Multiple NeoPixel Strips
by joshuakane on Wed Aug 09, 2017 9:04 am
I am following the guide on multitasking with the arduino for LED Strips
I have one strip using the scanner function, and I am trying to get a second one to light up the pixles on the strip with a delay between each of them, then extinguish them in the reverse order, kind of like counting up and then counting down. I created two functions for this and can do it with a single strip, but I am having trouble wrapping my head around how to incorporate it into the "PATTERN" and "UPDATE" logic of the example code.
Here are the two functions I created, based on ColorWipe
Color Wipe
void colorWipe(uint32_t c, uint8_t wait)
    for (uint16_t i = 0; i < strip.numPixels(); i++)
        strip.setPixelColor(i, c);
        strip.show();
        delay(wait);
Reverse ColorWipe
void ReverseColorWipe(uint32_t c, uint8_t wait)
    for (int i = (strip.numPixels() - 1); i >= 0; i--)
        strip.show();
        delay(wait);
Is it as simple as doing something like this?
    // Initialize for a Count Up/Down
    void CountUpDown(uint32_t color1, uint32_t color2, uint8_t interval, direction dir = FORWARD)
        ActivePattern = COUNT_UPDOWN;
        Interval = interval;
        TotalSteps = numPixels();
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    // Update the CountUpDown Pattern
    void CountUpDownUpdate()
        for (int i=0; i < numPixels(); i++)
           setPixelColor(i, Color1);
          delay(120);
            else (int i=0; i < numPixels(); i--)
                setPixelColor(i, Color2);
                delay(120);
        show();
        Increment();
joshuakane
Re: Multiple NeoPixel Strips
by adafruit_support_bill on Wed Aug 09, 2017 9:17 am
If you start from the first tutorial in the series, it explains that the first thing that you need to do is eliminate all calls to delay in all parts of your code. Everything stops during a delay, so multitasking is impossible. You need to do all of your timing using millis().
https://learn.adafruit.com/multi-taskin ... -the-delay
by joshuakane on Wed Aug 09, 2017 10:22 am
I went with this, but I can't get the strip to light up.
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
   int i = 0;
   if((Forward = true) && (currentMillis - previousMillis >= WaitTime))
             i++;
             if (i == 15){
               Forward = false;
    if((Forward = false) && (currentMillis - previousMillis >= WaitTime))
             i--;
             if (i == 0){
               Forward = true;
joshuakane
by adafruit_support_bill on Wed Aug 09, 2017 11:17 am
Your Update function does not call show() or Increment().
by joshuakane on Wed Aug 09, 2017 2:02 pm
I realized that and as I was coming back to edit the code, I saw you replied. I added them, and have tried them in several places in the loop and still have not met with success. Any assistance would be greatly appreciated.
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
   int i = 0;
    unsigned long currentMillis = millis();
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    previousMillis = currentMillis;
   if((UpDown = true) && (currentMillis - previousMillis >= WaitTime))
             if (i == 15){
               UpDown = false;
           if((UpDown = false) && (currentMillis - previousMillis >= WaitTime))
             i--;
             if (i == 0){
               UpDown = true;
     show();
     Increment();
joshuakane
by adafruit_support_bill on Wed Aug 09, 2017 2:14 pm
Where is UpDown defined? Please post the whole code.
by joshuakane on Wed Aug 09, 2017 2:19 pm
Here you go Bill,
This is the complete file
//---------------------------------BEGIN Yondu LIGHTING SECTION--------------------------------------------------------//
// Pattern types
enum  pattern { NONE, RAINBOW_CYCLE, SCANNER, COUNT_UPDOWN};
// Patern directions
enum  direction { FORWARD, REVERSE };
class YonduPatterns : public Adafruit_NeoPixel
    public:
    // Member Variables:
    pattern  ActivePattern;  // which pattern is running
    direction Direction;     // direction to run the pattern
    unsigned long Interval;   // milliseconds between updates
    unsigned long lastUpdate; // last update of position
    uint32_t Color1, Color2;  // What colors are in use
    uint16_t TotalSteps;  // total number of steps in the pattern
    uint16_t Index;  // current step within the pattern
    bool red, green, blue;
    unsigned long previousMillis = 0;        // will store last time LED Strip was updated
    long WaitTime = 120          ;           // milliseconds of Wait Time
    long interval = 1000;
    // check to see if it's time to change the state of the LED
    bool UpDown = true;
    // Constructor
    YonduPatterns(uint16_t pixels, uint8_t pin, uint8_t type)
    :Adafruit_NeoPixel(pixels, pin, type)
    // Update the pattern
    void Update()
        if((millis() - lastUpdate) > Interval) // time to update
            lastUpdate = millis();
            switch(ActivePattern)
                case RAINBOW_CYCLE:
                    RainbowCycleUpdate();
                    break;
                case SCANNER:
                    ScannerUpdate();
                    break;
               case COUNT_UPDOWN:
                    CountUpDownUpdate();
                    break;
                default:
                    break;
