Due to high demand, expect some shipping delays at this time - orders may not ship for up to 2-3 business days.
Neopixel 16 Ring Arduino Sketch Help
by andale on Fri Jan 21, 2022 8:11 pm
I want to fade in to blue like I currently have but have it pause and not restart the loop.
How do I do this?
#define PIN 4
Adafruit_NeoPixel strip = Adafruit_NeoPixel(16, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.show(); // initialize all pixels to "off"
  brighten();
  //darken();
// 0 to 255
void brighten() {
  uint16_t i, j;
    for (j = 0; j < 255; j++) {
    for (i = 0; i < strip.numPixels(); i++) {
      strip.setPixelColor(i, 0, 0, j);
    strip.show();
    delay(10);
Last edited by adafruit_support_bill on Fri Jan 21, 2022 8:19 pm, edited 1 time in total.
Reason: Please use [code] tags when posting code to the forums.
andale
Re: Neopixel 16 Ring Arduino Sketch Help
by adafruit_support_bill on Fri Jan 21, 2022 8:20 pm
Move the contents of your loop() function to your startup() function. Startup only runs once.
by andale on Fri Jan 21, 2022 8:28 pm
Thanks for the prompt reply.
Would this be able to be called per sensor behavior?
I need to call the fade to blue when triggered and when "released" it will call another lighting mode.
andale
by adafruit_support_bill on Fri Jan 21, 2022 9:05 pm
Your post and your code do not refer to any sensors. What sensors do you have and how are they connected? Please define specifically how you want the system to respond to the sensor input.
by andale on Fri Jan 21, 2022 10:31 pm
Thanks again for your reply.
Alright, below is the current code I have so far, incomplete as I am still figuring it out.
I am using the sonic HC-SR04 sensor.
ULTIMATE GOAL the project will work that 8 LED diodes and the Adafruit Neopixel Ring 16 will be fully lit, static, when the sensor is "undisturbed". When it senses a minimum distance of 36 inches - it calls the rainbow function from the strandtest PLUS (not currently in my code) randomly blink the 8 LED diodes. Then, when the distance is once again "cleared" all lighting components (8 LEDS and NeoPixel Ring) elegantly fade back to static.
// Adafruit Pixel Ring
#ifdef __AVR__
#endif
#define LED_PIN 4
#define LED_COUNT 16
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
// Ultrasoninc Sensor HC-SR04
const int trigPin = 12;
const int echoPin = 11;
long duration, inches;
// LEDs info here
//Neopixel dataPin
strip.begin();           // INITIALIZE NeoPixel strip object (REQUIRED)
strip.show();            // Turn OFF all pixels ASAP
strip.setBrightness(50); // Set BRIGHTNESS to about 1/5 (max = 255)
//Serial Port
Serial.begin(9600);
void loop(){
// Ultrasoninc Sensor HC-SR04 calculate distance
  pinMode (trigPin, OUTPUT);
  digitalWrite(trigPin, LOW);
  delayMicroseconds (2);
  digitalWrite (trigPin,HIGH);
  delayMicroseconds (10);
  digitalWrite (trigPin, LOW);
  pinMode (echoPin, INPUT);
  noInterrupts();
  duration = pulseIn (echoPin, HIGH);
  interrupts();
   inches = microsecondsToInches(duration);
   Serial.print(inches);
   Serial.print("in, ");
   Serial.println();
   delay(20);
  if (inches > 36) {
    colorWipe(strip.Color(  0,   0, 255), 50); // Blue;
  else {
    rainbow (1);
//Variable for Inches Conversion
long microsecondsToInches(long microseconds) {
   return microseconds / 74 / 2;
//Color wheel
void rainbow (int wait) {
  for(long firstPixelHue = 0; firstPixelHue < 5*65536; firstPixelHue += 256) {
    strip.rainbow(firstPixelHue);
    strip.show(); // Update strip with new contents
    delay(wait);  // Pause for a moment
// Fill strip pixels Blue
void colorWipe(uint32_t color, int wait) {
  for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
    strip.setPixelColor(i, color);         //  Set pixel's color (in RAM)
    strip.show();                          //  Update strip to match
andale
by adafruit_support_bill on Fri Jan 21, 2022 10:39 pm
the first thing to do is to verify that the code you have so far works. If everything is connected properly, I'd expect it to show the rainbow if the distance is <36" and show blue if it is more. If hat is working, then we can look into how to achieve the fade.
by andale on Fri Jan 21, 2022 10:59 pm
Yes, I've confirmed that works before requesting help. I've been stuck since achieving this. I tried uploading a .mov to demonstrate in action but wasn't able to "The extension mov is not allowed".
andale
by adafruit_support_bill on Sat Jan 22, 2022 7:54 am
What you need to add now is some state information to store the current state of your ring. this should be declared at global scope so that it persists between iterations of your loop:
enum RingState { Startup, Rainbow, Fading, Blue };  // all possible states of the ring
RingState state = Startup; // initial state
int fadeLevel = 0; // initial fade level
Then in your code, you can use the stored state information something like this:
   if (inches > 36)
      if (state == Rainbow) // start the fade
         state = Fading;
      if (state == Fading) // increase fade level one notch
         colorWipe(strip.Color(  0,   0, ++fadeLevel), 50); // Blue;
         if (fadeLevel == 255)
            state = Blue; // we are done
   else
      rainbow (1);
      state = Rainbow;
      fadeLevel = 0;
by andale on Sat Jan 22, 2022 10:20 am
Thanks much for the recommendation. It works but:
(1) the ring is off until the sensor is interrupted. When the program loads the initial state of the ring should be full 255 blue, and LEDs full on.
(2) the fade is now extremely slow, first going to a full state of OFF for a long time, turning on in sequential ring with not all leds at the same time, and stepping up to full blue in a jagged fashion.
The fade should behave as in the first example I sent where ALL the leds fade up smoothly. I've attempted the strip.fill from Uberguide and I just can't get it to work. I would also not mind a cross fade from one state to the next but have not been able to figure that out either.
Thanks again.
andale
by adafruit_support_bill on Sat Jan 22, 2022 10:31 am
1) Just add code to do that in your startup. Then set state = Blue.
2) Decrease the time parameter you are using in your colorWipe. You can also move the 'show();' command outside of the 'for' loop.
by andale on Sat Jan 22, 2022 11:17 am
Thx so much for your suggestions.
I did that, and set the state to Blue. I think that the enum setup distorts what blue is though. Once I did that it just remains on rainbow static and then official rainbow when sensor triggered.
I'm trying to figure out how is it that this code found in the strandtest does change the colors to blue and stop, and how your suggestion does that as well in order to replicate it:
void colorWipe(uint32_t color, int wait=10) {
I'll play with this new info for a while and post whatever I can figure out. I very much appreciate your help and patience in my learning process.
andale
by adafruit_support_bill on Sat Jan 22, 2022 11:25 am
Not sure what you mean by 'distorts'. As soon as setup completes, the loop will start running. If the distance is < 36, it will display the rainbow. If you want it to stay blue for a while, then add a delay at the end of your setup.
That colorWipe code sets the pixels to whatever color you pass in - one at a time - and with a delay between each pixel. How long it remains blue depends entirely on what your code does after calling that function.
