We have 4 faulty displays (ID 2423).
1. Backlight does not work
2. Crack in Glass (see photo)
3. Touch does not work
4. Touch does not work
Thanks for your help.
- tonic
- nok.jpg (67.75 KiB) Viewed 570 times
- adafruit_support_rick
Re: 4 faulty displays (ID 2423)
Check that the ribbon cable on the back of the TFT is fully seated and secured:
Also, please post the output of the command sudo dmesg- tonic
Thaks for your replay. The ribbon cable are ok on all 4 boards.
What's next?
What's next?
- 2423.jpg (107.35 KiB) Viewed 556 times
Please post the output of sudo dmesg
- tonic
display 1:
pi@raspberrypi:~ $ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.24-v7+ (root@vagrant-ubuntu-trusty-32) (gcc ver sion 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linar o GCC 2013.11) ) #1 SMP Mon Oct 10 21:48:58 UTC 2016
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 808aef80, node_mem_map b9fa600 0
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9520->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b9f62000 s22592 r8192 d22464 u5324 8
[ 0.000000] pcpu-alloc: s22592 r8192 d22464 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 239540
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 b cm2708_fb.fbheight=416 bcm2709.boardrev=0xa01041 bcm2709.serial=0x5c19f904 smsc9 5xx.macaddr=B8:27:EB:19:F9:04 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 bc m2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console= tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootw ait fbcon=map:10 fbcon=font:VGA8x8 quiet splash plymouth.ignore-serial-consoles
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 939152K/966656K available (6268K kernel code, 432K rwdata , 1716K rodata, 476K init, 764K bss, 19312K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x807d4484 (7986 kB)
.init : 0x807d5000 - 0x8084c000 ( 476 kB)
.data : 0x8084c000 - 0x808b82c0 ( 433 kB)
.bss : 0x808bb000 - 0x8097a1ec ( 765 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 43980 46511078ns
[ 0.000031] Switching to timer-based delay loop, resolution 52ns
[ 0.000346] Console: colour dummy device 80x30
[ 0.000575] console [tty1] enabled
[ 0.000605] Calibrating delay loop (skipped), value calculated using timer fr equency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000629] pid_max: default: 32768 minimum: 301
[ 0.001009] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001030] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002238] Disabling cpuset control group subsystem
[ 0.002286] Initializing cgroup subsys io
[ 0.002322] Initializing cgroup subsys memory
[ 0.002384] Initializing cgroup subsys devices
[ 0.002410] Initializing cgroup subsys freezer
[ 0.002436] Initializing cgroup subsys net_cls
[ 0.002508] CPU: Testing write buffer coherency: ok
[ 0.002593] ftrace: allocating 21216 entries in 63 pages
[ 0.055416] CPU0: update cpu_capacity 1024
[ 0.055453] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.055470] [bcm2709_smp_prepare_cpus] enter
[ 0.055611] Setting up static identity map for 0x8240 - 0x8274
[ 0.057993] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.058356] [bcm2709_secondary_init] enter cpu:1
[ 0.058410] CPU1: update cpu_capacity 1024
[ 0.058418] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.058980] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.059268] [bcm2709_secondary_init] enter cpu:2
[ 0.059300] CPU2: update cpu_capacity 1024
[ 0.059308] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.059845] [bcm2709_boot_secondary] cpu:3 started (0) 16
[ 0.060100] [bcm2709_secondary_init] enter cpu:3
[ 0.060128] CPU3: update cpu_capacity 1024
[ 0.060136] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.060223] Brought up 4 CPUs
[ 0.060253] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.060263] CPU: All CPU(s) started in HYP mode.
[ 0.060272] CPU: Virtualization extensions available.
[ 0.061177] devtmpfs: initialized
[ 0.075315] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.075795] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns
[ 0.076801] pinctrl core: initialized pinctrl subsystem
[ 0.077599] NET: Registered protocol family 16
[ 0.083532] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.092587] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.092605] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.092815] Serial: AMBA PL011 UART driver
[ 0.093146] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.093571] console [ttyAMA0] enabled
[ 0.094215] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.168430] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dma chans=0x1
[ 0.169185] SCSI subsystem initialized
[ 0.169423] usbcore: registered new interface driver usbfs
[ 0.169534] usbcore: registered new interface driver hub
[ 0.169692] usbcore: registered new device driver usb
[ 0.175013] raspberrypi-firmware soc:firmware: Attached to firmware from 2016 -09-21 13:13
[ 0.202660] clocksource: Switched to clocksource arch_sys_counter
[ 0.252856] FS-Cache: Loaded
[ 0.253252] CacheFiles: Loaded
[ 0.269778] NET: Registered protocol family 2
[ 0.271011] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.271165] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.271372] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.271502] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.271566] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.271905] NET: Registered protocol family 1
[ 0.272400] RPC: Registered named UNIX socket transport module.
[ 0.272416] RPC: Registered udp transport module.
[ 0.272427] RPC: Registered tcp transport module.
[ 0.272437] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.273987] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counter s available
[ 0.275693] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.291606] VFS: Disk quotas dquot_6.6.0
[ 0.291982] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.294659] FS-Cache: Netfs 'nfs' registered for caching
[ 0.295837] NFS: Registering the id_resolver key type
[ 0.295918] Key type id_resolver registered
[ 0.295930] Key type id_legacy registered
[ 0.299012] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 52)
[ 0.299207] io scheduler noop registered
[ 0.299235] io scheduler deadline registered (default)
[ 0.299320] io scheduler cfq registered
[ 0.302212] BCM2708FB: allocated DMA memory fac00000
[ 0.302257] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.312005] Console: switching to colour frame buffer device 82x52
[ 1.134971] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.135204] vc-cma: Videocore CMA driver
[ 1.135220] vc-cma: vc_cma_base = 0x00000000
[ 1.135231] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.135242] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.135586] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000 000(1008 MiB)
[ 1.155822] brd: module loaded
[ 1.166942] loop: module loaded
[ 1.168062] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 1.169804] Loading iSCSI transport class v2.0-870.
[ 1.170726] usbcore: registered new interface driver smsc95xx
[ 1.170807] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.371151] Core Release: 2.80a
[ 1.371181] Setting default values for core params
[ 1.371230] Finished setting default values for core params
[ 1.571687] Using Buffer DMA mode
[ 1.571702] Periodic Transfer Interrupt Enhancement - disabled
[ 1.571713] Multiprocessor Interrupt Enhancement - disabled
[ 1.571724] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.571746] Dedicated Tx FIFOs mode
[ 1.572199] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac 14000 dma = 0xfac14000 len=9024
[ 1.572238] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 1.572267] dwc_otg: Microframe scheduler enabled
[ 1.572333] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x804379d0
[ 1.572351] WARN::hcd_init_fiq:414: FIQ ASM at 0x80437d2c length 36
[ 1.572370] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb87e000
[ 1.572458] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.572510] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.572561] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.572617] Init: Port Power? op_state=1
[ 1.572627] Init: Power Port (0)
[ 1.572962] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.572982] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.572998] usb usb1: Product: DWC OTG Controller
[ 1.573014] usb usb1: Manufacturer: Linux 4.4.24-v7+ dwc_otg_hcd
[ 1.573029] usb usb1: SerialNumber: 3f980000.usb
[ 1.574102] hub 1-0:1.0: USB hub found
[ 1.574169] hub 1-0:1.0: 1 port detected
[ 1.574907] dwc_otg: FIQ enabled
[ 1.574921] dwc_otg: NAK holdoff enabled
[ 1.574931] dwc_otg: FIQ split-transaction FSM enabled
[ 1.574985] Module dwc_common_port init
[ 1.575366] usbcore: registered new interface driver usb-storage
[ 1.575745] mousedev: PS/2 mouse device common for all mice
[ 1.576685] bcm2835-cpufreq: min=600000 max=900000
[ 1.577045] sdhci: Secure Digital Host Controller Interface driver
[ 1.577057] sdhci: Copyright(c) Pierre Ossman
[ 1.577463] sdhost: log_buf @ bac13000 (fac13000)
[ 1.632704] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.633037] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.633726] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.633946] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.634185] usbcore: registered new interface driver usbhid
[ 1.634196] usbhid: USB HID core driver
[ 1.634848] Initializing XFRM netlink socket
[ 1.634901] NET: Registered protocol family 17
[ 1.635075] Key type dns_resolver registered
[ 1.635845] Registering SWP/SWPB emulation handler
[ 1.636975] registered taskstats version 1
[ 1.637234] vc-sm: Videocore shared memory driver
[ 1.637254] [vc_sm_connected_init]: start
[ 1.653721] [vc_sm_connected_init]: end - returning 0
[ 1.654178] of_cfs_init
[ 1.654294] of_cfs_init: OK
[ 1.655516] Waiting for root device /dev/mmcblk0p2...
