3.5" TFT 320x480 + Touchscreen Breakout Board
by dennisbowman on Tue Jun 13, 2017 2:39 pm
It doesn't seem to work! On powerup the display lights up but that’s all. I have tried SPI interface and the 8 bit Parall. and it acks the same way white screen no display. I have look at all the interface signals with a logic analyzer and all look correct?. So I guess I need to return it as it looks like a DOA one...
dennisbowman
Re: 3.5" TFT 320x480 + Touchscreen Breakout Board
by adafruit_support_rick on Thu Jun 15, 2017 3:33 pm
Please post clear, detailed pictures of both sides of the board, showing your soldering and wiring
by dennisbowman on Thu Jun 15, 2017 4:08 pm
Here are the pictures you ask for Connected to SPI interface.
Dennis
dennisbowman
by adafruit_support_rick on Fri Jun 16, 2017 9:00 am
The IM2 jumper doesn't look like it's closed. You need the solder to actually bridge the gap
by dennisbowman on Fri Jun 16, 2017 9:35 am
Here is a picture with im2 jumped to 3.3v !! Look as I said before I have tried both SPI and 8 bit mode and no response from display with the correct im2 jumper setting I am not sure what else I need to provide???
dennisbowman
by adafruit_support_rick on Fri Jun 16, 2017 2:41 pm
Not trying to put you off, but this is almost certainly a problem with either wiring or code. What sketch are you using? Are you using one of the standard Adafruit example sketches, like graphicstest? Can you post the serial monitor output from graphicstest?
by dennisbowman on Fri Jun 16, 2017 3:11 pm
OK Here is the picture of the Serial monitor output and the sketch and of the Display showing only a white screen when run. The sketch is from your example graphictest.
Look I have 3 other displays that I got working(SPI, 8bit & 16 bit Displays) very easy with no problems. This one has not worked at all!!! I do know how to make one WORK! I am getting tired of this Non Sense....I want to return it for a Refund because it was DOA!!!
Dennis
2017-06-16 (1).png (17.24 KiB) Viewed 178 times
2017-06-16 (2).png (83.6 KiB) Viewed 178 times
dennisbowman
by adafruit_support_rick on Fri Jun 16, 2017 4:01 pm
Please email support@adafruit.com with a link to this post for a refund
