NeoPixelRing code
NeoPixelRing code
by darylary on Thu Jan 12, 2017 10:43 am
I'm trying to control my 16 LED RGB NeoPixel ring, but I can't seem to make it work. I've tried using a lot of different codes, but none have worked for me.
First oft all, I am a beginner at coding and prototyping, so bare with me.
I am Using the Arduino Yun with the grove base shield. Also I have connected a grove touch button and of course the NeoPixel Ring.
I want to do this:
1. If I push the button, all oft the LEDs are supposed to light up in bright green.
2.If I push the button again, 2 LED's (next to each other)should go out. I want to be able to push the button until all of them are out.
3.lastly, if I push the button again, it's supposed to turn on all of the green lights again.
I'm a total noob and I'd really appreciate your help!
darylary
Re: NeoPixelRing code
by adafruit_support_bill on Thu Jan 12, 2017 10:53 am
If you post the code you have so far and describe what parts do and don't work we'll take a look.
by darylary on Thu Jan 12, 2017 11:04 am
#define PIN 7
#define NUM_LIGHTS  16
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LIGHTS, PIN, NEO_GRB + NEO_KHZ800);
// this constant won't change:
const int  buttonPin = 3;    // the pin that the pushbutton is attached to
const int ledPin = 7;       // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  // initialize the LED as an output:
  pinMode(ledPin, OUTPUT);
  // initialize serial communication:
  Serial.begin(9600);
 // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button
      // wend from off to on:
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes:  ");
      Serial.println(buttonPushCounter);
    } else {
      // if the current state is LOW then the button
      // wend from on to off:
      Serial.println("off");
    // Delay a little bit to avoid bouncing
    delay(50);
    lastButtonState = buttonState;
    uint32_t low = strip.Color(0, 0, 0);
    uint32_t high = strip.Color(0, 255, 0);
    // Turn them off
    for( int i = 0; i<NUM_LIGHTS; i++){
        strip.setPixelColor(i, high);
        strip.show();
    delay(1000);
        strip.setPixelColor(i, low);
        strip.show();
So the statechange code worked on its own and the Neopixel code too. But together they don't seem to work.
darylary
by adafruit_support_bill on Thu Jan 12, 2017 12:20 pm
You need to put your led code in a 'switch' statement to handle the various cases.
The structure of it would be something like this:
   switch(buttomPushCounter)
      case 0:
         // code for 0 pushes
      break;
      case 1:
         // code for 1 push
      break;
      case 2:
         // code for 2 pushes
      break;
      default
         // code for everything else
      break:
by darylary on Wed Jan 18, 2017 10:21 am
Hi, thanks a lot for the advice.
I did different cases now, but I think there's a problem with the counter.
All of the leds are on, but the cases don't seem to work. just two off them turn off at some point.
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
#ifdef __AVR__
  #include <avr/power.h>
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#define PIN            6
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS      16
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRBW + NEO_KHZ800);
//int delayval = 500; // delay for half a second
const int buttonPin = 3;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// variables will change:
int showType = 0;
 // initialize the LED pin as an output:
  // initialize the pushbutton pin as an input:
  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#if defined (__AVR_ATtiny85__)
  if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
  // End of trinket special code
  strip.begin(); // This initializes the NeoPixel library.
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
 /* if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
  } else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
  button_press();
  // For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one.
 /* for(int i=0;i<NUMPIXELS;i++){
    // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
    pixels.setPixelColor(i, pixels.Color(0,150,0)); // Moderately bright green color.
    pixels.show(); // This sends the updated pixel color to the hardware.
    delay(delayval); // Delay for a period of time (in milliseconds).
void startShow(int i) {
  switch(i){
    case 0:
            seg1();
            seg2();
            seg3();
            seg4();
            seg5();
            seg6();
            seg7();
            seg8();
            strip.show();
            break;
    case 1:
            seg2();
            seg3();
            seg4();
            seg5();
            seg6();
            seg7();
            seg8();
              //strip.show();
            break;
    case 2:
            seg3();
            seg4();
            seg5();
            seg6();
            seg7();
            seg8();
             // strip.show();
            break;
    case 3: seg4();
            seg5();
            seg6();
            seg7();
            seg8();
            break;
    case 4: seg5();
            seg6();
            seg7();
            seg8();
            break;
    case 5: seg6();
            seg7();
            seg8();
            break;
    case 6:
            seg7();
            seg8();
            break;
    case 7: seg8();
            break;
    case 8: seg9();
            break;
void button_press(){
