Neopixel RBGW 60 LED/m Not Working
by rjangra on Tue Feb 28, 2017 12:39 am
Got my first Neopixel LED strip. This is a trial strip to get an idea about how easy/difficult it is to program a Neopixel strip before I start my actual project. Connected the strip to Adruino Uno board loaded with "strandtest". Only first LED goes through the color cycle. None of the other LEDs are powered. Tried powering the strip using 3 AA batteries as well as Uno board. Only the first LED will cycle through the colors.
Here's the code that I am using for strandtest. Any inputs to get other LEDs to work?
// Simple NeoPixel test.  Lights just a few pixels at a time so a
// 1m strip can safely be powered from Arduino 5V pin.  Arduino
// may nonetheless hiccup when LEDs are first connected and not
// accept code.  So upload code first, unplug USB, connect pixels
// to GND FIRST, then +5V and digital pin 6, then re-plug USB.
// A working strip will show a few pixels moving down the line,
// cycling between red, green and blue.  If you get no response,
// might be connected to wrong end of strip (the end wires, if
// any, are no indication -- look instead for the data direction
// arrows printed on the strip).
#define PIN      6
#define N_LEDS 60
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, PIN, NEO_RGBW + NEO_KHZ800);
  strip.begin();
  chase(strip.Color(255, 0, 0)); // Red
  chase(strip.Color(0, 255, 0)); // Green
  chase(strip.Color(0, 0, 255)); // Blue
static void chase(uint32_t c) {
  for(uint16_t i=0; i<strip.numPixels()+4; i++) {
      strip.setPixelColor(i  , c); // Draw new pixel
      strip.setPixelColor(i-4, 0); // Erase pixel a few steps back
      strip.show();
      delay(25);
rjangra
Re: Neopixel RBGW 60 LED/m Not Working
by __real__talk__ on Tue Feb 28, 2017 11:30 pm
Things to Check:
1. Make sure the ground from your separate power supply shares a ground with the Arduino Controller.
2. Verify you have data flowing in the right direction, check the arrow on the strip.
__real__talk__
by rjangra on Wed Mar 01, 2017 12:39 am
Thanks for your inputs. Connected negative from battery to ground on Arduino. Still the same result.
Here's some additional details about my connections.
1. LED strip has 4 wires - Red, Black and a group of White & Black
2. Strip end with these wires have signal arrow going away from that end and towards the other end.
3. Connections are
    Red - connected to external battery positive
    Black (2 in number) - connected to ground
    White - Arduino Digital 6
Attaching two pics, if that makes things a bit clear. Let me know if you have any other inputs.
Signal direction going away from Connectors
SignalDirection and Connectors.jpg (813.18 KiB) Viewed 438 times
Connections
__real__talk__ wrote:Things to Check:
rjangra
by __real__talk__ on Thu Mar 02, 2017 12:42 am
Did you get it working?
This is the RGBW Strandtest from the Adafruit Library.
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 6
#define NUM_LEDS 60
#define BRIGHTNESS 50
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRBW + NEO_KHZ800);
int gamma[] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1,
1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2,
2, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 5, 5, 5,
5, 6, 6, 6, 6, 7, 7, 7, 7, 8, 8, 8, 9, 9, 9, 10,
10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255 };
Serial.begin(115200);
// This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#if defined (__AVR_ATtiny85__)
if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
// End of trinket special code
strip.setBrightness(BRIGHTNESS);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// Some example procedures showing how to display to the pixels:
colorWipe(strip.Color(255, 0, 0), 50); // Red
colorWipe(strip.Color(0, 255, 0), 50); // Green
colorWipe(strip.Color(0, 0, 255), 50); // Blue
colorWipe(strip.Color(0, 0, 0, 255), 50); // White
whiteOverRainbow(20,75,5);
pulseWhite(5);
// fullWhite();
// delay(2000);
rainbowFade2White(3,3,1);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void pulseWhite(uint8_t wait) {
for(int j = 0; j < 256 ; j++){
strip.setPixelColor(i, strip.Color(0,0,0, gamma[j] ) );
delay(wait);
strip.show();
for(int j = 255; j >= 0 ; j--){
delay(wait);
strip.show();
void rainbowFade2White(uint8_t wait, int rainbowLoops, int whiteLoops) {
float fadeMax = 100.0;
int fadeVal = 0;
uint32_t wheelVal;
int redVal, greenVal, blueVal;
for(int k = 0 ; k < rainbowLoops ; k ++){
for(int j=0; j<256; j++) { // 5 cycles of all colors on wheel
for(int i=0; i< strip.numPixels(); i++) {
wheelVal = Wheel(((i * 256 / strip.numPixels()) + j) & 255);
redVal = red(wheelVal) * float(fadeVal/fadeMax);
greenVal = green(wheelVal) * float(fadeVal/fadeMax);
blueVal = blue(wheelVal) * float(fadeVal/fadeMax);
strip.setPixelColor( i, strip.Color( redVal, greenVal, blueVal ) );
//First loop, fade in!
if(k == 0 && fadeVal < fadeMax-1) {
fadeVal++;
//Last loop, fade out!
