So I bought these assuming that they would work together but I'm having a hell of a time getting the top on and it seems to me that the PyPortal Titano is slightly different than the board pictured in the instructions and the three connectors on the right (top as pictured) are in a different position. Am I losing it?
https://www.adafruit.com/product/4146
Adafruit PyPortal Desktop Stand Enclosure Kit PID: 4146
https://www.adafruit.com/product/4444
Adafruit PyPortal Titano PID: 4444
PyPortal stand
- adafruit_support_carter
Re: PyPortal stand
Sorry for the confusion. There are three different PyPortal products:
The PID 4146 is only for the original PyPortal product.
- rayhayes
Re: PyPortal stand
Thanks. Yes that could have been a bit clearer. It's fixable though with a bit of plastic removal.
Ray
Ray
Re: PyPortal stand
I agree. I've sent word to have the product page updated. The Titano and Pynt came out after that stand and the original PyPortal came out, so it was probably never re-visited.
Sorry again for the confusion.
- rayhayes
Re: PyPortal stand
I worked through the original NASA demo from learn.adafruit.com/pyportal-nasa-image-viewer/code-pyportal-nasa-image-viewer which I'm guessing was also designed for the original. It does work though it's offset and smaller than it could be. I don't think the code is provided or perhaps it's obfuscated. Is there any way that you could release a PyPortal Titano version of it?
Thanks,
Ray
Thanks,
Ray
Re: PyPortal stand
The screen resolutions for the PyPortals are:
to this:
and see if that at least gets you a full screen image. The text placements may need to additional tweaking.
The code listing is on this page:
https://learn.adafruit.com/pyportal-nas ... age-viewer
and is also available here:
https://github.com/adafruit/Adafruit_Le ... SA/code.py
- Original and Pynt = 240 x 320
- Titano = 320 x 480
image_resize=(320, 240),
image_resize=(480, 320),
- rayhayes
Re: PyPortal stand
It does make the image larger but the position stays the same. I'll see if there's a place in the code where it's set but I don't remember seeing it.
Ray
Ray
- rayhayes
Re: PyPortal stand
Is it possible the code for the include module that does the display is online in git somewhere as Python?
Ray
Ray
Re: PyPortal stand
The PyPortal libary is here:
https://github.com/adafruit/Adafruit_Ci ... n_PyPortal
It relies on this base library:
https://github.com/adafruit/Adafruit_Ci ... PortalBase
- rayhayes
Re: PyPortal stand
I'm getting back to trying to get this to work. I'm running all the default code but I'm seeing the same behavior as this: viewtopic.php?f=60&t=173296&p=845113&hi ... ds#p845113
Everything is backwards. Was a solution found eventually to this issue?
Ray
Ray
Re: PyPortal stand
Sorry for the delay. Wanted to update the Titano guide to add a self test UF2. It's now added and available here:
https://learn.adafruit.com/adafruit-pyp ... duino-test
Try that and see if the display still looks odd.
To use: download PyPortal_Titano_Self_Test.UF2 (green button). Double click reset on Titano to get BOOT folder. Drag UF2 to BOOT folder. That's it!
You don't need Arduino installed.
