It is mentioned here that
"As of October 2018, we now sell a version that can be used with 64x64 pixel matrices that have an 'E' address pin!"
Adafruit RGB Matrix HAT + RTC for Raspberry Pi - Mini Kit
https://www.adafruit.com/product/2345
How can I determine if I got one of these updates versions, when buying? I'd like to buy one in Europe, but would like to be sure I grab a HUB75E compatible one.
Thank you for your help?
RGB Matrix HAT HUB75E
- dastels
Re: RGB Matrix HAT HUB75E
It's 4 years later so you're pretty certain to get one of the new versions.
If you look at the board at https://cdn-shop.adafruit.com/970x728/2345-10.jpg You'll see mention of "E" on the silk screen. next to the camera cable opening you'll see 3 pads labelled 8, E, 16 (top to bottom) and just below GPIO 24 on the GPIO breakout pads you'll see an "E" pad. Compare with the older version here: https://learn.adafruit.com/assets/22489.
Also, see https://learn.adafruit.com/adafruit-rgb ... 3004286-23.
- hazelxvx
Hey Dave,
thank you so much for your quick answer.. This helped a lot! Thank you so much. I love your items!
Greetings!
Greetings!