    // Increment the Index and reset at the end
    void Increment()
        if (Direction == FORWARD)
           Index++;
           if (Index >= TotalSteps)
                Index = 0;
        else // Direction == REVERSE
            --Index;
            if (Index <= 0)
                Index = TotalSteps-1;
    // Reverse pattern direction
    void Reverse()
            Direction = REVERSE;
        else
            Direction = FORWARD;
            Index = 0;
    // Initialize for a RainbowCycle
    void RainbowCycle(uint8_t interval, direction dir = FORWARD)
        ActivePattern = RAINBOW_CYCLE;
        TotalSteps = 255;
        Index = 0;
        Direction = dir;
    // Update the Rainbow Cycle Pattern
    void RainbowCycleUpdate()
        for(int i=0; i< numPixels(); i++)
            setPixelColor(i, Wheel(((i * 256 / numPixels()) + Index) & 255));
        show();
        Increment();
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
   int i = 0;
             if (i == 15){
               UpDown = false;
             i--;
             if (i == 0){
               UpDown = true;
     show();
     Increment();
    // Initialize for a SCANNNER
    void Scanner(uint32_t color1, uint8_t interval)
        ActivePattern = SCANNER;
        TotalSteps = (numPixels() - 1) * 2;
        Color1 = color1;
        Index = 0;
    // Update the Scanner Pattern
    void ScannerUpdate()
        for (int i = 0; i < numPixels(); i++)
            if (i == Index)  // Scan Pixel to the right
            else if (i == TotalSteps - Index) // Scan Pixel to the left
            else // Fading tail
                 setPixelColor(i, 255,0,0);
        show();
        Increment();
  // Calculate 50% dimmed version of a color (used by ScannerUpdate)
    uint32_t DimColor(uint32_t color)
        // Shift R, G and B components one bit to the right
        uint32_t dimColor = Color(Red(color) >> 2, Green(color) >> 2, Blue(color) >> 2);
        return dimColor;
    // Set all pixels to a color (synchronously)
    void ColorSet(uint32_t color)
            setPixelColor(i, color);
        show();
    // Returns the Red component of a 32-bit color
    uint8_t Red(uint32_t color)
        return (color >> 16) & 0xFF;
    // Returns the Green component of a 32-bit color
    uint8_t Green(uint32_t color)
        return (color >> 8) & 0xFF;
    // Returns the Blue component of a 32-bit color
    uint8_t Blue(uint32_t color)
        return color & 0xFF;
    // Input a value 0 to 255 to get a color value.
    // The colours are a transition r - g - b - back to r.
    uint32_t Wheel(byte WheelPos)
        WheelPos = 255 - WheelPos;
        if(WheelPos < 85)
            return Color(255 - WheelPos * 3, 0, WheelPos * 3);
        else if(WheelPos < 170)
            WheelPos -= 85;
            return Color(0, WheelPos * 3, 255 - WheelPos * 3);
        else
            WheelPos -= 170;
            return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
//---------------------------------- END Yondu Lighting SECTION ------------------------------------
#define UP 0
#define DOWN 1
// Define some YonduPatterns for the Radar, Jolo Projector, Side lights and PSI
YonduPatterns Radar(11, 5, NEO_GRB + NEO_KHZ800); //radar has 7 LEDs in it and will be controlled on pin 5
YonduPatterns Side(15, 9, NEO_GRB + NEO_KHZ800);  //Side sections  have 15 LEDs in it and will be controlled on pin 9
// Initialize everything and prepare to start
void setup()
    //initialize all our LED sections
    Radar.begin();
    Side.begin();
    Radar.setPixelColor(0, 255,0,0);
    Radar.setPixelColor(1, 255,0,0);
    Radar.setPixelColor(2, 255,0,0);
    Radar.setPixelColor(3, 255,0,0);
    Radar.setPixelColor(4, 255,0,0);
    Radar.setPixelColor(5, 255,0,0);
    Radar.setPixelColor(6, 255,0,0);
    Radar.setPixelColor(7, 255,0,0);
    Radar.setPixelColor(8, 255,0,0);
    Radar.setPixelColor(9, 255,0,0);
    Radar.setPixelColor(10, 255,0,0);
    Radar.setPixelColor(11, 255,0,0);
    Radar.Update();
    Radar.show();
    delay(3000);
    // Kick off a pattern
    Radar.Scanner(Radar.Color(255, 255, 0), 50); // Radar scans Cylon style red with 100ms interval;
    Side.CountUpDown(Side.Color(255, 0, 0), Side.Color(255, 0, 0),0 ,FORWARD); //Count up and down in red
// Main loop
void loop()
Radar.Update();
Side.Update();
joshuakane
by adafruit_support_bill on Wed Aug 09, 2017 2:56 pm
A couple of examples of a very common C/C++ programming error:
The "=" operator is the assignment operator. What you want here is the "==" comparison operator.
by joshuakane on Thu Aug 10, 2017 2:14 pm
Thank you Bill,
I did some more reading, and found a way to make it functional for my needs. Here was the final code I used.
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    if ((unsigned long)(millis() - previousMillis) >= interval) {
    previousMillis = millis();
        if((UpDown == true))
            Serial.print ("the vlaue of i is ");
            Serial.println (i);
            i++;
            show();
            Increment();
             if (i == 15){
               UpDown = false;
           if((UpDown == false))
             i--;
             show();
             Increment();
             if (i == 0){
               UpDown = true;
joshuakane
by adafruit_support_bill on Thu Aug 10, 2017 2:28 pm
Good to hear it is working. Thanks for the follow-up.
