Faulty 5.0" 40-pin TFT Display 800x480 (Non-Touch)
by supaevensteven on Sun Jan 08, 2017 8:15 pm
Hi I purchased a 5.0" 40-pin TFT Display - 800x480 without touchscreen Order No: 828825-5521556001.
The LCD details sticker has:
KD50G21-40NT-A1
2015.03.30
I use the LCD screen with a Kippah hat. Unfortunately I've always had a horizontal line of black pixels on the screen that don't appear to work.
I contacted Adafruit a while ago to get support and they pointed me here.
I've already tried:
- re-seating the 40-pin flex cable in the kippah connector
- fresh install of raspbian and the kippah guide
I want to use the screen to make a video doorbell with my RPi2
Can you please help me fix the LCD fault?
Stephen
supaevensteven
Re: Faulty 5.0" 40-pin TFT Display 800x480 (Non-Touch)
by franklin97355 on Sun Jan 08, 2017 11:22 pm
Could you post large, clear, detailed pictures of both sides of your board and the connections to it? Pictures should be less than 1meg in size.
franklin97355
by supaevensteven on Mon Jan 09, 2017 1:12 am
Thanks for the fast reply. Please find the the requested photos attached.
I'm using a 2.0A 5V power adapter to power the raspberry pi. I have nothing else connected to the Raspberry Pi 2 other than a power cable and the Kippah Hat.
No connections have been soldered to the Kippah Hat. The only connections are the GPIO header and the 40-pin LCD flex cable.
I hope this helps.
Stephen
supaevensteven
by supaevensteven on Mon Jan 09, 2017 1:13 am
Board specific photos:
supaevensteven
by supaevensteven on Mon Jan 09, 2017 1:18 am
I thought it's worth mentioning that as you can see in the photos of the active LCD above I get a mixture of white/black lines. Either they rarely flicker or they're constantly solid and persistent on the screen. A couple of times I've noticed they've disappeared and the screen looks perfect but it doesn't last very long.
supaevensteven
by supaevensteven on Sun Jan 07, 2018 5:01 am
Mate, can someone organise the replacement of these faulty units. I purchased the parts 2015-07-11 and reported the fault via email to Stephanie of Adafruit on 2015-27-11.
The fact no one from Adafruit followed up on this or replied to my issue baffles me.
supaevensteven