[ 1.689996] mmc0: host does not support reading read-only switch, assuming wr ite-enable
[ 1.691984] mmc0: new high speed SDHC card at address 0001
[ 1.692874] mmcblk0: mmc0:0001 SD8GB 7.32 GiB
[ 1.694787] mmcblk0: p1 p2
[ 1.765921] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesyst em
[ 1.765940] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.772843] Indeed it is in host mode hprt0 = 00021501
[ 1.952710] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.952888] Indeed it is in host mode hprt0 = 00001101
[ 2.153059] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.153082] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.154064] hub 1-1:1.0: USB hub found
[ 2.154191] hub 1-1:1.0: 5 ports detected
[ 2.432754] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.533085] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.533113] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[ 2.536196] smsc95xx v1.0.4
[ 2.596924] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb- 1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:19:f9:04
[ 2.760955] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 2.761846] EXT4-fs (mmcblk0p2): 5 orphan inodes deleted
[ 2.761863] EXT4-fs (mmcblk0p2): recovery complete
[ 2.830356] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null)
[ 2.830436] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.838507] devtmpfs: mounted
[ 2.839307] Freeing unused kernel memory: 476K (807d5000 - 8084c000)
[ 3.135044] random: systemd: uninitialized urandom read (16 bytes read, 71 bi ts of entropy available)
[ 3.140493] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SEL INUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -BANNED)
[ 3.140969] systemd[1]: Detected architecture 'arm'.
[ 3.254947] NET: Registered protocol family 10
[ 3.257049] systemd[1]: Inserted module 'ipv6'
[ 3.259530] systemd[1]: Set hostname to <raspberrypi>.
[ 3.356902] uart-pl011 3f201000.uart: no DMA platform data
[ 3.406820] random: systemd-sysv-ge: uninitialized urandom read (16 bytes rea d, 73 bits of entropy available)
[ 3.520335] random: systemd: uninitialized urandom read (16 bytes read, 74 bi ts of entropy available)
[ 3.522036] random: systemd: uninitialized urandom read (16 bytes read, 74 bi ts of entropy available)
[ 3.523993] random: systemd: uninitialized urandom read (16 bytes read, 74 bi ts of entropy available)
[ 3.546637] random: systemd: uninitialized urandom read (16 bytes read, 75 bi ts of entropy available)
[ 3.547657] random: systemd: uninitialized urandom read (16 bytes read, 75 bi ts of entropy available)
[ 3.547905] random: systemd: uninitialized urandom read (16 bytes read, 75 bi ts of entropy available)
[ 3.598471] random: systemd: uninitialized urandom read (16 bytes read, 75 bi ts of entropy available)
[ 3.602493] random: systemd: uninitialized urandom read (16 bytes read, 75 bi ts of entropy available)
[ 3.771677] systemd[1]: Expecting device dev-ttyAMA0.device...
[ 3.772198] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 3.772536] systemd[1]: Started Forward Password Requests to Wall Directory W atch.
[ 3.772730] systemd[1]: Starting Remote File Systems (Pre).
[ 3.772842] systemd[1]: Reached target Remote File Systems (Pre).
[ 3.773059] systemd[1]: Starting Arbitrary Executable File Formats File Syste m Automount Point.
[ 3.773752] systemd[1]: Set up automount Arbitrary Executable File Formats Fi le System Automount Point.
[ 3.773882] systemd[1]: Starting Encrypted Volumes.
[ 3.773981] systemd[1]: Reached target Encrypted Volumes.
[ 3.774091] systemd[1]: Starting Swap.
[ 3.774186] systemd[1]: Reached target Swap.
[ 3.774284] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 3.774382] systemd[1]: Starting Root Slice.
[ 3.774581] systemd[1]: Created slice Root Slice.
[ 3.774676] systemd[1]: Starting User and Session Slice.
[ 3.774991] systemd[1]: Created slice User and Session Slice.
[ 3.775089] systemd[1]: Starting Delayed Shutdown Socket.
[ 3.775330] systemd[1]: Listening on Delayed Shutdown Socket.
[ 3.775429] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 3.775689] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.775785] systemd[1]: Starting Journal Socket (/dev/log).
[ 3.776076] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.776203] systemd[1]: Starting udev Control Socket.
[ 3.776415] systemd[1]: Listening on udev Control Socket.
[ 3.776533] systemd[1]: Starting udev Kernel Socket.
[ 3.776712] systemd[1]: Listening on udev Kernel Socket.
[ 3.776828] systemd[1]: Starting Journal Socket.
[ 3.777096] systemd[1]: Listening on Journal Socket.
[ 3.777255] systemd[1]: Starting System Slice.
[ 3.777560] systemd[1]: Created slice System Slice.
[ 3.777724] systemd[1]: Starting File System Check on Root Device...
[ 3.803567] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 3.804117] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.804301] systemd[1]: Starting system-autologin.slice.
[ 3.804703] systemd[1]: Created slice system-autologin.slice.
[ 3.804806] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 3.805212] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 3.805563] systemd[1]: Starting Increase datagram queue length...
[ 3.809367] systemd[1]: Starting Restore / save the current clock...
[ 3.820724] systemd[1]: Mounted Huge Pages File System.
[ 3.820904] systemd[1]: Starting udev Coldplug all Devices...
[ 3.825444] systemd[1]: Mounting Debug File System...
[ 3.856287] systemd[1]: Started Set Up Additional Binary Formats.
[ 3.856957] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 3.862002] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.921031] systemd[1]: Starting Load Kernel Modules...
[ 3.926607] systemd[1]: Starting Slices.
[ 3.926754] systemd[1]: Reached target Slices.
[ 3.932605] systemd[1]: Started Create list of required static device nodes f or the current kernel.
[ 3.982179] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.982760] systemd[1]: Mounted Debug File System.
[ 3.986492] systemd[1]: Started Increase datagram queue length.
[ 4.000166] fuse init (API version 7.23)
[ 4.043913] i2c /dev entries driver
[ 4.047646] systemd[1]: Started udev Coldplug all Devices.
[ 4.061353] Adafruit Industries' power switch driver v1.7
[ 4.067900] systemd[1]: Started Restore / save the current clock.
