Adafruit 2.4" TFT LCD with Touchscreen Breakout w/MicroSD So
by wfitkin on Sun May 22, 2022 9:03 pm
New display not working.
I purchased a Adafruit 2.4 " LCD Touchscreen Breakout on 5/5/2022.
I am unable to get it to work, The back light works but when using the Example under Adafruit, ILI9341, graphicstest i only get a white screeen and nothing else eccept from the Serial Monitor I get
4740342
Text 255453
Lines 2374797
Horiz/Vert Lines 384945
Rectangles (outline) 244567
Rectangles (filled) 9447233
Circles (filled) 1120043
Circles (outline) 1031837
Triangles (outline) 539286
Triangles (filled) 3201198
Rounded rects (outline) 487844
Rounded rects (filled) 9780115
Done!
I am attaching some code & photos...
Showing connections
Proper connections.jpg (30.49 KiB) Viewed 220 times
Soldered jumpers
3 Solder jumpers on back.jpg (26.67 KiB) Viewed 220 times
Working example with a SPI ILI9341 display showing the example.
Working ILI9341.jpg (32.13 KiB) Viewed 220 times
  This is our GFX example for the Adafruit ILI9341 Breakout and Shield
  ----> http://www.adafruit.com/products/1651
  Check out the links above for our tutorials and wiring diagrams
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional)
  products from Adafruit!
  MIT license, all text above must be included in any redistribution
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
// For the Adafruit shield, these are the default.
#define TFT_DC 9
#define TFT_CS 10
#define TFT_MOSI 11
#define TFT_CLK 13
#define TFT_RST 8
#define TFT_MISO 12
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
// Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// If using the breakout, change pins as desired
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
  Serial.println("ILI9341 Test!");
  tft.begin();
  // read diagnostics (optional but can help debug problems)
  uint8_t x = tft.readcommand8(ILI9341_RDMODE);
  Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDMADCTL);
  Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDPIXFMT);
  Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDIMGFMT);
  Serial.print("Image Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDSELFDIAG);
  Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
  Serial.println(F("Benchmark                Time (microseconds)"));
  delay(10);
  Serial.print(F("Screen fill              "));
  Serial.println(testFillScreen());
  delay(500);
  Serial.print(F("Text                     "));
  Serial.println(testText());
  delay(3000);
  Serial.print(F("Lines                    "));
  Serial.println(testLines(ILI9341_CYAN));
  delay(500);
  Serial.print(F("Horiz/Vert Lines         "));
  Serial.println(testFastLines(ILI9341_RED, ILI9341_BLUE));
  delay(500);
  Serial.print(F("Rectangles (outline)     "));
  Serial.println(testRects(ILI9341_GREEN));
  delay(500);
  Serial.print(F("Rectangles (filled)      "));
  Serial.println(testFilledRects(ILI9341_YELLOW, ILI9341_MAGENTA));
  delay(500);
  Serial.print(F("Circles (filled)         "));
  Serial.println(testFilledCircles(10, ILI9341_MAGENTA));
  Serial.print(F("Circles (outline)        "));
  Serial.println(testCircles(10, ILI9341_WHITE));
  delay(500);
  Serial.print(F("Triangles (outline)      "));
  Serial.println(testTriangles());
  delay(500);
  Serial.print(F("Triangles (filled)       "));
  Serial.println(testFilledTriangles());
  delay(500);
  Serial.print(F("Rounded rects (outline)  "));
  Serial.println(testRoundRects());
  delay(500);
  Serial.print(F("Rounded rects (filled)   "));
  Serial.println(testFilledRoundRects());
  delay(500);
  Serial.println(F("Done!"));
void loop(void) {
  for(uint8_t rotation=0; rotation<4; rotation++) {
    tft.setRotation(rotation);
    testText();
    delay(1000);
unsigned long testFillScreen() {
  unsigned long start = micros();
  tft.fillScreen(ILI9341_BLACK);
  yield();
  tft.fillScreen(ILI9341_RED);
  yield();
  tft.fillScreen(ILI9341_GREEN);
  yield();
  tft.fillScreen(ILI9341_BLUE);
  yield();
  yield();
  return micros() - start;
unsigned long testText() {
  tft.setCursor(0, 0);
  tft.setTextColor(ILI9341_WHITE);  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(ILI9341_YELLOW); tft.setTextSize(2);
  tft.println(1234.56);
  tft.setTextColor(ILI9341_RED);    tft.setTextSize(3);
  tft.println(0xDEADBEEF, HEX);
  tft.println();
  tft.setTextColor(ILI9341_GREEN);
  tft.setTextSize(5);
  tft.println("Groop");
  tft.setTextSize(2);
  tft.println("I implore thee,");
  tft.setTextSize(1);
  tft.println("my foonting turlingdromes.");
