problem with combinartoin of Pi 0 case and mini-pitft displa
by FranTaylor on Tue Jan 19, 2021 2:07 pm
If you use the adafruit mini PITFT display on a Raspberry Pi Zero with the adafruit pi zero case, the bottom left plastic nut for the case interferes with the qwiic connector, I have to remove the plastic nut so that I can plug something into the qwiic connector. This is all adafruit stuff and we naturally assume that it will all play well together. It would work fine with a smaller nut.
FranTaylor
Re: problem with combinartoin of Pi 0 case and mini-pitft di
by mikeysklar on Wed Jan 20, 2021 7:55 pm
@FranTaylor,
Can you post a photo of the friction point at the QWIIC connector?
I'm wondering if it makes sense to add a 2x20 stacking header to lift the display a little higher.
https://www.adafruit.com/?q=gpio+2x20+s ... =BestMatch
mikeysklar
by stevezero on Wed Sep 22, 2021 3:46 pm
I believe I am having the same issue. I purchased the Pi-Hole Zero kit (PID 4475) and the Mini PiTFT won't fit with the top of the included case.
QWIIC connector touching clear case top
maximum pin coverage with clear case top
stevezero
by mikeysklar on Wed Sep 22, 2021 4:21 pm
Nice photos.
I see that the Pi Zero clear cover would need to be removed for the display to be used due to the QWIIC connector.
I'll ask engineering if they have any suggestions.
mikeysklar
by adafruit2 on Wed Sep 22, 2021 4:36 pm
this fits just fine, you can see the header is connecting into the display socket. is the display not showing up?
adafruit2
Site Admin
by stevezero on Thu Sep 23, 2021 9:47 am
The display powered but would not refresh/the button did not change function. I can try reseating it again.
stevezero
by adafruit2 on Thu Sep 23, 2021 10:23 am
sure, make sure its seated - how / what did you run to install support?
adafruit2
Site Admin
by MakerMelissa on Thu Sep 23, 2021 11:11 am
Hi, there's a few possibilities.
First, the display should be working even at that angle. You can try removing the clear cover and see if that makes a difference. If it does, you can either leave it removed or add an extension such as https://www.adafruit.com/product/2243.
If it still doesn't work, make sure everything is updated on the pi and maybe reinstall the driver for it. There were some updates earlier in the year that would cause the display to not refresh. You may just want to even do a fresh reinstall on an SD card.
Melissa
MakerMelissa
