NeoPixelRing code
Re: NeoPixelRing code
by mqdean on Sun Feb 04, 2018 8:19 pm
Thank you for the help. Edited the sketch and uploaded, all the pixels light up without any force on the fsr.
int force;
int pixelCount = 0;
long impactTime = 0;
int currentMillis;
void loop()
    force = analogRead(9);
    Serial.println(force);
    currentMillis = millis();
    if (force < 50)
        // record the time when it goes below 50.
        impactTime = currentMillis;
        while(force < 50) { } // do nothing.
    if (force > 60) // check for return to 'normal'
        if ((currentMillis - impactTime) < 100)  // If less than 100 ms, record as a hit.
            strip.setPixelColor(pixelCount++, 0, 255, 0);
            strip.show();
mqdean
by adafruit_support_bill on Mon Feb 05, 2018 7:07 am
Print out the actual force readings. You may need to adjust the thresholds to match the range that your sensor is reading.
by mqdean on Mon Feb 05, 2018 7:52 am
The readings are between 125 and 135. So it should not light up by right. Was trying to play around with the brackets but did not work.
mqdean
by adafruit_support_bill on Mon Feb 05, 2018 7:59 am
Try adding a delay(100); to your setup().
by mqdean on Mon Feb 05, 2018 10:22 am
The delay did not work but I modified the code a little by changing the "<" and ">" with "==" for the "if" logic. The force is working now but the time code is not working. Below is the modified sketch.
int force;
int pixelCount = 0;
int currentMillis;
void loop()
    if (force == 30)
        while(force < 30) { } // do nothing.
    if (force == 60) // check for return to 'normal'
            strip.show();
mqdean
by mqdean on Mon Feb 05, 2018 10:23 am
What I understand is that the below code is not working.
mqdean
by mqdean on Mon Feb 05, 2018 10:25 am
When I apply pressure on the fsr for more than 5000 mills, the pixel still lights up when I release.
mqdean
by adafruit_support_bill on Mon Feb 05, 2018 2:34 pm
That is not likely to work well. The sensor is not guaranteed to ever generate that specific value. With analog sensors, you generally need to check for a range of values.
by mqdean on Mon Feb 05, 2018 3:20 pm
Is the below code meant to record the duration when the value is below 50 or is it meant to capture the time when it goes below 50.
if (force < 50)
mqdean
by adafruit_support_bill on Mon Feb 05, 2018 3:28 pm
It records the time when the value first goes below 50. Then it waits until the value goes back above 50.
by mqdean on Mon Feb 05, 2018 11:02 pm
Why do we have to use the below code
instead of
int impactTime
mqdean
by adafruit_support_bill on Tue Feb 06, 2018 8:35 am
Because an 'int' is a 16 bit signed integer. it can store values ranging from -32768 to +32767.
In milliseconds, that is a little over 32 seconds before it wraps around to be a negative number.
A 'long' is a 32 bit integer. That will run for about 25 days worth of milliseconds before wrapping around.
Technically, a better type to use would be uint32_t which is an unsigned 32 bit integer. That run for 49 days worth of milliseconds before wrapping back around to zero.
by mqdean on Tue Feb 06, 2018 9:22 am
Thank you for the explanation. Very useful.
In your recommended sketch, below, I have edited the "currentMillis()" to "currentMillis" thinking that it might have been a typo. If it was not a typo, please let me know.
Do I have to change the "int currentMillis;" to "long currentMillis as well;"?
int force;
int pixelCount = 0;
void loop()
    if (force < 50)
        impactTime = currentMillis();
        while(analogRead(9) < 50) { } // do nothing.
        if ((currentMillis() - impactTime) < 100)  // If less than 100 ms, record as a hit.
            strip.show();
mqdean
by adafruit_support_bill on Tue Feb 06, 2018 9:28 am
Yes, "currentMillis()" was a typo. It should not have the parenthesis.
And all variables holding millisecond values should be of type 'long' or 'uint32_t'.
by mqdean on Thu Feb 08, 2018 5:44 am
Any recommendation of books on arduino programming, something comprehensive.
mqdean