  tft.println("And hooptiously drangle me");
  tft.println("with crinkly bindlewurdles,");
  tft.println("Or I will rend thee");
  tft.println("in the gobberwarts");
  tft.println("with my blurglecruncheon,");
  tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
  unsigned long start, t;
  int           x1, y1, x2, y2,
                w = tft.width(),
                h = tft.height();
  yield();
  x1 = y1 = 0;
  y2    = h - 1;
  start = micros();
  for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
  x2    = w - 1;
  for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
  t     = micros() - start; // fillScreen doesn't count against timing
  yield();
  yield();
  x1    = w - 1;
  y1    = 0;
  y2    = h - 1;
  start = micros();
  x2    = 0;
  t    += micros() - start;
  yield();
  yield();
  x1    = 0;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = w - 1;
  yield();
  yield();
  x1    = w - 1;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = 0;
  yield();
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
  unsigned long start;
  int           x, y, w = tft.width(), h = tft.height();
  start = micros();
  for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
  for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
  int           n, i, i2,
                cx = tft.width()  / 2,
                cy = tft.height() / 2;
  n     = min(tft.width(), tft.height());
  start = micros();
  for(i=2; i<n; i+=6) {
    i2 = i / 2;
    tft.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
  unsigned long start, t = 0;
  int           n, i, i2,
                cx = tft.width()  / 2 - 1,
                cy = tft.height() / 2 - 1;
  for(i=n; i>0; i-=6) {
    i2    = i / 2;
    start = micros();
    tft.fillRect(cx-i2, cy-i2, i, i, color1);
    // Outlines are not included in timing results
    tft.drawRect(cx-i2, cy-i2, i, i, color2);
    yield();
  return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
  int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
  start = micros();
  for(x=radius; x<w; x+=r2) {
    for(y=radius; y<h; y+=r2) {
      tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
  int           x, y, r2 = radius * 2,
                w = tft.width()  + radius,
                h = tft.height() + radius;
  // Screen is not cleared for this one -- this is
  // intentional and does not affect the reported time.
  start = micros();
  for(x=0; x<w; x+=r2) {
    for(y=0; y<h; y+=r2) {
      tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
  int           n, i, cx = tft.width()  / 2 - 1,
  n     = min(cx, cy);
  start = micros();
  for(i=0; i<n; i+=5) {
    tft.drawTriangle(
      cx    , cy - i, // peak
      cx - i, cy + i, // bottom left
      cx + i, cy + i, // bottom right
      tft.color565(i, i, i));
unsigned long testFilledTriangles() {
  int           i, cx = tft.width()  / 2 - 1,
  start = micros();
  for(i=min(cx,cy); i>10; i-=5) {
    start = micros();
    tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      tft.color565(0, i*10, i*10));
    tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      tft.color565(i*10, i*10, 0));
    yield();
  return t;
unsigned long testRoundRects() {
  int           w, i, i2,
  w     = min(tft.width(), tft.height());
  start = micros();
  for(i=0; i<w; i+=6) {
    i2 = i / 2;
    tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
  int           i, i2,
  start = micros();
  for(i=min(tft.width(), tft.height()); i>20; i-=6) {
    i2 = i / 2;
    tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
    yield();
wfitkin
Re: Adafruit 2.4" TFT LCD with Touchscreen Breakout w/MicroS
by adafruit_support_carter on Mon May 23, 2022 1:29 pm
It looks like the initial serial prints did not get included above. Can you run the sketch again and paste those lines here. They are the ones printed here, which contain some diagnostic information:
https://github.com/adafruit/Adafruit_IL ... no#L36-L46
See example expected output at the bottom of page here:
https://learn.adafruit.com/adafruit-2-4 ... iring-test
by wfitkin on Mon May 23, 2022 2:39 pm
I only get this on the serial monitor when the breakout is connected...
4740342
Text 255453
Lines 2374797
Done!
wfitkin
by wfitkin on Mon May 23, 2022 2:53 pm
Overview showing connections
I have tried connecting two other ili9341 displays to the Arduino Nano 33 IoT controller and they display fine using the controller in the picture and the code I attached. They display the demo perfectly. The Adafruit breakout only turns on the backlight and never displays anything.