  bool newState = digitalRead(buttonPin);
    // turn LED on:
    if (newState == HIGH) {
      showType++;
      if (showType > 7)
        {showType=0;}
      startShow(showType);
      strip.show();
    delay(500);
    //seg1();
    //zaehler++
    //evtl: delay
    strip.show();
  } else {
    // turn LED off:
    //led_aus();
void seg1(){
  strip.setPixelColor(0, strip.Color(0, 150, 0, 10));
  strip.setPixelColor(1, strip.Color(0, 150, 0));
void seg2(){
  strip.setPixelColor(2, strip.Color(0, 150, 0));
  strip.setPixelColor(3, strip.Color(0, 150, 0));
void seg3(){
  strip.setPixelColor(4, strip.Color(0, 150, 0));
  strip.setPixelColor(5, strip.Color(0, 150, 0));
void seg4(){
  strip.setPixelColor(6, strip.Color(0, 150, 0));
  strip.setPixelColor(7, strip.Color(0, 150, 0));
  void seg5(){
  strip.setPixelColor(8, strip.Color(0, 150, 0));
  strip.setPixelColor(9, strip.Color(0, 150, 0));
  void seg6(){
  strip.setPixelColor(10, strip.Color(0, 150, 0));
  strip.setPixelColor(11, strip.Color(0, 150, 0));
  void seg7(){
  strip.setPixelColor(12, strip.Color(0, 150, 0));
  strip.setPixelColor(13, strip.Color(0, 150, 0));
  void seg8(){
  strip.setPixelColor(14, strip.Color(0, 150, 0));
  strip.setPixelColor(15, strip.Color(0, 150, 0));
void seg9(){
  strip.setPixelColor(0, strip.Color(0, 0, 0));
  strip.setPixelColor(1, strip.Color(0, 0, 0));
  strip.setPixelColor(2, strip.Color(0, 0, 0));
  strip.setPixelColor(3, strip.Color(0, 0, 0));
  strip.setPixelColor(4, strip.Color(0, 0, 0));
  strip.setPixelColor(5, strip.Color(0, 0, 0));
  strip.setPixelColor(6, strip.Color(0, 0, 0));
  strip.setPixelColor(7, strip.Color(0, 0, 0));
  strip.setPixelColor(8, strip.Color(0, 0, 0));
  strip.setPixelColor(9, strip.Color(0, 0, 0));
  strip.setPixelColor(10, strip.Color(0, 0, 0));
  strip.setPixelColor(11, strip.Color(0, 0, 0));
  strip.setPixelColor(12, strip.Color(0, 0, 0));
  strip.setPixelColor(13, strip.Color(0, 0, 0));
  strip.setPixelColor(14, strip.Color(0, 0, 0));
  strip.setPixelColor(15, strip.Color(0, 0, 0));
darylary
by adafruit_support_bill on Wed Jan 18, 2017 10:25 am
Other than your "seg9()" all the functions just turn pixels on. They don't turn off any pixels that might already be on.. If you want pixels to turn off when you the counter changes, you have to write code for that.
by darylary on Wed Jan 18, 2017 10:43 am
it works! thank you so much for your help!
darylary
by adafruit_support_bill on Wed Jan 18, 2017 10:49 am
Great! Thanks for the follow-up.
by mqdean on Fri Feb 02, 2018 8:33 am
Hi
I am trying something similar to this post. I am using a FSR to switch on the led light. I am trying to switch on one led light whenever the serial value goes below 20. So when I apply the required force once, I want one pixel to light up.. 2nd time when force is applied, 2 lights to light up and so on.
I am using FLORA and neopixel ring (16)
Below is my code for your reference. Hope you could help me on this. Thank you!
#include <EasyNeoPixels.h>
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(16, PIN, NEO_GRB + NEO_KHZ800);
int force;
  pinMode(9, INPUT_PULLUP);
  strip.begin();
  strip.show();
  // put your main code here, to run repeatedly:
force = analogRead(9);
Serial.println(force);
if(force <= 20)
strip.setPixelColor(7, 250, 130, 1);
strip.setBrightness(10);
strip.show();
Last edited by adafruit_support_bill on Fri Feb 02, 2018 9:03 am, edited 1 time in total.
Reason: Please use [code] tags when submitting code to the forums
mqdean
by adafruit_support_bill on Fri Feb 02, 2018 9:10 am
A couple of problems there:
Your pixel number is hard-coded (7). So you are setting the same pixel every time.
Calling this repeatedly can cause problems. You should only call this once in setup().
To get your pixels to increment with each press, you need to declare a global variable to keep count of the pixels:
int pixelCount = 0;
Then in your code you need to use that value to set the pixel. And you need to increment it after each press:
int pixelCount = 0;
void loop()
   if(force <= 20)
      strip.setPixelColor(pixelCount++, 250, 130, 1);
      strip.show();
by mqdean on Fri Feb 02, 2018 9:33 am
I did not expect such a prompt reply. You guys are incredible.
Below is what I have coded. All the pixels light up when I hit the FSR once. What am I doing wrongly?
#define PIN 6
int force;
  strip.begin();
  strip.show();
int pixelCount = 0;
   if(force <= 20)
      strip.show();
Last edited by adafruit_support_bill on Fri Feb 02, 2018 9:54 am, edited 1 time in total.
mqdean
by mqdean on Fri Feb 02, 2018 9:39 am
Its working. Thank you man!
mqdean
by adafruit_support_bill on Fri Feb 02, 2018 9:55 am
You may need to 'debounce' the input. Adding a short delay inside the 'if' statement should work.
by mqdean on Fri Feb 02, 2018 10:35 am
Thanks a lot. Great Help. It is working. Just want to confirm that I have written the delay correctly.
#define PIN 6
int force;
  strip.setBrightness(255);
  strip.begin();
  strip.show();
int pixelCount = 0;
   if(force < 20)
      delay(100);
      strip.setPixelColor(pixelCount++, 0, 255, 0);
      strip.show();
Last edited by adafruit_support_bill on Fri Feb 02, 2018 11:09 am, edited 1 time in total.
mqdean
by adafruit_support_bill on Fri Feb 02, 2018 11:12 am
Yes. The delay looks fine. That will wait 100 milliseconds (1/10th second) before reading the sensor again. So as long as the pressure is applied for 1/10th second or less, it will only light one more pixel.
