Mounting NeoTrellis to front panel
Post Reply
bill_fisher
Post by bill_fisher »
I’m looking for info on mounting a single 4x4 NeoTrellis to a front panel. I see four very small holes that pass through the PCB and elastomer buttons. Are these the best way to mount the NeoTrellis to a front panel? Or should I try to make new holes in the elastomer and use the larger holes in the PCB?
Does anyone know what size of screw will work in any of these holes? I did try M3 in the larger holes, and M3 is too big.
I’m only interested in mounting to the front panel, not sandwich designs like this: https://learn.adafruit.com/neotrellis-s ... l-assembly
Thanks in advance!
adafruit_support_mike
Re: Mounting NeoTrellis to front panel
The holes in the corners should work for you.
The hole diameter is 0.100".. M2.5 or #4 screws should work.
Post Reply
