NeoPixel Digital RGBW LED Strip Showing Incorrect Colors
by schofe on Wed Jun 16, 2021 12:29 pm
Order #: 2585465-2588372764
Product: NeoPixel Digital RGBW LED Strip 60 LED/m [ID:2837]
Purchased: 6/21
I am having trouble with a recently purchased LED strip. It powers up and accepts new programs but only 1/3 of the LEDs display correctly.
In the below pictures all pixels on the strip and board should be purple. Only every third LED seems to be working properly. So #1, #4, #7, #10 are correct and the do not change correctly. I have tried another strip and board and everything works fine. I am probably missing something incredibly obvious, so any help is appreciated.
LED strip
Screen Shot 2021-06-16 at 11.18.35 AM.png (730.57 KiB) Viewed 93 times
Board and connections
schofe
Re: NeoPixel Digital RGBW LED Strip Showing Incorrect Colors
by franklin97355 on Wed Jun 16, 2021 12:32 pm
Make sure you are using the correct RGBW code. The strip takes 4 sets of data and the RGB code only sends 3.
franklin97355
by schofe on Wed Jun 16, 2021 1:14 pm
All solved, thank you for the help.
schofe
