I spent a couple of hours searching but I couldn't find anything on this topic. I'm working on a project using a Raspberry Pi with Python and Adafruit's 2.42" OLED display (https://www.adafruit.com/products/2719) would be perfect for my needs. However, the specs say it uses the SSD1305 controller, and the only documentation/library I can find is for the SSD1306 controller. I've done some research and found out that the SSD1305 has a different initialization sequence, so I was wondering if the Adafruit SSD1306 python library would for this display. If not are there any other options available?
John
Adafruit 2.42" OLED display on Raspberry Pi
Re: Adafruit 2.42" OLED display on Raspberry Pi
Did you see that there's a tutorial linked from the product page? https://learn.adafruit.com/1-5-and-2-1- ... lay-module
If you follow that through a couple of pages on wiring, it eventually links to a C library they have on Github for the SSD1305: https://github.com/adafruit/Adafruit_SSD1305_Library
The example in that tutorial and library is for Arduino, but it looks like the code is straight C, so it seems likely you could adapt it to the Raspberry Pi. I'm not 100% sure that's true, but thought I'd point out the Github repo in case you hadn't seen it.
- johnmcd
Yep, I saw that, but thanks anyway. It's been a few years since I touched C and I'm not sure my skills are up to adapting the library to working with Python.elnj wrote:Did you see that there's a tutorial linked from the product page? https://learn.adafruit.com/1-5-and-2-1- ... lay-module
Hi John,
Did you finally getting it working with Python on Raspberry Pi?
I was hoping I can get a Python library for SSD1305 but like you mentioned all references on the Internet and Adafruit seems to be only for Arduino and C.
Ashwin
Ashwin
- cmkerr
Hi guys,
Did any of you figure this out?
- BeauSlim
I don't have one of these, but I do have a couple 1306 bonnets.cmkerr wrote: Did any of you figure this out?
This github blog says to use 1306 drivers and provides a guide for getting luma.oled working with your display and the pi.
- adafruit_support_carter
You can try this CircuitPython SSD1306 library:
https://github.com/adafruit/Adafruit_Ci ... on_SSD1306
To use on the RPi you will need to install blinka:
https://learn.adafruit.com/circuitpytho ... x/overview
