Is there a specific resolution (minimum or maximum) you were hoping to work with?
Does it matter if the display is a RGB panel or does it need to be a TFT?
You will be limited to a 3.5" TFT 320x480 in terms of plug and play with written guides for Arduino based older controllers.
https://www.adafruit.com/?q=3.5%22&sort=BestMatchThere are HDMI and DAC hacks to get you into large (think desktop monitors / tvs) using M0, M4 or RP2040 boards.
https://learn.adafruit.com/adafruit-dvi-breakout-boardhttps://learn.adafruit.com/circuit-play ... -dac-hacksThis probably goes without saying, but if you really want to drive a big screen it would be easiest to use a Raspberry Pi.