[ 4.069766] systemd[1]: Started Load Kernel Modules.
[ 4.088533] systemd[1]: Time has been changed
[ 4.137603] systemd[1]: Started File System Check on Root Device.
[ 4.211175] systemd[1]: Mounting FUSE Control File System...
[ 4.243831] systemd[1]: Mounting Configuration File System...
[ 4.247170] systemd[1]: Starting Apply Kernel Variables...
[ 4.251817] systemd[1]: Starting Syslog Socket.
[ 4.252315] systemd[1]: Listening on Syslog Socket.
[ 4.252573] systemd[1]: Starting Journal Service...
[ 4.257738] systemd[1]: Started Journal Service.
[ 4.455309] systemd-udevd[136]: starting version 215
[ 4.952592] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 5.030967] input: ft6x06_ts as /devices/virtual/input/input0
[ 5.205761] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 83) (baudrate 100000)
[ 5.213079] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f2 00000
[ 5.225691] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.417062] fbtft: module is from the staging directory, the quality is unkno wn, you have been warned.
[ 5.423725] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.425403] fbtft_of_value: buswidth = 8
[ 5.425430] fbtft_of_value: debug = 0
[ 5.425442] fbtft_of_value: rotate = 90
[ 5.425455] fbtft_of_value: fps = 20
[ 5.629816] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video mem ory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 5.895724] systemd-journald[130]: Received request to flush runtime journal from PID 1
[ 8.217047] Adding 102396k swap on /var/swap. Priority:-1 extents:3 across:4 87420k SSFS
[ 8.291665] cfg80211: World regulatory domain updated:
[ 8.291699] cfg80211: DFS Master region: unset
[ 8.291709] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gai n, max_eirp), (dfs_cac_time)
[ 8.291722] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 m Bm), (N/A)
[ 8.291733] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 m Bm), (N/A)
[ 8.291745] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 m Bm), (N/A)
[ 8.291758] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AU TO), (N/A, 2000 mBm), (N/A)
[ 8.291770] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AU TO), (N/A, 2000 mBm), (0 s)
[ 8.291780] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 8.291791] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 m Bm), (N/A)
[ 8.291801] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 8.464955] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 8.465241] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.091570] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.093348] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E 1
[ 10.994493] random: nonblocking pool is initialized
[ 15.097901] Bluetooth: Core ver 2.21
[ 15.099477] NET: Registered protocol family 31
[ 15.099525] Bluetooth: HCI device and connection manager initialized
[ 15.099630] Bluetooth: HCI socket layer initialized
[ 15.099668] Bluetooth: L2CAP socket layer initialized
[ 15.099745] Bluetooth: SCO socket layer initialized
[ 15.131888] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.131917] Bluetooth: BNEP filters: protocol multicast
[ 15.131945] Bluetooth: BNEP socket layer initialized
- tonic
display 2:
[ 0.000000] Linux version 4.4.24-v7+ (root@vagrant-ubuntu-trusty-32) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #1 SMP Mon Oct 10 21:48:58 UTC 2016
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] free_area_init_node: node 0, pgdat 808aef80, node_mem_map b9fa6000
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b9f62000 s22592 r8192 d22464 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa01041 bcm2709.serial=0x5c19f904 smsc95xx.macaddr=B8:27:EB:19:F9:04 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait fbcon=map:10 fbcon=font:VGA8x8 quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Memory: 939152K/966656K available (6268K kernel code, 432K rwdata, 1716K rodata, 476K init, 764K bss, 19312K reserved, 8192K cma-reserved)
[ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000030] Switching to timer-based delay loop, resolution 52ns
[ 0.000344] Console: colour dummy device 80x30
[ 0.000574] console [tty1] enabled
[ 0.000604] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000628] pid_max: default: 32768 minimum: 301
[ 0.001003] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001023] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002218] Disabling cpuset control group subsystem
[ 0.002263] Initializing cgroup subsys io
[ 0.002298] Initializing cgroup subsys memory
[ 0.002357] Initializing cgroup subsys devices
[ 0.002382] Initializing cgroup subsys freezer
[ 0.002407] Initializing cgroup subsys net_cls
[ 0.002477] CPU: Testing write buffer coherency: ok
[ 0.002563] ftrace: allocating 21216 entries in 63 pages
[ 0.055568] CPU0: update cpu_capacity 1024
[ 0.055606] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.055624] [bcm2709_smp_prepare_cpus] enter
[ 0.055768] Setting up static identity map for 0x8240 - 0x8274
[ 0.058155] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.058516] [bcm2709_secondary_init] enter cpu:1
[ 0.058574] CPU1: update cpu_capacity 1024
[ 0.058582] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.059149] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.059435] [bcm2709_secondary_init] enter cpu:2
[ 0.059465] CPU2: update cpu_capacity 1024
[ 0.059473] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.060009] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.060263] [bcm2709_secondary_init] enter cpu:3
[ 0.060292] CPU3: update cpu_capacity 1024
[ 0.060300] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.060386] Brought up 4 CPUs
[ 0.060416] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.060426] CPU: All CPU(s) started in HYP mode.
[ 0.060435] CPU: Virtualization extensions available.
[ 0.061334] devtmpfs: initialized
[ 0.075469] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.075947] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.076946] pinctrl core: initialized pinctrl subsystem
[ 0.077745] NET: Registered protocol family 16
[ 0.083676] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.092722] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.092742] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.092954] Serial: AMBA PL011 UART driver
[ 0.093284] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.093707] console [ttyAMA0] enabled
[ 0.094348] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.168556] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.169310] SCSI subsystem initialized
[ 0.169555] usbcore: registered new interface driver usbfs
[ 0.169669] usbcore: registered new interface driver hub
[ 0.169827] usbcore: registered new device driver usb
[ 0.175144] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-09-21 13:13
[ 0.202791] clocksource: Switched to clocksource arch_sys_counter
[ 0.253013] FS-Cache: Loaded
[ 0.253414] CacheFiles: Loaded
[ 0.269939] NET: Registered protocol family 2
[ 0.271162] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.271315] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.271522] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.271653] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.271716] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.272055] NET: Registered protocol family 1
[ 0.272556] RPC: Registered named UNIX socket transport module.
[ 0.272575] RPC: Registered udp transport module.
[ 0.272585] RPC: Registered tcp transport module.
[ 0.272595] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.274162] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.275860] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.291753] VFS: Disk quotas dquot_6.6.0
[ 0.292131] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.294801] FS-Cache: Netfs 'nfs' registered for caching
[ 0.295972] NFS: Registering the id_resolver key type
[ 0.296046] Key type id_resolver registered
[ 0.296059] Key type id_legacy registered
[ 0.299155] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.299351] io scheduler noop registered
[ 0.299379] io scheduler deadline registered (default)
[ 0.299465] io scheduler cfq registered
[ 0.302369] BCM2708FB: allocated DMA memory fac00000
[ 0.302412] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.312158] Console: switching to colour frame buffer device 82x52
[ 1.145608] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.145879] vc-cma: Videocore CMA driver
[ 1.145895] vc-cma: vc_cma_base = 0x00000000
[ 1.145907] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.145918] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.146319] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.166330] brd: module loaded
[ 1.177391] loop: module loaded
[ 1.178539] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 1.180258] Loading iSCSI transport class v2.0-870.
