Problem with NeoPixel 8X8 Matrix
Re: Problem with NeoPixel 8X8 Matrix
What program are you using to send data? Is it always sending a 255 before each number command?
- Maximvs
Yes of course.... C# code....if i send data without blink , everything works perfect!...When i send blink loop...when i change values...not work.
Please post the code.
- Maximvs
if (BriCHK.Checked == true)
serialData2[0] = 255;
serialData2[1] = Convert.ToByte(flagdebug);
serialData2[2] = Convert.ToByte(flagInt);
_sp5.Write(serialData2, 0, 3);
and then i send different values
private void BlueCheck_Click_1(object sender, EventArgs e)
flagdebug = 1;
private void YellowCheck_Click(object sender, EventArgs e)
flagdebug = 2;
private void RedCheck_Click(object sender, EventArgs e)
flagdebug = 3;
... e.t.c
flagdebug = 1;
flagdebug = 2;
flagdebug = 3;
... e.t.c
You are sending three bytes, but only reading two. It is not clear what the value of flagint is, but it looks like you will lose at least one command before you re-sync with the next 255.
- Maximvs
i change it but same results....This problem appears only when blink is set....if i send values 1,2,3,4 e.t.c matrix works perfect....is it weird?
Hard to say looking at only a fragment of the code. If you are sending commands continuously, it will take a while to work through the input buffer with the delays in your blinking code.
- Maximvs
yes i see....is there any other way to blink a matrix without delays?....with a timer maybe when values is change?....
You can use the millis() function for timing: https://learn.adafruit.com/multi-taskin ... for-timing
