Connect multiple 2.8" TFT Touch Shield for Arduino
james219
Post by james219 »
Is it possible to connect 3 or 4 2.8" TFT Touch Shields to a single Arduino Uno?
dastels
Re: Connect multiple 2.8" TFT Touch Shield for Arduino
Post by dastels »
In theory, possibly. In practice it's likely not the best approach.
Each TFT would need dedicated CS, DC, and backlite pins (connected to #10, #9, and #3), and each resistive touch controller would need a dedicated CS pin (connected to #8). The capacitive touch is harder since it's I2C and each would need a separate address and that doesn't seem possible so you'd have to use an I2C multiplexor such as https://learn.adafruit.com/adafruit-tca ... r-breakout. Interrupts from the touch controllers would have to be dealt with. If it's open-collector then you could connect them together and poll the controllers when one of them interrupts. If it's not open-collector you'll need to combine them with a big AND gate.
A completely different consideration is whether the UNO has enough power and memory to support multiple displays.