[ 1.181152] usbcore: registered new interface driver smsc95xx
[ 1.181233] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.381590] Core Release: 2.80a
[ 1.381631] Setting default values for core params
[ 1.381682] Finished setting default values for core params
[ 1.582115] Using Buffer DMA mode
[ 1.582131] Periodic Transfer Interrupt Enhancement - disabled
[ 1.582142] Multiprocessor Interrupt Enhancement - disabled
[ 1.582153] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.582172] Dedicated Tx FIFOs mode
[ 1.582588] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 1.582626] FIQ FSM acceleration enabled for :
[ 1.582655] dwc_otg: Microframe scheduler enabled
[ 1.582720] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x804379d0
[ 1.582738] WARN::hcd_init_fiq:414: FIQ ASM at 0x80437d2c length 36
[ 1.582757] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb87e000
[ 1.582846] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.582899] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.582950] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.583006] Init: Port Power? op_state=1
[ 1.583017] Init: Power Port (0)
[ 1.583303] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.583323] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.583339] usb usb1: Product: DWC OTG Controller
[ 1.583355] usb usb1: Manufacturer: Linux 4.4.24-v7+ dwc_otg_hcd
[ 1.583370] usb usb1: SerialNumber: 3f980000.usb
[ 1.584427] hub 1-0:1.0: USB hub found
[ 1.584494] hub 1-0:1.0: 1 port detected
[ 1.585231] dwc_otg: FIQ enabled
[ 1.585243] dwc_otg: NAK holdoff enabled
[ 1.585253] dwc_otg: FIQ split-transaction FSM enabled
[ 1.585306] Module dwc_common_port init
[ 1.585694] usbcore: registered new interface driver usb-storage
[ 1.586063] mousedev: PS/2 mouse device common for all mice
[ 1.586972] bcm2835-cpufreq: min=600000 max=900000
[ 1.587340] sdhci: Secure Digital Host Controller Interface driver
[ 1.587352] sdhci: Copyright(c) Pierre Ossman
[ 1.587746] sdhost: log_buf @ bac13000 (fac13000)
[ 1.642832] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.643168] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.643859] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.644081] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.644335] usbcore: registered new interface driver usbhid
[ 1.644346] usbhid: USB HID core driver
[ 1.645021] Initializing XFRM netlink socket
[ 1.645074] NET: Registered protocol family 17
[ 1.645253] Key type dns_resolver registered
[ 1.645995] Registering SWP/SWPB emulation handler
[ 1.647135] registered taskstats version 1
[ 1.647392] vc-sm: Videocore shared memory driver
[ 1.647413] [vc_sm_connected_init]: start
[ 1.663844] [vc_sm_connected_init]: end - returning 0
[ 1.664287] of_cfs_init
[ 1.664404] of_cfs_init: OK
[ 1.665606] Waiting for root device /dev/mmcblk0p2...
[ 1.700012] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.701989] mmc0: new high speed SDHC card at address 0001
[ 1.702884] mmcblk0: mmc0:0001 SD8GB 7.32 GiB
[ 1.704816] mmcblk0: p1 p2
[ 1.775076] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.775096] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.782978] Indeed it is in host mode hprt0 = 00021501
[ 1.962877] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.963084] Indeed it is in host mode hprt0 = 00001101
[ 2.163164] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.163187] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.164191] hub 1-1:1.0: USB hub found
[ 2.164320] hub 1-1:1.0: 5 ports detected
[ 2.212180] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 2.212612] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[ 2.212629] EXT4-fs (mmcblk0p2): recovery complete
[ 2.259728] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.259806] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.261098] devtmpfs: mounted
[ 2.261886] Freeing unused kernel memory: 476K (807d5000 - 8084c000)
[ 2.442869] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.543233] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.543260] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.546298] smsc95xx v1.0.4
[ 2.566628] random: systemd: uninitialized urandom read (16 bytes read, 65 bits of entropy available)
[ 2.572143] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -BANNED)
[ 2.572629] systemd[1]: Detected architecture 'arm'.
[ 2.607091] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:19:f9:04
[ 2.687641] NET: Registered protocol family 10
[ 2.689703] systemd[1]: Inserted module 'ipv6'
[ 2.692198] systemd[1]: Set hostname to <raspberrypi>.
[ 2.809867] uart-pl011 3f201000.uart: no DMA platform data
[ 2.840844] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[ 2.957530] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 2.959274] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 2.961188] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 2.984437] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 2.985487] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 2.985737] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 3.037566] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 3.041726] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 3.214698] systemd[1]: Expecting device dev-ttyAMA0.device...
[ 3.215245] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 3.215572] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.215685] systemd[1]: Starting Remote File Systems (Pre).
[ 3.215787] systemd[1]: Reached target Remote File Systems (Pre).
[ 3.216002] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 3.216669] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.216796] systemd[1]: Starting Encrypted Volumes.
[ 3.216894] systemd[1]: Reached target Encrypted Volumes.
[ 3.217003] systemd[1]: Starting Swap.
[ 3.217094] systemd[1]: Reached target Swap.
[ 3.217193] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 3.217288] systemd[1]: Starting Root Slice.
[ 3.217485] systemd[1]: Created slice Root Slice.
[ 3.217582] systemd[1]: Starting User and Session Slice.
[ 3.217895] systemd[1]: Created slice User and Session Slice.
[ 3.217993] systemd[1]: Starting Delayed Shutdown Socket.
[ 3.218229] systemd[1]: Listening on Delayed Shutdown Socket.
[ 3.218329] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 3.218626] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.218727] systemd[1]: Starting Journal Socket (/dev/log).
[ 3.218986] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.219111] systemd[1]: Starting udev Control Socket.
[ 3.219330] systemd[1]: Listening on udev Control Socket.
[ 3.219448] systemd[1]: Starting udev Kernel Socket.
[ 3.219616] systemd[1]: Listening on udev Kernel Socket.
[ 3.219733] systemd[1]: Starting Journal Socket.
[ 3.219993] systemd[1]: Listening on Journal Socket.
[ 3.220150] systemd[1]: Starting System Slice.
[ 3.220457] systemd[1]: Created slice System Slice.
[ 3.220619] systemd[1]: Starting File System Check on Root Device...
[ 3.263714] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 3.264267] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.264446] systemd[1]: Starting system-autologin.slice.
[ 3.264857] systemd[1]: Created slice system-autologin.slice.
[ 3.264961] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 3.265347] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 3.265657] systemd[1]: Starting Increase datagram queue length...
[ 3.269962] systemd[1]: Starting Restore / save the current clock...
[ 3.276676] systemd[1]: Mounted Huge Pages File System.
[ 3.276943] systemd[1]: Starting udev Coldplug all Devices...
[ 3.282041] systemd[1]: Mounting Debug File System...
[ 3.311837] systemd[1]: Started Set Up Additional Binary Formats.
[ 3.312865] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 3.319048] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.381055] systemd[1]: Starting Load Kernel Modules...
[ 3.386243] systemd[1]: Starting Slices.
[ 3.386397] systemd[1]: Reached target Slices.
[ 3.396939] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 3.425897] systemd[1]: Started Increase datagram queue length.
[ 3.427362] systemd[1]: Mounted Debug File System.
[ 3.428773] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.466282] fuse init (API version 7.23)
[ 3.478138] systemd[1]: Started udev Coldplug all Devices.
[ 3.502106] i2c /dev entries driver
[ 3.516125] Adafruit Industries' power switch driver v1.7
[ 3.528161] systemd[1]: Started Restore / save the current clock.
[ 3.530015] systemd[1]: Started Load Kernel Modules.
[ 3.545289] systemd[1]: Time has been changed
[ 3.625001] systemd[1]: Started File System Check on Root Device.
