1.44 Color TFT Display issues
by tenicho on Thu Jun 15, 2017 12:27 pm
I order the Adafruit 1.44" Color TFT with Micro SD Socket display https://www.adafruit.com/product/2088 on 5/22/2017. The order number is 1451805-7678739256.
I followed the tutorial that is recommended to use in the product description. When I run the graphicstest code I get a white screen. I commented out the wrong initializer and uncomment the correct one.
Here is a picture of the display after putting power to it and running code. It goes white as soon as I put power to it.
I'm pretty sure the product is bad.
tenicho
Re: 1.44 Color TFT Display issues
by tenicho on Fri Jun 16, 2017 11:03 am
no help technical support??
tenicho
by adafruit_support_carter on Fri Jun 16, 2017 12:22 pm
So you made this change?
// Use this initializer if you're using a 1.8" TFT
//tft.initR(INITR_BLACKTAB);   // initialize a ST7735S chip, black tab
// Use this initializer (uncomment) if you're using a 1.44" TFT
tft.initR(INITR_144GREENTAB);   // initialize a ST7735S chip, black tab
Did you try pressing RESET after uploading the sketch?
by tenicho on Fri Jun 16, 2017 12:38 pm
Thanks for the reply!
Yes I made that change, and yes I have tried that as well.
When running the graphics test, it will work once every 10 times I upload it. It will white screen every other time. That why I think it is an faulty display.
tenicho
by adafruit_support_carter on Fri Jun 16, 2017 12:45 pm
Sounds like it could be an intermittent wiring issue. When it does work, does it continue to work, or does it suddenly stop? The graphictest example should do some stuff and then enter a loop where it just inverts the display over and over once per second.
by tenicho on Fri Jun 23, 2017 11:14 am
I honestly think it just a bad board. It will work sometimes but the display will seem to flicker. Lately I can not even get the graphics test to even run. I have check connections many times with different wires etc. but nothing seems to works. I have even re-soldered the pins to insure there was a good connection.
tenicho
by adafruit_support_carter on Fri Jun 23, 2017 11:35 am
Let's try a replacement. Send an email to support@adafruit.com with a link to this thread and they can get you a replacement display.
