Can you test whether a specific neopixel is bad?
by jdpville on Sun Jun 18, 2017 2:10 pm
I have a series of flora neopixels in my project that used to all work fine. I have tested continuity, positive and negative connections - all good. Then checked voltage and it was correct. Control circuit from one to the next was good, but pixels don't light past a certain point. Is there a way to test individual pixels to see if they are bad?
jdpville
Re: Can you test whether a specific neopixel is bad?
by franklin97355 on Sun Jun 18, 2017 2:20 pm
You could disconnect the data wire from the previous pixel and put the data directly on Din of the test pixel.
franklin97355
by jdpville on Sun Jun 18, 2017 3:32 pm
Thanks for the quick response! I'll give that a try.
jdpville