[ 3.665578] systemd[1]: Mounting FUSE Control File System...
[ 3.703845] systemd[1]: Mounting Configuration File System...
[ 3.707542] systemd[1]: Starting Apply Kernel Variables...
[ 3.711779] systemd[1]: Starting Syslog Socket.
[ 3.712324] systemd[1]: Listening on Syslog Socket.
[ 3.712742] systemd[1]: Starting Journal Service...
[ 3.720488] systemd[1]: Started Journal Service.
[ 3.936175] systemd-udevd[136]: starting version 215
[ 4.402229] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 4.431434] input: ft6x06_ts as /devices/virtual/input/input0
[ 4.595403] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 83) (baudrate 100000)
[ 4.606027] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.687361] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.964832] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.976753] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.978812] fbtft_of_value: buswidth = 8
[ 4.978841] fbtft_of_value: debug = 0
[ 4.978854] fbtft_of_value: rotate = 90
[ 4.978870] fbtft_of_value: fps = 20
[ 5.184037] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 5.410655] systemd-journald[131]: Received request to flush runtime journal from PID 1
[ 7.724562] Adding 102396k swap on /var/swap. Priority:-1 extents:3 across:487420k SSFS
[ 7.792269] cfg80211: World regulatory domain updated:
[ 7.792296] cfg80211: DFS Master region: unset
[ 7.792306] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.792318] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.792329] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.792339] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.792352] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.792364] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.792375] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.792385] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.792395] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 8.293377] random: nonblocking pool is initialized
[ 8.295242] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 8.295485] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.938704] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.941751] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 14.620169] Bluetooth: Core ver 2.21
[ 14.620906] NET: Registered protocol family 31
[ 14.620926] Bluetooth: HCI device and connection manager initialized
[ 14.620963] Bluetooth: HCI socket layer initialized
[ 14.620982] Bluetooth: L2CAP socket layer initialized
[ 14.621047] Bluetooth: SCO socket layer initialized
[ 14.665925] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.665955] Bluetooth: BNEP filters: protocol multicast
[ 14.665989] Bluetooth: BNEP socket layer initialized
- tonic
display 3:
[ 0.000347] Console: colour dummy device 80x30
[ 0.000581] console [tty1] enabled
[ 0.000610] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000634] pid_max: default: 32768 minimum: 301
[ 0.001006] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001027] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002221] Disabling cpuset control group subsystem
[ 0.002265] Initializing cgroup subsys io
[ 0.002299] Initializing cgroup subsys memory
[ 0.002355] Initializing cgroup subsys devices
[ 0.002406] Initializing cgroup subsys net_cls
[ 0.002474] CPU: Testing write buffer coherency: ok
[ 0.055453] CPU0: update cpu_capacity 1024
[ 0.055488] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.055506] [bcm2709_smp_prepare_cpus] enter
[ 0.055642] Setting up static identity map for 0x8240 - 0x8274
[ 0.058021] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.058383] [bcm2709_secondary_init] enter cpu:1
[ 0.058436] CPU1: update cpu_capacity 1024
[ 0.058444] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.059010] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.059297] [bcm2709_secondary_init] enter cpu:2
[ 0.059328] CPU2: update cpu_capacity 1024
[ 0.059336] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.059866] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.060121] [bcm2709_secondary_init] enter cpu:3
[ 0.060150] CPU3: update cpu_capacity 1024
[ 0.060158] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.060243] Brought up 4 CPUs
[ 0.060273] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.060283] CPU: All CPU(s) started in HYP mode.
[ 0.060292] CPU: Virtualization extensions available.
[ 0.061193] devtmpfs: initialized
[ 0.075335] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.075822] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.076832] pinctrl core: initialized pinctrl subsystem
[ 0.077624] NET: Registered protocol family 16
[ 0.083559] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.092607] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.092627] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.092836] Serial: AMBA PL011 UART driver
[ 0.093168] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.093592] console [ttyAMA0] enabled
[ 0.094238] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.168480] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.169239] SCSI subsystem initialized
[ 0.169481] usbcore: registered new interface driver usbfs
[ 0.169595] usbcore: registered new interface driver hub
[ 0.169753] usbcore: registered new device driver usb
[ 0.175058] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-09-21 13:13
[ 0.202701] clocksource: Switched to clocksource arch_sys_counter
[ 0.252899] FS-Cache: Loaded
[ 0.253296] CacheFiles: Loaded
[ 0.269735] NET: Registered protocol family 2
[ 0.270961] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.271113] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.271320] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.271450] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.271514] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.271853] NET: Registered protocol family 1
[ 0.272351] RPC: Registered named UNIX socket transport module.
[ 0.272368] RPC: Registered udp transport module.
[ 0.272378] RPC: Registered tcp transport module.
[ 0.272389] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.273956] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.275652] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.291575] VFS: Disk quotas dquot_6.6.0
[ 0.291952] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.294632] FS-Cache: Netfs 'nfs' registered for caching
[ 0.295794] NFS: Registering the id_resolver key type
[ 0.295864] Key type id_resolver registered
[ 0.295877] Key type id_legacy registered
[ 0.299009] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.299208] io scheduler noop registered
[ 0.299237] io scheduler deadline registered (default)
[ 0.299321] io scheduler cfq registered
[ 0.302224] BCM2708FB: allocated DMA memory fac00000
[ 0.302268] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.312020] Console: switching to colour frame buffer device 82x52
[ 1.142716] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.142990] vc-cma: Videocore CMA driver
[ 1.143006] vc-cma: vc_cma_base = 0x00000000
[ 1.143019] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.143029] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.143452] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.163584] brd: module loaded
[ 1.174630] loop: module loaded
[ 1.175784] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 1.177525] Loading iSCSI transport class v2.0-870.
[ 1.178405] usbcore: registered new interface driver smsc95xx
[ 1.178484] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.378836] Core Release: 2.80a
[ 1.378877] Setting default values for core params
[ 1.378927] Finished setting default values for core params
[ 1.579366] Using Buffer DMA mode
[ 1.579382] Periodic Transfer Interrupt Enhancement - disabled
[ 1.579392] Multiprocessor Interrupt Enhancement - disabled
[ 1.579403] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.579423] Dedicated Tx FIFOs mode
[ 1.579848] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 1.579887] FIQ FSM acceleration enabled for :
[ 1.579915] dwc_otg: Microframe scheduler enabled
[ 1.579981] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x804379d0
[ 1.579999] WARN::hcd_init_fiq:414: FIQ ASM at 0x80437d2c length 36
[ 1.580018] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb87e000
[ 1.580105] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.580155] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.580205] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.580262] Init: Port Power? op_state=1
[ 1.580273] Init: Power Port (0)
[ 1.580569] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.580589] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.580605] usb usb1: Product: DWC OTG Controller
[ 1.580621] usb usb1: Manufacturer: Linux 4.4.24-v7+ dwc_otg_hcd
[ 1.580636] usb usb1: SerialNumber: 3f980000.usb
[ 1.581683] hub 1-0:1.0: USB hub found
[ 1.581749] hub 1-0:1.0: 1 port detected
[ 1.582500] dwc_otg: FIQ enabled
[ 1.582513] dwc_otg: NAK holdoff enabled
[ 1.582525] dwc_otg: FIQ split-transaction FSM enabled
[ 1.582566] Module dwc_common_port init
[ 1.583036] usbcore: registered new interface driver usb-storage
[ 1.583419] mousedev: PS/2 mouse device common for all mice
[ 1.584350] bcm2835-cpufreq: min=600000 max=900000
[ 1.584713] sdhci: Secure Digital Host Controller Interface driver
[ 1.584725] sdhci: Copyright(c) Pierre Ossman
[ 1.585129] sdhost: log_buf @ bac13000 (fac13000)
[ 1.642745] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.643047] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.643751] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.643971] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.644218] usbcore: registered new interface driver usbhid
[ 1.644230] usbhid: USB HID core driver
[ 1.644898] Initializing XFRM netlink socket
[ 1.644952] NET: Registered protocol family 17
[ 1.645159] Key type dns_resolver registered
[ 1.645902] Registering SWP/SWPB emulation handler
[ 1.647030] registered taskstats version 1
[ 1.647300] vc-sm: Videocore shared memory driver
[ 1.647320] [vc_sm_connected_init]: start
[ 1.663481] [vc_sm_connected_init]: end - returning 0
[ 1.663908] of_cfs_init
[ 1.664023] of_cfs_init: OK
[ 1.665230] Waiting for root device /dev/mmcblk0p2...
