WCMCU2812B (WS2812B) on UP2 Board
by noobie on Wed Sep 22, 2021 7:45 am
I have 3 Neopixel LED rings that have 12, 16 and 24 LEDs and I was using Arduino for programming. But now, I have a duty to recode everything on the UP2 board since it is the one that is going to be used in the project. I did some research and here are my problems.
    I guess, strict timing restrictions on the neopixels can cause some problems on the UP2 board. I guess there are some solutions like using SPI. But I am fairly new to programming and I don't know anything about SPI or UPboard. So I don't know how to implement this solution. For ex. I saw this library; https://github.com/adafruit/Adafruit_CircuitPython_NeoPixel_SPI But I don't know if it's applicable to UP2 or not, and if so; how?
    If any of you have tried to use neopixel led rings on the UP2 board, can you share a guideline? For a real beginner..
noobie
Re: WCMCU2812B (WS2812B) on UP2 Board
by mikeysklar on Wed Sep 22, 2021 7:19 pm
Sorry. Can you clarify which device the UP2 board is?
mikeysklar
by noobie on Thu Sep 23, 2021 1:10 am
noobie
by mikeysklar on Thu Sep 23, 2021 2:58 pm
It looks like you have made your way into uncharted waters. There be dragons here. You are off the map.
Looking at Adafruit Blinka I don't see any sign of support for the Up Squared board as of now. I think you might need some of these libraries to make things go. You could play with the NeoPixel SPI library, but I suspect it will have some dependencies.
If you were allowed to use your Arduino with the UP2 that would make things a lot easier for you.
We do have one guide which might help if you must use the UP2 for everything.
https://learn.adafruit.com/adding-a-sin ... -to-blinka
mikeysklar
