128x64 PiOLED?
128x64 PiOLED?
by dchang0 on Thu Jun 08, 2017 2:51 am
I love the design of the 128x32 PiOLED.
But 4 lines of text isn't much. I'd love to see a 128x64 PiOLED, preferably in color, but monochrome is good enough.
It should still be possible to fit the 128x64 over a Pi Zero, though it would be a tight fit.
I figure the display would have to be moved a few mm closer to the camera connector end to allow post holes at both the upper left and bottom left corner (current design is just at the upper left corner).
Please consider making one--thanks!
dchang0
Re: 128x64 PiOLED?
by dchang0 on Wed Jun 14, 2017 2:22 am
Wow, that was fast!
https://blog.adafruit.com/2017/06/12/ne ... pberry-pi/
Very cool. and I do like the fact that it has buttons and a thumbstick.
dchang0
Re: 128x64 PiOLED?
by dchang0 on Wed Jun 28, 2017 4:54 am
I figured out how to get the Adafruit 128x64 OLED Bonnet working with the ODROID C1+ running Ubuntu 16.04 minimal.
It requires Luma.OLED's SSD1306 driver to drive the display:
https://github.com/rm-hull/luma.oled
And it requires HardKernel's ODROID port of WiringPi2 for Python.
https://github.com/hardkernel/WiringPi2-Python
The pin numbers after using .wiringPiSetup() are:
L = 2
R = 4
U = 0
D = 3
C = 7
A = 21
B = 22
I don't know why these pin numbers don't match what Adafruit designates in:
https://github.com/adafruit/Adafruit_Py ... buttons.py
But the above is what works.
Thanks, Adafruit for making this awesome bonnet. For a project, I needed a small OLED display with compact pushbuttons and a joystick for a handheld LIDAR scanner, and no hat or bonnet or the 3.2 TFT display with 3 buttons could cut it. This bonnet would have worked, although a color OLED would really have helped draw the LIDAR scan.
dchang0
Re: 128x64 PiOLED?
by WanderingArtist on Tue Dec 12, 2017 3:55 pm
Is there a way to drive this display from c++?
WanderingArtist
Re: 128x64 PiOLED?
by BruceLindbloom on Mon Mar 12, 2018 9:54 pm
Like WanderingArtist, I would like to drive this OLED bonnet from C++. Any suggestions would be most welcome.
I had a similar issue with the PaPiRus Zero pHAT (Adafruit product ID 3335), where all the software support is Python-based. I was able to successfully drive this display from C++ by using (and modifying a bit) code from https://github.com/repaper/gratis.
It would be nice to do something similar with the 128x64 PiOLED.
BruceLindbloom