[ 1.699989] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.701963] mmc0: new high speed SDHC card at address 0001
[ 1.702845] mmcblk0: mmc0:0001 SD8GB 7.32 GiB
[ 1.704757] mmcblk0: p1 p2
[ 1.772846] Indeed it is in host mode hprt0 = 00021501
[ 1.847245] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.847315] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.857073] devtmpfs: mounted
[ 1.857878] Freeing unused kernel memory: 476K (807d5000 - 8084c000)
[ 1.952770] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.952975] Indeed it is in host mode hprt0 = 00001101
[ 2.153140] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.153167] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.154142] hub 1-1:1.0: USB hub found
[ 2.154274] hub 1-1:1.0: 5 ports detected
[ 2.164668] random: systemd: uninitialized urandom read (16 bytes read, 36 bits of entropy available)
[ 2.170786] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -BANNED)
[ 2.171331] systemd[1]: Detected architecture 'arm'.
[ 2.287142] NET: Registered protocol family 10
[ 2.289238] systemd[1]: Inserted module 'ipv6'
[ 2.291893] systemd[1]: Set hostname to <raspberrypi>.
[ 2.403406] uart-pl011 3f201000.uart: no DMA platform data
[ 2.431044] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 62 bits of entropy available)
[ 2.432789] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.533209] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.533238] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.536374] smsc95xx v1.0.4
[ 2.556510] random: systemd: uninitialized urandom read (16 bytes read, 65 bits of entropy available)
[ 2.558243] random: systemd: uninitialized urandom read (16 bytes read, 65 bits of entropy available)
[ 2.560149] random: systemd: uninitialized urandom read (16 bytes read, 65 bits of entropy available)
[ 2.584767] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.585814] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.586062] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 2.597217] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:19:f9:04
[ 2.639953] random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
[ 2.644125] random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
[ 2.816579] systemd[1]: Expecting device dev-ttyAMA0.device...
[ 2.817116] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 2.817451] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.817568] systemd[1]: Starting Remote File Systems (Pre).
[ 2.817669] systemd[1]: Reached target Remote File Systems (Pre).
[ 2.817864] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 2.818513] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.818639] systemd[1]: Starting Encrypted Volumes.
[ 2.818735] systemd[1]: Reached target Encrypted Volumes.
[ 2.818842] systemd[1]: Starting Swap.
[ 2.818934] systemd[1]: Reached target Swap.
[ 2.819030] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 2.819125] systemd[1]: Starting Root Slice.
[ 2.819319] systemd[1]: Created slice Root Slice.
[ 2.819414] systemd[1]: Starting User and Session Slice.
[ 2.819738] systemd[1]: Created slice User and Session Slice.
[ 2.819836] systemd[1]: Starting Delayed Shutdown Socket.
[ 2.820075] systemd[1]: Listening on Delayed Shutdown Socket.
[ 2.820172] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 2.820427] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.820520] systemd[1]: Starting Journal Socket (/dev/log).
[ 2.820809] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.820937] systemd[1]: Starting udev Control Socket.
[ 2.821152] systemd[1]: Listening on udev Control Socket.
[ 2.821271] systemd[1]: Starting udev Kernel Socket.
[ 2.821439] systemd[1]: Listening on udev Kernel Socket.
[ 2.821558] systemd[1]: Starting Journal Socket.
[ 2.821819] systemd[1]: Listening on Journal Socket.
[ 2.821979] systemd[1]: Starting System Slice.
[ 2.822308] systemd[1]: Created slice System Slice.
[ 2.822470] systemd[1]: Starting File System Check on Root Device...
[ 2.863641] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 2.864206] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.864388] systemd[1]: Starting system-autologin.slice.
[ 2.864788] systemd[1]: Created slice system-autologin.slice.
[ 2.864893] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 2.865266] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.865566] systemd[1]: Starting Increase datagram queue length...
[ 2.869922] systemd[1]: Starting Restore / save the current clock...
[ 2.876638] systemd[1]: Mounted Huge Pages File System.
[ 2.876892] systemd[1]: Starting udev Coldplug all Devices...
[ 2.881952] systemd[1]: Mounting Debug File System...
[ 2.918698] systemd[1]: Started Set Up Additional Binary Formats.
[ 2.919662] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 2.926642] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.973877] systemd[1]: Starting Load Kernel Modules...
[ 2.979685] systemd[1]: Starting Slices.
[ 2.979894] systemd[1]: Reached target Slices.
[ 2.989310] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 3.032485] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.033126] systemd[1]: Mounted Debug File System.
[ 3.037057] systemd[1]: Started Increase datagram queue length.
[ 3.048134] fuse init (API version 7.23)
[ 3.086009] i2c /dev entries driver
[ 3.086828] systemd[1]: Started Restore / save the current clock.
[ 3.088993] systemd[1]: Started udev Coldplug all Devices.
[ 3.095471] systemd[1]: Time has been changed
[ 3.098778] Adafruit Industries' power switch driver v1.7
[ 3.111604] systemd[1]: Started Load Kernel Modules.
[ 3.193396] systemd[1]: Started File System Check on Root Device.
[ 3.257198] systemd[1]: Mounting FUSE Control File System...
[ 3.303807] systemd[1]: Mounting Configuration File System...
[ 3.307170] systemd[1]: Starting Apply Kernel Variables...
[ 3.311833] systemd[1]: Starting Syslog Socket.
[ 3.312371] systemd[1]: Listening on Syslog Socket.
[ 3.312649] systemd[1]: Starting Journal Service...
[ 3.317702] systemd[1]: Started Journal Service.
