NeoPixelRing code
Re: NeoPixelRing code
by adafruit_support_bill on Thu Feb 08, 2018 8:07 am
The Simon Monk books are good project-based introductory texts.
https://www.adafruit.com/category/250
But most of the Arduino-specific books are not very comprehensive with respect to the programming language. The "Arduino Language" is based on C++. And the Bjarne Stroustrup book is the definitive text on that - although I'll warn you that it is not an easy read.
https://www.amazon.com/C-Programming-La ... B%2B+books
There are also a number of very good on-line tutorials and references for the C++ language:
https://www.tutorialspoint.com/cplusplus/index.htm
http://www.cplusplus.com/doc/tutorial/
https://www.cprogramming.com/tutorial/c++-tutorial.html
by mqdean on Thu Feb 08, 2018 9:11 am
Thanks alot! You guys are super responsive.
mqdean
by mqdean on Fri Feb 09, 2018 10:45 am
Managed to get the sketch working.
Thanks alot!
mqdean
by adafruit_support_bill on Fri Feb 09, 2018 11:02 am
Good to hear. Thanks for the follow-up.
by mqdean on Fri Mar 23, 2018 6:28 am
Hi there again.
I am trying to auto calibrate my fsr and below is the code. I want the pixel to light up when the value drops by 5 (serial monitor value) and return back to normal within 10 miliseconds. Hope you could assist me on this. I want to do this because the neutral reading changes when the fsr is worn as a vest by different persons.
// These constants won't change:
const int sensorPin = 9;    // pin that the sensor is attached to
// variables:
int sensorValue = 0;         // the sensor value
int sensorMin = 1023;        // minimum sensor value
int sensorMax = 0;           // maximum sensor value
#include <EasyNeoPixels.h>
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(24, PIN, NEO_GRB + NEO_KHZ800);
  // calibrate during the first five seconds
  while (millis() < 5000) {
    sensorValue = analogRead(sensorPin);
    // record the maximum sensor value
    if (sensorValue > sensorMax) {
      sensorMax = sensorValue;
    // record the minimum sensor value
    if (sensorValue < sensorMin) {
      sensorMin = sensorValue;
  pinMode(9, INPUT_PULLUP);
  strip.setBrightness(10);
  strip.begin();
  strip.show();
  delay (30);
int pixelCount = 0;
long impactTime = 0;
  // read the sensor:
  // apply the calibration to the sensor reading
  sensorValue = map(sensorValue, sensorMin, sensorMax, 0, 255);
  // in case the sensor value is outside the range seen during calibration
  sensorValue = constrain(sensorValue, 0, 255);
Serial.println(analogRead(sensorPin));
    if (sensorValue < ((analogRead(sensorPin) - 5)))
        // record the time when it goes below sensorValue drops by 5.
        impactTime = millis();
    while (sensorValue < ((analogRead(sensorPin) - 5))) {}
    if (sensorValue) // check for return to 'normal'
        if ((millis() - impactTime) < 10)  // If less than 100 ms, record as a hit.
            strip.setPixelColor(pixelCount++, 0, 255, 0);
            strip.show();
            delay (100);
mqdean
by adafruit_support_bill on Fri Mar 23, 2018 7:19 am
Not sure I understand the logic in your loop. You take one reading that is re-mapped to your calibrated range. And you compare that to a raw, unmapped reading. I don't think you will get a meaningful result from that.
What happens during your calibration phase? Is it just to establish a baseline value, or do you do anything to the FSR?
by mqdean on Fri Mar 23, 2018 9:12 am
Below is the sketch I did. When I wear the fsr as a vest, the reading in the serial monitor is between 40 and 50. But when my friend wears the fsr as a vest, the reading is between 20 and 30 without any pressure applied. Hence, the below sketch does not work because the threshold is according to the readings when I am wearing. Therefore, I would like the pixel to light up when the serial monitor value drops by 5.
