1.44 TFT display integration with audrino maker 1500
dkanday
Post by dkanday »
I am trying to integrate the audrino maker 1500NB with 1.44TFT display but it seems to be that the example code: graphictest doesnt work with it. I used the same display with audrino uno and it worked fine. I followed all the wiring from this link: https://learn.adafruit.com/adafruit-1-4 ... g-and-test
I modified the code to use pin 7 on the maker to act as the CS pin but that did not help.
Is there something that I could have missed?
Thanks in advance for the help!
blnkjns
Re: 1.44 TFT display integration with audrino maker 1500
Post by blnkjns »
You use the hardware SPI pins? Pin 8,9,10.
dkanday
Post by dkanday »
Yes I tried using them but the display did not do anything other than turning on and a white screen
dkanday
Post by dkanday »
sorry I was initializing the pins incorrectly in code. Fixed that and it worked.
dkanday
Post by dkanday »
How can I rotate the font on the display? I was looking at the examples and didnt find anything. I want to rotate it by 90 degree.
I tried setRotation() and added an angle in the brackets. but that did not help.
dkanday
Post by dkanday »
Sorry, I figured it out. I was supposed to configure that in void tftPrintTest().