[ 3.521698] systemd-udevd[135]: starting version 215
[ 4.006731] input: ft6x06_ts as /devices/virtual/input/input0
[ 4.164190] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 83) (baudrate 100000)
[ 4.169687] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 4.170729] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.266266] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.518944] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.529057] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.531015] fbtft_of_value: buswidth = 8
[ 4.531049] fbtft_of_value: debug = 0
[ 4.531082] fbtft_of_value: rotate = 90
[ 4.531098] fbtft_of_value: fps = 20
[ 4.746181] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 4.953880] systemd-journald[129]: Received request to flush runtime journal from PID 1
[ 7.367590] Adding 102396k swap on /var/swap. Priority:-1 extents:3 across:487420k SSFS
[ 7.412357] cfg80211: World regulatory domain updated:
[ 7.412381] cfg80211: DFS Master region: unset
[ 7.412392] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.412405] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.412415] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.412425] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.412438] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.412450] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.412461] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.412471] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.412481] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 7.866068] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 7.866301] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.509527] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.510518] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 11.204338] random: nonblocking pool is initialized
[ 14.010200] Bluetooth: Core ver 2.21
[ 14.010367] NET: Registered protocol family 31
[ 14.010378] Bluetooth: HCI device and connection manager initialized
[ 14.010404] Bluetooth: HCI socket layer initialized
[ 14.010424] Bluetooth: L2CAP socket layer initialized
[ 14.010467] Bluetooth: SCO socket layer initialized
[ 14.055342] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.055369] Bluetooth: BNEP filters: protocol multicast
[ 14.055400] Bluetooth: BNEP socket layer initialized
- tonic
display 4:
[ 0.000345] Console: colour dummy device 80x30
[ 0.000576] console [tty1] enabled
[ 0.000605] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001004] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001025] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002206] Disabling cpuset control group subsystem
[ 0.002252] Initializing cgroup subsys io
[ 0.002285] Initializing cgroup subsys memory
[ 0.002344] Initializing cgroup subsys devices
[ 0.002369] Initializing cgroup subsys freezer
[ 0.002393] Initializing cgroup subsys net_cls
[ 0.002462] CPU: Testing write buffer coherency: ok
[ 0.002547] ftrace: allocating 21216 entries in 63 pages
[ 0.055540] CPU0: update cpu_capacity 1024
[ 0.055577] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.055594] [bcm2709_smp_prepare_cpus] enter
[ 0.055737] Setting up static identity map for 0x8240 - 0x8274
[ 0.058091] [bcm2709_boot_secondary] cpu:1 started (0) 16
[ 0.058454] [bcm2709_secondary_init] enter cpu:1
[ 0.058510] CPU1: update cpu_capacity 1024
[ 0.058518] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.059087] [bcm2709_boot_secondary] cpu:2 started (0) 16
[ 0.059374] [bcm2709_secondary_init] enter cpu:2
[ 0.059404] CPU2: update cpu_capacity 1024
[ 0.059412] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.059947] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.060200] [bcm2709_secondary_init] enter cpu:3
[ 0.060230] CPU3: update cpu_capacity 1024
[ 0.060237] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.060323] Brought up 4 CPUs
[ 0.060353] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.060363] CPU: All CPU(s) started in HYP mode.
[ 0.060372] CPU: Virtualization extensions available.
[ 0.061271] devtmpfs: initialized
[ 0.075427] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.075902] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.076897] pinctrl core: initialized pinctrl subsystem
[ 0.077687] NET: Registered protocol family 16
[ 0.083622] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.092681] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.092700] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.092910] Serial: AMBA PL011 UART driver
[ 0.093239] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.093662] console [ttyAMA0] enabled
[ 0.094303] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.168554] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.169317] SCSI subsystem initialized
[ 0.169556] usbcore: registered new interface driver usbfs
[ 0.169667] usbcore: registered new interface driver hub
[ 0.169823] usbcore: registered new device driver usb
[ 0.175145] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-09-21 13:13
[ 0.202804] clocksource: Switched to clocksource arch_sys_counter
[ 0.253006] FS-Cache: Loaded
[ 0.253402] CacheFiles: Loaded
[ 0.269904] NET: Registered protocol family 2
[ 0.271134] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.271287] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.271494] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.271622] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.271685] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.272026] NET: Registered protocol family 1
[ 0.272527] RPC: Registered named UNIX socket transport module.
[ 0.272544] RPC: Registered udp transport module.
[ 0.272555] RPC: Registered tcp transport module.
[ 0.272565] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.274124] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.275826] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.291728] VFS: Disk quotas dquot_6.6.0
[ 0.292105] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.294777] FS-Cache: Netfs 'nfs' registered for caching
[ 0.295929] NFS: Registering the id_resolver key type
[ 0.296003] Key type id_resolver registered
[ 0.296015] Key type id_legacy registered
[ 0.299120] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.299313] io scheduler noop registered
[ 0.299341] io scheduler deadline registered (default)
[ 0.299424] io scheduler cfq registered
[ 0.302318] BCM2708FB: allocated DMA memory fac00000
[ 0.302363] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.312107] Console: switching to colour frame buffer device 82x52
[ 1.146097] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.146334] vc-cma: Videocore CMA driver
[ 1.146351] vc-cma: vc_cma_base = 0x00000000
[ 1.146362] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.146373] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.146711] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.166849] brd: module loaded
[ 1.177873] loop: module loaded
[ 1.179016] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 1.180756] Loading iSCSI transport class v2.0-870.
[ 1.181655] usbcore: registered new interface driver smsc95xx
[ 1.181735] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.382103] Core Release: 2.80a
[ 1.382132] Setting default values for core params
[ 1.382181] Finished setting default values for core params
[ 1.582620] Using Buffer DMA mode
[ 1.582636] Periodic Transfer Interrupt Enhancement - disabled
[ 1.582646] Multiprocessor Interrupt Enhancement - disabled
[ 1.582657] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.582678] Dedicated Tx FIFOs mode
[ 1.583111] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 1.583150] FIQ FSM acceleration enabled for :
[ 1.583178] dwc_otg: Microframe scheduler enabled
[ 1.583246] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x804379d0
[ 1.583265] WARN::hcd_init_fiq:414: FIQ ASM at 0x80437d2c length 36
[ 1.583283] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb87e000
[ 1.583369] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.583420] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.583470] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.583526] Init: Port Power? op_state=1
[ 1.583537] Init: Power Port (0)
[ 1.583830] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.583849] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.583865] usb usb1: Product: DWC OTG Controller
[ 1.583881] usb usb1: Manufacturer: Linux 4.4.24-v7+ dwc_otg_hcd
[ 1.583896] usb usb1: SerialNumber: 3f980000.usb
[ 1.584969] hub 1-0:1.0: USB hub found
[ 1.585033] hub 1-0:1.0: 1 port detected
[ 1.585762] dwc_otg: FIQ enabled
[ 1.585776] dwc_otg: NAK holdoff enabled
[ 1.585786] dwc_otg: FIQ split-transaction FSM enabled
[ 1.585838] Module dwc_common_port init
[ 1.586229] usbcore: registered new interface driver usb-storage
[ 1.586608] mousedev: PS/2 mouse device common for all mice
[ 1.587542] bcm2835-cpufreq: min=600000 max=900000
[ 1.587917] sdhci: Secure Digital Host Controller Interface driver
[ 1.587930] sdhci: Copyright(c) Pierre Ossman
[ 1.588335] sdhost: log_buf @ bac13000 (fac13000)
[ 1.642846] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.643166] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.643853] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.644077] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.644334] usbcore: registered new interface driver usbhid
[ 1.644345] usbhid: USB HID core driver
[ 1.645007] Initializing XFRM netlink socket
[ 1.645060] NET: Registered protocol family 17
[ 1.645246] Key type dns_resolver registered
[ 1.645989] Registering SWP/SWPB emulation handler
[ 1.647157] registered taskstats version 1
[ 1.647435] vc-sm: Videocore shared memory driver
[ 1.647455] [vc_sm_connected_init]: start
[ 1.663851] [vc_sm_connected_init]: end - returning 0
[ 1.665607] Waiting for root device /dev/mmcblk0p2...