For example, if the reading is between 20 and 30 for my friend, I need the pixel to light up when the value goes below 15 and returns to 20 within 100millis
int force;
int pixelCount = 0;
int currentMillis;
void loop()
    force = analogRead(9);
    Serial.println(force);
    currentMillis = millis();
    if (force < 30)
        // record the time when it goes below 30.
        impactTime = currentMillis;
        while(force < 30) { } // do nothing.
    if (force > 40) // check for return to 'normal'
        if ((currentMillis - impactTime) < 100)  // If less than 100 ms, record as a hit.
            strip.show();
mqdean
by adafruit_support_bill on Fri Mar 23, 2018 9:30 am
So the calibration phase is just to establish the baseline for whomever is wearing the vest.
So instead of comparing against a fixed value like this:
if (force < 30)
You want to compare against the minimum baseline value from your calibration - minus 5:
if (force < sensorMin - 5)
by mqdean on Sat Mar 24, 2018 10:30 am
Hi
Below is what I have done. It does not seem to work. It seems like the baseline is not getting established. Kindly let me know where I have made an error.
Thank you!
  Calibration
  Demonstrates one technique for calibrating sensor input. The sensor readings
  during the first five seconds of the sketch execution define the minimum and
  maximum of expected values attached to the sensor pin.
  The sensor minimum and maximum initial values may seem backwards. Initially,
  you set the minimum high and listen for anything lower, saving it as the new
  minimum. Likewise, you set the maximum low and listen for anything higher as
  the new maximum.
  The circuit:
  - analog sensor (potentiometer will do) attached to analog input 0
  - LED attached from digital pin 9 to ground
  created 29 Oct 2008
  by David A Mellis
  modified 30 Aug 2011
  by Tom Igoe
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/Calibration
// variables:
#define PIN 6
  strip.begin();
  strip.show();
  delay (15);
int pixelCount = 0;
  // read the sensor:
    if (analogRead(sensorPin) < sensorMin-5)
        // record the time when it goes below 50.
     while (analogRead(sensorPin) < sensorMin-5) {}
    if (analogRead(sensorPin) > sensorMin) // check for return to 'normal'
        if ((millis() - impactTime) < 5)  // If less than 100 ms, record as a hit.
            strip.show();
            delay (100);
mqdean
by adafruit_support_bill on Sat Mar 24, 2018 12:45 pm
This code is not serving any purpose. You can just delete it.
  // read the sensor:
If you add some serial output to the loop showing the analog values and millisecond timings, it might shed some light on why it is not working as expected.
by mqdean on Sat Nov 24, 2018 8:57 am
Hi
I am doing a vibration sensor using a piezo element. I need the neopixel to light up according to the number of peaks in voltage within a specified time range. Please find the code below. It is not working as it should be. The neopixel lights up after one spike. Kindly advise how I can amend the below code. Thank you!
// variables:
#define PIN 6
  strip.begin();
  strip.show();
  strip.setPixelColor(0, 255, 0, 0);
  strip.show();
  Serial.begin(9600);
    sensorValue = analogRead(9);
  strip.setPixelColor(0, 0, 0, 0);
  strip.show();
long pixelCount = 0;
void loop()
      Serial.println(analogRead(9));
    if (analogRead(9) < (sensorMax*0.9))
     while (analogRead(9) < (sensorMax*0.9)) {}
     if (analogRead(9) > (sensorMax*0.95)){}
     if (analogRead(9) < (sensorMax*0.9)){}
     {if ((millis() - impactTime) < 20 )
     {strip.setPixelColor(pixelCount++, 0, 255, 0);
     strip.show(); delay (3000);}}
mqdean
by adafruit_support_bill on Sat Nov 24, 2018 10:48 am
A single impact on a Piezo sensor will typically result in a series of oscillations. You need to decide what will be the minimum time interval between detected impacts and ignore any oscillations that occur within that time interval.
