bmpDraw on M0 and TFT FeatherWing with SD
- clampron
Re: bmpDraw on M0 and TFT FeatherWing with SD
The card I'm currently using is a class 10. I'll purchase 3 alternatives with different specs and see if any of them work.
- clampron
Also, I read that at least 1 pin is used for the SD. Is it possible that one pin is defective? Sounds like everything else is via SPI.
- clampron
I tried two more SD cards tonight.
(1) SanDisk: Class 4 - Works great on the 32U4, not the M0.
(2) Lexar by Micron: Class 10 - Works great on the 32U4, intermittent on the M0.
The Lexar worked first try on the M0. I then added the purple.bmp file to it, booted the M0 and it wouldn't initialize the SD. (Same problem as before). I then reformatted it using the formatter from sdcard.org and transferred the file back to it and it worked on the M0 (all tested ok). I then compiled and uploaded another test program (without touching the SD or M0 or unplugging anything) and ran into initialization issues again. After using the power switch on the TFT, it then worked again.
Very strange behavior.
Any advice to resolve the instability?
Here's the formatter I used:
https://www.sdcard.org/downloads/formatter_4/index.html
Curt
Curt
- adafruit_support_rick
Oh, man. I have no idea. Let's try replacing the M0. That's all I can think of.
Please email [email protected] with a link to this post for a replacement
- adafruit2
hiya don't forget you have to set pin #8 to be an INPUT_PULLUP!
https://learn.adafruit.com/adafruit-fea ... dio-module
- danchen
Hello, I wired up my Feather M0 with the 128x128 TFT display and try to run the "Adafruit_ILI9341 > Graphic Test"
but it's showing white screen. the serial monitor is indicating that the scripting is running, but it's not slowing anything but white.
Here is my wiring
Feather M0 > 128x128 TFT
SCK > SCK
MOSI > MOSI
MISO > MISO
VIN > 3.3V
GND > GND
D/C > 9
TFT_CS > 10
Is there something wrong with my wiring?
thank you!
Here is my wiring
SCK > SCK
MOSI > MOSI
MISO > MISO
VIN > 3.3V
GND > GND
D/C > 9
TFT_CS > 10
thank you!
Are you running GraphicsTest or GraphicsTest_Featherwing?
Please post some pictures of your soldering.
Also, post the complete output from Serial Monitor
- rengelking
Nothing wrong with the card ... bug in the example: Change the file path, prepend a forward slash to the name: bmpDraw( "/purple.bmp",0,0 );