[ 1.700050] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.702026] mmc0: new high speed SDHC card at address 0001
[ 1.702897] mmcblk0: mmc0:0001 SD8GB 7.32 GiB
[ 1.704806] mmcblk0: p1 p2
[ 1.776002] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.776022] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.782980] Indeed it is in host mode hprt0 = 00021501
[ 1.962908] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.963113] Indeed it is in host mode hprt0 = 00001101
[ 2.163203] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.163227] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.164224] hub 1-1:1.0: USB hub found
[ 2.164350] hub 1-1:1.0: 5 ports detected
[ 2.282321] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 2.282766] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[ 2.282874] EXT4-fs (mmcblk0p2): recovery complete
[ 2.320433] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.320514] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.328572] devtmpfs: mounted
[ 2.329372] Freeing unused kernel memory: 476K (807d5000 - 8084c000)
[ 2.442872] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.543253] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.543280] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.546360] smsc95xx v1.0.4
[ 2.607376] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:19:f9:04
[ 2.623122] random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
[ 2.628674] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -BANNED)
[ 2.629163] systemd[1]: Detected architecture 'arm'.
[ 2.742609] NET: Registered protocol family 10
[ 2.744753] systemd[1]: Inserted module 'ipv6'
[ 2.747220] systemd[1]: Set hostname to <raspberrypi>.
[ 2.847916] uart-pl011 3f201000.uart: no DMA platform data
[ 2.887644] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[ 3.002017] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 3.003892] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 3.005765] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 3.028706] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 3.029716] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 3.029963] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 3.081308] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 3.085430] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 3.256246] systemd[1]: Expecting device dev-ttyAMA0.device...
[ 3.256799] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 3.257121] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.257234] systemd[1]: Starting Remote File Systems (Pre).
[ 3.257335] systemd[1]: Reached target Remote File Systems (Pre).
[ 3.257533] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 3.258199] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.258325] systemd[1]: Starting Encrypted Volumes.
[ 3.258423] systemd[1]: Reached target Encrypted Volumes.
[ 3.258531] systemd[1]: Starting Swap.
[ 3.258622] systemd[1]: Reached target Swap.
[ 3.258719] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 3.258814] systemd[1]: Starting Root Slice.
[ 3.259015] systemd[1]: Created slice Root Slice.
[ 3.259111] systemd[1]: Starting User and Session Slice.
[ 3.259439] systemd[1]: Created slice User and Session Slice.
[ 3.259540] systemd[1]: Starting Delayed Shutdown Socket.
[ 3.259789] systemd[1]: Listening on Delayed Shutdown Socket.
[ 3.259890] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 3.260155] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.260252] systemd[1]: Starting Journal Socket (/dev/log).
[ 3.260507] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.260632] systemd[1]: Starting udev Control Socket.
[ 3.260847] systemd[1]: Listening on udev Control Socket.
[ 3.260963] systemd[1]: Starting udev Kernel Socket.
[ 3.261133] systemd[1]: Listening on udev Kernel Socket.
[ 3.261250] systemd[1]: Starting Journal Socket.
[ 3.261512] systemd[1]: Listening on Journal Socket.
[ 3.261671] systemd[1]: Starting System Slice.
[ 3.261978] systemd[1]: Created slice System Slice.
[ 3.262136] systemd[1]: Starting File System Check on Root Device...
[ 3.293705] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 3.294261] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.294448] systemd[1]: Starting system-autologin.slice.
[ 3.294855] systemd[1]: Created slice system-autologin.slice.
[ 3.294961] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 3.295354] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 3.295858] systemd[1]: Starting Increase datagram queue length...
[ 3.299985] systemd[1]: Starting Restore / save the current clock...
[ 3.306520] systemd[1]: Mounted Huge Pages File System.
[ 3.306946] systemd[1]: Starting udev Coldplug all Devices...
[ 3.311522] systemd[1]: Mounting Debug File System...
[ 3.340827] systemd[1]: Started Set Up Additional Binary Formats.
[ 3.341663] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 3.346342] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.403801] systemd[1]: Starting Load Kernel Modules...
[ 3.408015] systemd[1]: Starting Slices.
[ 3.408225] systemd[1]: Reached target Slices.
[ 3.414911] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 3.462756] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.463626] systemd[1]: Mounted Debug File System.
[ 3.467817] systemd[1]: Started Increase datagram queue length.
[ 3.481923] fuse init (API version 7.23)
[ 3.514997] systemd[1]: Started Restore / save the current clock.
[ 3.515210] i2c /dev entries driver
[ 3.520077] systemd[1]: Time has been changed
[ 3.522636] systemd[1]: Started udev Coldplug all Devices.
[ 3.534073] Adafruit Industries' power switch driver v1.7
[ 3.541237] systemd[1]: Started Load Kernel Modules.
[ 3.621236] systemd[1]: Started File System Check on Root Device.
[ 3.684784] systemd[1]: Mounting FUSE Control File System...
[ 3.713861] systemd[1]: Mounting Configuration File System...
[ 3.717310] systemd[1]: Starting Apply Kernel Variables...
[ 3.722038] systemd[1]: Starting Syslog Socket.
[ 3.722574] systemd[1]: Listening on Syslog Socket.
[ 3.722930] systemd[1]: Starting Journal Service...
[ 3.727921] systemd[1]: Started Journal Service.
[ 3.942631] systemd-udevd[136]: starting version 215
[ 4.465311] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 4.475205] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.514917] input: ft6x06_ts as /devices/virtual/input/input0
[ 4.671721] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.673910] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 83) (baudrate 100000)
[ 4.865942] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.873722] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.875686] fbtft_of_value: buswidth = 8
[ 4.875736] fbtft_of_value: debug = 0
[ 4.875773] fbtft_of_value: rotate = 90
[ 4.875795] fbtft_of_value: fps = 20
[ 5.077032] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=20, spi0.0 at 32 MHz
[ 5.461475] systemd-journald[130]: Received request to flush runtime journal from PID 1
[ 7.772972] Adding 102396k swap on /var/swap. Priority:-1 extents:3 across:487420k SSFS
[ 7.842005] cfg80211: World regulatory domain updated:
[ 7.842027] cfg80211: DFS Master region: unset
[ 7.842035] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.842047] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.842058] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.842068] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.842081] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.842093] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.842104] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.842114] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.842124] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 8.375098] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 8.375371] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.017841] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.022007] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 11.248842] random: nonblocking pool is initialized
[ 14.532595] Bluetooth: Core ver 2.21
[ 14.534356] NET: Registered protocol family 31
[ 14.534379] Bluetooth: HCI device and connection manager initialized
[ 14.534413] Bluetooth: HCI socket layer initialized
[ 14.534432] Bluetooth: L2CAP socket layer initialized
[ 14.534477] Bluetooth: SCO socket layer initialized
[ 14.576657] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.576681] Bluetooth: BNEP filters: protocol multicast
[ 14.576711] Bluetooth: BNEP socket layer initialized
- tonic
Re: 4 faulty displays (ID 2423)
Please find above as requested the output of sudo dmesg.
Please let me know what's next.
- adafruit2
tonic, are you using our easy-install image?
- adafruit2
it seems its finding the capacitive touch controller - how are you testing the captouch?
- tonic
we touch it with a finger - what do you recommend?
several 100s worked fine. These do not ...
- adafruit2
lol yes you touch it with a finger but with what software? X11? pygame? :) if you swap the pi with a working one does that solve the issue?
- tonic
With X11.
We sold several 100s of these displays. They work usually fine, but these three do not (the one with the crack works fine, but has a crack). Changing the RPI does not help.
What's next?
Thanks for your help.
What's next?
