I'm going to purchase Product ID 2441, that is the PiTFT Plus 3.5" TFT display for Raspberry PI.
I'd like to see the datasheet of the display module. I searched for it, but I couldn't find it.
I also need mechanical details of the PCB.
PiTFT Plus 3.5" TFT display: datasheet
- adafruit_support_rick
Re: PiTFT Plus 3.5" TFT display: datasheet
It's all in the tutorial:
https://learn.adafruit.com/adafruit-pit ... /downloads
- snschbt
Could I be provided a SolidWorks (or equivalent file-type) model of the PiTFT Plus 480x320 3.5" TFT+Touchscreen for Raspberry Pi? It's product ID is 2441. I will need to add it to the assembly I have created in Solidworks. Thanks!
Sorry, but we don't have any 3D models of that.
- snschbt
Are there any 2D drawings in any format? I'm just looking for some accurate dimensions to design around...
- snschbt
Thank you for pointing me in the right direction! :) Unfortunately, my attempts at converting/importing the BRD files into SolidWorks have been both feeble and in vain. Would anyone be willing to convert the brd file to a dxf or dwg file for me? I would appreciate it IMMENSELY. Thanks!
https://github.com/adafruit/Adafruit-Pi ... master.zip
- snschbt
Can the display on this LCD be rotated upside down? My install on a bezel only allows for an "upside down" configuration per the images shown in the product description, so having this ability would solve a lot of problems for me. :)
Edit /boot/config.txt. Change the rotation in this line from 90 to 270:
dtoverlay=pitft35r,rotate=90,speed=42000000,fps=20
- snschbt
Thanks Rick!
