Where can I get LED Diffusion Acrylic sheets in any size?
by billtubbs on Fri Jul 01, 2022 12:41 am
Anyone know where I can get LED Diffusion Acrylic sheets in larger sizes than the 12" x 12" sheet from Adafruit: https://www.adafruit.com/product/4594? Where does Adafruit get this sheet from?
I found this supplier in the US but their sheet only comes in 1/8" thick (3 mm):
I need 1/10" (2.5 mm) to fit this 20" x 16" frame:
Alternatively, if anyone knows where I can get an aluminium frame that fits 1/8" glass that would work.
thanks
billtubbs
Re: Where can I get LED Diffusion Acrylic sheets in any size
by adafruit_support_mike on Fri Jul 01, 2022 9:21 pm
Acrylic sheet comes in two forms: cast and extruded. Cast acrylic sheet has a relatively wide tolerance on thickness.. as much as +/-.010" (+/-0.25mm). Extruded sheet has better tolerances, but costs more.
There are many plastics distributors.. Tap, Regal, Interstate, etc.. and you can probably find at least one in any reasonably large city. Their bread and butter trade is advertising substrates, but they can order anything in their catalog from a central warehouse if they don't keep it in local inventory.
And when in doubt, McMaster-Carr is the Maker's friend:
https://www.mcmaster.com/sheet-stock/
They have a broad inventory and ship quickly.
by billtubbs on Sat Jul 02, 2022 12:30 pm
adafruit_support_mike wrote:There are many plastics distributors.. Tap, Regal, Interstate, etc..
Thanks. As far as I can see only TAP Plastics have the black LED diffuser (3mm thick).
I'm not sure whether the Adafruit sheet is cast or extruded but I guess it is probably extruded.
I was hoping to find the source where Adafruit gets it from so I can order a larger sheet.
billtubbs
by adafruit_support_mike on Mon Jul 04, 2022 8:29 pm
I'm afraid our supplier contracts forbid sharing source information with third parties, but we work through the distributors too. Our orders aren't nearly big enough to warrant special production.
by billtubbs on Tue Jul 05, 2022 1:23 am
Okay thanks. I'll try contacting all of them.
billtubbs
by billtubbs on Wed Jul 06, 2022 12:17 pm
I think I have figured out what is going on. TAP Plastics and Regal both supply Black LED acrylic sheet in thickness 0.118" (3.00 mm). However, I contacted TAP and they informed me the tolerance of their sheet is +/- .015” or +/- .381mm.
0.118” - .015” = .103” = 2.62mm
Also, I contacted someone who actually bought some of this sheet from TAP and they said theirs was actually 2.61 mm. So it seems 1/8" (3mm) is the nominal size but the shipped product is actually variable and sometimes 1/10" (2.62mm) ...
Is it possible that Adafruit came up with the "0.1" / 2.6mm thick" description based on an actual measurement of your stock rather than what the specification from the supplier says?
billtubbs
by adafruit_support_mike on Wed Jul 06, 2022 10:27 pm
I'm fairly sure we get extruded sheet with a nominal size of 2.5mm.
We do work with a lot of European and Asian suppliers though, who use metric as their default.