Using the following pins on all of them.
Vin is 3.3 volts
CLK on 13
MISO on 12
MOSI on 11
CS on 10
DC on 9
RST on 8
wfitkin
by wfitkin on Mon May 23, 2022 11:02 pm
At home tonight i tested it again, Only the following on the Serial Monitor...
4740232
Text 255458
Lines 2374795
Rectangles (outline) 244562
Rectangles (filled) 9447274
Circles (filled) 1120045
Circles (outline) 1031992
Triangles (outline) 539287
Triangles (filled) 3201173
Rounded rects (outline) 487845
Rounded rects (filled) 9780125
Done!
wfitkin
by wfitkin on Mon May 23, 2022 11:06 pm
I did try this wired directly to an Arduino Uno R3. same result
wfitkin
by adafruit_support_carter on Tue May 24, 2022 11:20 am
The lines could be scrolling out of view in the Serial Monitor window. Try making the window bigger. Can also add a wait:
  while (!Serial);
to wait for the Serial Monitor to be opened before printing out the text.
by wfitkin on Wed May 25, 2022 12:41 am
That did provide some more information. Thank you for your help with this.
Here is the new output... looks like all of the Serial.print information is there.
ILI9341 Test!
Display Power Mode: 0x0
MADCTL Mode: 0x0
Pixel Format: 0x0
Image Format: 0x0
Self Diagnostic: 0x0
Screen fill 4740383
Text 254324
Lines 2374799
Horiz/Vert Lines 384942
Rectangles (filled) 9447192
Circles (filled) 1120042
Circles (outline) 1031874
Triangles (outline) 539291
Triangles (filled) 3201188
Rounded rects (outline) 487838
Rounded rects (filled) 9780117
Done!
wfitkin
by adafruit_support_carter on Wed May 25, 2022 1:12 pm
Thanks. These are the lines that were of interest:
ILI9341 Test!
MADCTL Mode: 0x0
Pixel Format: 0x0
Image Format: 0x0
It's getting back all 0's for the various mode and format parameters. Those are being read back from the TFT. Getting all 0's is a good indication that there's a connection issue.
Please post a higher res photo of the soldering on the TFT header pins:
by wfitkin on Wed May 25, 2022 11:12 pm
Here are 2 photos
wfitkin
by adafruit_support_carter on Thu May 26, 2022 3:45 pm
Thanks. A little hard to tell for sure, but is maybe the MISO pin a little thin / under soldered?
And also maybe D/C and RST?
See here for reference:
https://learn.adafruit.com/adafruit-gui ... n-problems
Try adding a bit more solder to those to see if it helps. Same general check for goodness - run same sketch, should get some non-zero values back for the various settings.
by wfitkin on Thu May 26, 2022 9:23 pm
I re flowed and added solder to all pins.
Here is a fresh output from the serial monitor
ILI9341 Test!
MADCTL Mode: 0x0
Pixel Format: 0x0
Image Format: 0x0
Screen fill 4740481
Text 254327
Lines 2374797
Rectangles (outline) 244565
Rectangles (filled) 9447239
Circles (outline) 1031997
Triangles (outline) 539293
Triangles (filled) 3201185
Rounded rects (outline) 487849
Rounded rects (filled) 9780132
Done!
Re-Soldered pins
Re-Soldered Pins.jpg (453.92 KiB) Viewed 135 times
wfitkin
by wfitkin on Thu May 26, 2022 9:41 pm
Here is the Serial output from a WaveShare ILI9341. The sketch is running normally
ILI9341 Test!
MADCTL Mode: 0x0
Pixel Format: 0x0
Image Format: 0x0
Screen fill 4740490
Text 254325
Lines 2374800
Rectangles (filled) 9447232
Circles (filled) 1120046
Circles (outline) 1031999
Triangles (filled) 3201175
Done!
Working ILI9341 Waveshare display, same sketch, same board
Working ILI9341 Waveshare display, same sketch, same board.jpg (607.23 KiB) Viewed 131 times
wfitkin
by wfitkin on Tue May 31, 2022 4:28 am
I have done everything you asked of me can I get a warranty on this display?
wfitkin
by adafruit_support_carter on Tue May 31, 2022 5:52 pm
OK, let's just replace it and see what happens.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement TFT.
