Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days.
NeoPixel Triple-Ring- Not Lighting UP
by Rjwolf89 on Thu Dec 09, 2021 1:58 am
Here is a photo the board powered on but the neopixels are not lighting up
I purchased 2 neopixel triple-rings for my Rezz-Inspired NeoPixel Glasses project. I have connect everything and the neopixels are not lighting up
Please Help!
Rjwolf89
Re: NeoPixel Triple-Ring- Not Lighting UP
by dastels on Thu Dec 09, 2021 9:36 am
How have you connected them? What is their power connection wired to? What's the controller? Did you test them individually?
dastels
by Rjwolf89 on Thu Dec 09, 2021 4:33 pm
I have it connected just like in the diagram from the rezz glasses how to page
https://learn.adafruit.com/rezz-inspire ... it-diagram
I have tested each ring individually but nothing
Rjwolf89
by dastels on Thu Dec 09, 2021 4:44 pm
I understand that's the way it should be connected. Does your wiring agree with it?
How did you test them individually?
The battery is charged? The switch is "on"?
dastels
by Rjwolf89 on Thu Dec 09, 2021 5:26 pm
Yes and I have double checked the connections And solder point are all good.
I have tested it with out connecting the switch and board does turn on but the rings do not. I have tested by just connecting to the voltage and ground on the rings
Rjwolf89
by dastels on Thu Dec 09, 2021 7:30 pm
They're neopixels... connecting power and ground do nothing with sending them a correct data signal. See https://learn.adafruit.com/adafruit-neopixel-uberguide. In retrospect, that might be the problem all along.
dastels
by Rjwolf89 on Sun Dec 12, 2021 4:21 am
Followed the guide you listed but I was not able to get the lights to power on.
I did also tried using SP107E Controller that works off a 5v and connected to the Neopixels and still was not able them to power on
and I did also try them separately as well as in a daisy chain with no luck
Rjwolf89
by dastels on Sun Dec 12, 2021 2:23 pm
Can you post a clear photo of your actual, physical wiring & connections?
dastels
by Rjwolf89 on Sun Dec 12, 2021 7:12 pm
Here’s a link to all my connections as if I resize the photos any smaller. It will become unseeable
https://imgur.com/a/M6LFd0n
Rjwolf89
by dastels on Sun Dec 12, 2021 7:38 pm
My first step would be to tidy the soldering, with less bare wire visible that could cause shorts and cleaner joints. See https://learn.adafruit.com/adafruit-guide-excellent-soldering and https://learn.adafruit.com/collins-lab-soldering for tips/advice.
dastels
by Rjwolf89 on Sun Dec 12, 2021 9:35 pm
I just did those connections quickly to show you them. But thanks for the tip about that
Rjwolf89
by Rjwolf89 on Thu Dec 16, 2021 9:22 pm
At this point I would just like a refund on these two neopixels
Rjwolf89
by dastels on Thu Dec 16, 2021 9:49 pm
Let's see if a new set fixes it. Please email support@adafruit.com with a link to this thread, your order number, and request the replacement of two NeoPixel Triple Rings.
dastels
