It's Holiday Sale Weekend at Adafruit - use the code ADATY to get 15% off items storewide! Some restrictions apply.
miniPiTFT 240x135 backlight works but does not display data
Re: miniPiTFT 240x135 backlight works but does not display d
by dinglebox on Tue Mar 23, 2021 3:08 pm
mikeysklar - I will start a new thread, thank you.
lysynski - I do have both of those enabled
dinglebox
by rsuryase on Fri Oct 01, 2021 11:03 pm
lysynski wrote:I'm having a similar problem but different message: it looks like a module is missing - any thoughts? Thanks for the help.
me@pihole: ~ $ sudo python3 ~pi/stats.py
  File "/home/pi/stats.py", line 16, in <module>
    import adafruit_rgb_display.st7789 as st7789
ModuleNotFoundError: No module named 'adafruit_rgb_display'
I have this same problem so I use this code to get a console display instead. How do I get the Pi-Hole stats display? I've enabled SPI and I2C.
cd ~
sudo pip3 install --upgrade adafruit-python-shell click
sudo apt-get install -y git
git clone https://github.com/adafruit/Raspberry-Pi-Installer-Scripts.git
cd Raspberry-Pi-Installer-Scripts
sudo python3 adafruit-pitft.py --display=st7789_240x135 --rotation=270 --install-type=console
rsuryase
by rsuryase on Fri Oct 01, 2021 11:48 pm
lysynski wrote:The kernel driver wasn't installed I did your Python Setup as shown on your site. Regardless I ran the installer without parameters and got the following
sudo pip3 install
ERROR: You must give at least one requirement to install (see "pip help install")
unless you meant this
install
install: missing file operand
Try 'install --help' for more information
either way it didn't work. Any other ideas? Thanks for the help.
What code to use to uninstall kernel driver?
rsuryase
by jjaguirre394 on Sat Oct 23, 2021 11:07 pm
For anyone still seeing these issues like I was after following the python setup instructions here: https://learn.adafruit.com/adafruit-min ... thon-setup.
I had to run all of these commands with "sudo" so that they were installed system-wide.
Specifically:
sudo pip3 install adafruit-circuitpython-rgb-display
sudo pip3 install --upgrade --force-reinstall spidev
jjaguirre394
