Due to high demand and inclement weather, expect some shipping delays at this time, orders may not ship for 4-5 business days.
is31fl3731 With Pimoroni Led Shim
by Toldcodger on Tue Nov 30, 2021 6:23 pm
I’m trying to get the CircuitPython is31fl3731 LedShim Rainbow example to run on a Pico.
I get various error such as SDA not defined and No pull-up resistors found. I added a2.2k resistor to the sda and scl lines but it made no difference.
I am using GP0 and GP1
Toldcodger
Re: is31fl3731 With Pimoroni Led Shim
by mikeysklar on Thu Dec 02, 2021 7:33 pm
Post your code and errors in CODE blocks please.
This sounds like you need to modify the Pico specific pins naming conventions.
https://learn.adafruit.com/getting-star ... on/pinouts
mikeysklar
by Toldcodger on Fri Dec 03, 2021 4:28 pm
Thanks for the response.
i started by using the is31fl3731_ledshim_rainbow.py script from the circuitpython examples folder. That's when I got the SCL not defined error. I did a little digging and found this,
Basically it says;
import board
i2c = board.I2C() # Does not work on the Pico.
Try this
import board
import busio
i2c = busio.I2C(scl=board.GP1, sda=board.GP0)
I've attached the file I modified. The original file is identical apart from this line:
i2c = busio.I2C(board.SCL, board.SDA)
(1.13 KiB) Downloaded 3 times
Toldcodger
by Toldcodger on Fri Dec 03, 2021 4:38 pm
Sorry,
I forgot to show the full error:
File "<stdin>", line 9, in <module>
RuntimeError: No pull up found on SDA or SCL; check your wiring
Toldcodger
by mikeysklar on Sat Dec 04, 2021 7:09 pm
Yep, you got the right syntax now for the i2c pins.
Can you post a photo of how you have connected the SHIM to the Pico? It seems like it might not be connected to the proper pins.
mikeysklar
by Toldcodger on Sun Dec 05, 2021 7:39 am
I’ve added a photo of the ledshim and Pico. The photo shows it set for 5v but i’ve tried it with 3.3 with the same results.
The ledshim is on a double row of pins as it would be on a RPi. I’ve checked for continuity and cross connections, everything is fine.
As the shim literally slots on the gpio pins, I’m wondering if it’s just a poor connection. When my Grandson goes home I’ll try soldering the connections on the ledshim.
Toldcodger
by mikeysklar on Sun Dec 05, 2021 3:24 pm
I have not seen anyone try to use the LED shim with a pico only a Raspberry Pi based board, but it's i2c so should be possible.
You will want to keep the voltage at 3v3 to avoid damaging your Pico.
You posted an image of a Raspberry Pi pinout, but you are using a Pico Pi which is not the same.
At this point I'm going to refer you over to the Pimoroni forums as they support the usage of their hardware.
http://forums.pimoroni.com/
Screen Shot 2021-12-05 at 11.20.50 AM.png (177.31 KiB) Viewed 111 times
mikeysklar
by Toldcodger on Sun Dec 05, 2021 4:49 pm
Thanks for your assistance mikeysklar.
I posted the pinouts for the ledshim to show that I had taken the correct connections for the sda & scl connections.
I found some code on the Adafruit site to get the I2C address. That doesn’t work either and comes back with an I2C not defined error. I have used an I2C display on the GP0 & GP1 pins so I will try that again tomorrow to prove those pins work. I’ll try the I2C detector code too.
I tried to get a Pimoroni Blinkt working on the Pico. The problem with that is getting a 102apa library for either micropython or circuitpython. Someone on there said I needed to use 3.3v. Another responder said the Raspberry Pi is 3.3 logic and the Blinkt works OK on the Pi so 5v won’t cause a problem on the Pico. I presumed the LEDshim would be the same. I have tried using 3.3v but got the same errors.
Toldcodger
by mikeysklar on Mon Dec 06, 2021 5:30 pm
@Toldcodger,
You need to start a thread with Pimoroni on connecting a Pico with their LED Shim. Pimoroni handles their own hardware support.
The Pico is not 5v tolerant on the i2c pins so 5v is a bad idea. Keep it 3v3.
mikeysklar