else if(k == rainbowLoops - 1 && j > 255 - fadeMax ){
fadeVal--;
strip.show();
delay(wait);
delay(500);
for(int k = 0 ; k < whiteLoops ; k ++){
for(uint16_t i=0; i < strip.numPixels(); i++) {
strip.show();
delay(2000);
strip.show();
delay(500);
void whiteOverRainbow(uint8_t wait, uint8_t whiteSpeed, uint8_t whiteLength ) {
if(whiteLength >= strip.numPixels()) whiteLength = strip.numPixels() - 1;
int head = whiteLength - 1;
int tail = 0;
int loops = 3;
int loopNum = 0;
static unsigned long lastTime = 0;
while(true){
if((i >= tail && i <= head) || (tail > head && i >= tail) || (tail > head && i <= head) ){
strip.setPixelColor(i, strip.Color(0,0,0, 255 ) );
else{
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
if(millis() - lastTime > whiteSpeed) {
head++;
tail++;
if(head == strip.numPixels()){
loopNum++;
lastTime = millis();
if(loopNum == loops) return;
head%=strip.numPixels();
tail%=strip.numPixels();
strip.show();
delay(wait);
void fullWhite() {
strip.show();
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256 * 5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.show();
delay(wait);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3,0);
if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3,0);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0,0);
uint8_t red(uint32_t c) {
return (c >> 8);
uint8_t green(uint32_t c) {
return (c >> 16);
uint8_t blue(uint32_t c) {
return (c);
__real__talk__
by rjangra on Fri Mar 03, 2017 8:48 pm
No luck. Still the same result. Only first LED will cycle through the color sequence. Though colors are much more dull than the RGB strandtest.
Is there a way to verify if something is wrong with the LED strip? Or how do I return it if I can't make it work?
__real__talk__ wrote:Did you get it working?
#ifdef __AVR__
#endif
#define PIN 6
#define NUM_LEDS 60
int gamma[] = {
#endif
strip.begin();
pulseWhite(5);
// fullWhite();
// delay(2000);
strip.show();
delay(wait);
delay(wait);
strip.show();
delay(wait);
strip.show();
int fadeVal = 0;
uint32_t wheelVal;
fadeVal++;
fadeVal--;
strip.show();
delay(wait);
delay(500);
strip.show();
delay(2000);
strip.show();
delay(500);
int tail = 0;
int loops = 3;
int loopNum = 0;
while(true){
else{
head++;
tail++;
loopNum++;
strip.show();
delay(wait);
void fullWhite() {
strip.show();
uint16_t i, j;
strip.show();
delay(wait);
uint16_t i, j;
strip.show();
delay(wait);
if(WheelPos < 85) {
WheelPos -= 85;
WheelPos -= 170;
return (c >> 8);
return (c >> 16);
return (c);
rjangra
by __real__talk__ on Fri Mar 03, 2017 11:24 pm
The dullness of the LEDS can be adjusted with this line of code in the definition "#define BRIGHTNESS 50". Brightness number can be made higher.
Sorry to hear that you are having issues. I also just started using Neopixels as well as the Arduino board. Everything worked right out the box. I put some other stuff you can try below. I made some bad connections the first time, and was a bit frustrated, especially with the coding, but learned how it worked pretty quickly. In the event you do have a bad LED strip, don't get frustrated with it. I would just contact Adafruit and let them know the issues you are having, and return the strip for a new one. If you also just purchased you Arduino Uno board, I would also exchange it.
I assume there are no errors when you compile the code and upload to the Arduino Uno board?
You can run a test by checking that each color is working on your strip.
In the RGBW Strandtest, where the loop starts (pasted below) adjust the code like below to check if your colors are working on your strip.
With the adjustment below, only red should light up.
After checking red, delete the Red line, and add back the green line, and continue until you have checked all the colors.
colorWipe(strip.Color(0, 255, 0), 50); // Green (Delete This Line)
colorWipe(strip.Color(0, 0, 255), 50); // Blue (Delete This Line)
colorWipe(strip.Color(0, 0, 0, 255), 50); // White (Delete This Line)
whiteOverRainbow(20,75,5); (Delete This Line)
pulseWhite(5); (Delete This Line)
// fullWhite(); (Delete This Line)
// delay(2000); (Delete This Line)
rainbowFade2White(3,3,1); (Delete This Line)
__real__talk__
by tliguori on Wed Oct 11, 2017 5:44 pm
Can anybody explain the wheel function at the bottom of the codes shown here?
I am self learning and decided to look into each part of this code to understand something new. I have my LED strip up and running these examples on my fish tank right now. I can follow most of these for loops and understand what they mean but the wheel is a very knew idea to me. I know what it does (cycle all 256 colors on the color wheel). I am more asking how that math works. 256 choices for each Red, Blue, and Green seems like more than 256 color combination. I am not super strong with the color wheel in general besides the basics. What is this code doing to pick each color? any knowledge shared is appreciated =]
also what is "uint32_t" that is all over the code? what do i need to know about it? i dont have a good answer right now incase a student ask
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
tliguori
by kcl1s on Wed Oct 11, 2017 8:49 pm
Here is a description I gave in another thread.
Basically the the code breaks the possible 255 choices of the wheel input into 3 sections of 85. Then the first 'if' does the math to fade two of the 3 colors (red and blue) from all one to all the other over 85 steps. The next 85 steps fade between another pair of colors (blue and green) and the last 85 steps fade between the final pair (green and red).
So yes you are not getting all conceivable combinations it is more about creating the ability to get a nice rainbow effect with an 8 bit integer.
uint32_t is a data type like int, float or long. It is an unsigned 32 bit integer. The 3 - 8 bit color values of a rgb pixel (or 4 - 8 bit values of a rgbw pixel) are bit shifted into this data type by the Neopixel library.
Keith
kcl1s
