🇺🇸Adafruit will not be shipping orders on Independence Day Monday 7/4/2022. Please allow extra time for your order to ship and plan accordingly.🇺🇸
largest display w arduino?
by skypickle on Tue May 17, 2022 10:45 am
Which is the largest display (available here at adafruit) that an arduino leonardo (or similar or Teensy) can drive?
Which is the largest display anyone has seen an arduino (or teensy) drive?
skypickle
Re: largest display w arduino?
by mikeysklar on Tue May 17, 2022 12:45 pm
Is there a specific resolution (minimum or maximum) you were hoping to work with?
Does it matter if the display is a RGB panel or does it need to be a TFT?
You will be limited to a 3.5" TFT 320x480 in terms of plug and play with written guides for Arduino based older controllers.
https://www.adafruit.com/?q=3.5%22&sort=BestMatch
There are HDMI and DAC hacks to get you into large (think desktop monitors / tvs) using M0, M4 or RP2040 boards.
https://learn.adafruit.com/adafruit-dvi-breakout-board
https://learn.adafruit.com/circuit-play ... -dac-hacks
This probably goes without saying, but if you really want to drive a big screen it would be easiest to use a Raspberry Pi.
mikeysklar
by skypickle on Wed May 18, 2022 7:20 am
Thanks, that’s what I thought. I just don’t want the overhead of running a full OS or the delay in boot up
skypickle
by mikeysklar on Wed May 18, 2022 8:08 pm
I certainly understand the desire to avoid running an entire OS and waiting for boot times.
I think the RP2040 HDMI display hack buys you the biggest display option, but it still depends on your content.
mikeysklar
