thank you.
autobotic
by adafruit_support_carter on Wed Apr 28, 2021 10:25 am
by autobotic on Thu Apr 29, 2021 10:38 pm
Sorry for the information that misleads you.
On that days, I have replaced a new RGB Matrix HAT + RTC board , I configure it the same as the configuration with Unit 1. The new RGB Matrix HAT + RTC board function well.
autobotic
by adafruit_support_carter on Fri Apr 30, 2021 10:01 am
Is the only difference between Unit 1 and Unit 2 the Matrix HAT? All other hardware is the same? Same Pi, cables, matrix, etc.
If you haven't tried that test yet, please do. That will help narrow it down to the HAT or something else.
by autobotic on Tue May 04, 2021 1:22 am
Yes, the only difference between Unit 1 and Unit 2 is the Matrix HAT. All others hardware is the same.
We already tried the test, but unable to get the result.
autobotic
