AnimationGroup Same NeoPixel Strip Odd vs Even
adafruitguy
Post by adafruitguy »
The CircuitPython examples in AnimationGroups show two separate pixel objects as: Circuit Playground built-in and a NeoPixel strip.
https://learn.adafruit.com/circuitpytho ... tion-group
What if I wanted to run an AnimationGroup across the 1). odd and 2). even pixels of the same NeoPixel strip?
ie Sparkle or SparklePulse with orange on the odd, and purple on the evens?
Anyone have any hints?
mikeysklar
Re: AnimationGroup Same NeoPixel Strip Odd vs Even
Post by mikeysklar »
The adafruit_led_animation library is not going to allow the AnimationGroup to break into odd / even numbered NeoPixels. You will limited to using entire pixel_objects (NeoPixel strips, rings, CP built-ins).
You could look into Pixel Mapping as a way to get finer control within a strip. This is really meant more for arrays and I don't see it integrating with sparkle / sparkleplus.
https://learn.adafruit.com/circuitpytho ... el-mapping
